How to flush heater core during radiator change - JeepForum.com
post #1 of 6 Old 01-19-2013, 08:37 AM Thread Starter
ckarmis
Can anyone answer the following questions:
1. Exactly how do you flush the heater core while changing out the radiator and thermostat. I've seen a few different posts but not sure which hoses to run the water hose through. Particuarly when I have the radiator disconnected and the thermostat removed. Any pictures to clarify would be helpful.
2. If I replaced the origainal radiator with a new mopar one, should I be using zerex G-05 or just the regular green stuff? I've also seen a few conflicing posts.
3. My current radiator cap is rated at 20#, but everythhing I read online says it should be 18#, so I'm replacing with an 18# one. Doest that sound right?
Thanks.
ckarmis is offline
post #2 of 6 Old 01-19-2013, 10:09 AM Thread Starter
ckarmis
For a 98 TJ
Also, to clarify point #2, I have a 98 TJ 6cyl. So I think the manuf recommendations call for the green stuff, but people recommend the zerex. Although I'm not sure if that's only for newer models, or applies to a 98 as well. All that said, I"m replacing the radiator with a new mopar one.
ckarmis is offline
post #3 of 6 Old 01-19-2013, 10:48 AM
Sandhara
just run the green stuff, it works just fine.
99 Wrangler Sahara 5spd manual - Mine
08 Patriot sport 4x4 auto - Wifes
92 Cherokee Lorado auto - for when mine needs fixin/winter beater
Im sorry, some times i drink and post stupid comments.
Sandhara is offline
post #4 of 6 Old 01-19-2013, 11:16 AM
oakmckinley
The thinner black hoses go to the heater core. Remove the hoses from thermo housing and other, and then flush water in one side, and then switch and flush into the other side (have the hose on pretty high, yes you'll get sprayed).
You should be good flushing both ways. I don't recommend putting anything in there, CLR etc. just use water.
If you are getting a radiator from mopar, ask them, if you not sure what coolant to use. I got my radiator from the dealer too, and was able to haggle on the price. It is much better one than after an market, IMO.
Good luck.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #5 of 6 Old 01-19-2013, 11:58 AM
LastDetail
Good write up right here with some good pictures.
Helped me to do it right the first time and I'm a moron.
http://www.jeepforum.com/forum/f9/he...hotos-1266369/
99 TJ 4.0 5spd F:D35 R:D44
LastDetail is offline
post #6 of 6 Old 01-19-2013, 10:31 PM Thread Starter
ckarmis
Mission Accomplished
Thanks for the feedback. Mission accomplished. Only snag was wermopar.com sent me the wrong lower radiator hose. But the old one was in good shape so I cleaned it up and put it back on.
ckarmis is offline
flush , heater core , radiator , radiator cap
