How to flush coolant - JeepForum.com
post #1 of 24 Old 05-05-2007, 06:18 PM Thread Starter
JeeperAbe
How do i flush and refill my coolant? I over heated this morning and come to find out there is a small peckock valve on the bottom and somehow it was open. Coolant everywhere on the raod....so i closed it and filled her up with water to test and see if i had a leak somewhere else or if it leaked anymore. Well it doesn't and im going to take a closer look at the valve but how do i drain the water out. And put new coolant in. What kind? How much? is it 50/50? I really dont know what im doing when it comes to the cooling system. Thanks!
1997 Jeep Wrangler SE 2.5l 4 cylinder auto, Stock.
Mods to come: 2" Coil lift, 31 MTs, Bumpers, Lights, Skids
JeeperAbe is offline
post #2 of 24 Old 05-05-2007, 06:28 PM
robncar
robncar's Avatar
Well, sorry to say, you've found the radiator drain. There is another drain on the block back by the exhaust. A 50/50 mix of coolant to distilled water is fine. Get a coolant that plays well with aluminum. Straight coolant in your reservoir, no water. You should be fine, good luck.
robncar is offline
post #3 of 24 Old 05-05-2007, 06:33 PM Thread Starter
JeeperAbe
Thanks...how to i purge the system of air...? Let it run with cap off for a little bit?
post #4 of 24 Old 05-05-2007, 06:36 PM
robncar
robncar's Avatar
Sure, why not. I've also "pulsed" the hoses a little by squeezing them and releasing. Just be carefull of the fan and anything that is rotating. The thermostat will usually have an air bleed on it (internal) that will help you eliminate air before it opens due to temperature upon warm up.
By the way, you may be able to get the coolant "pre-diluted" with de-mineralized water. Time saver if distilled water is hard to find.
robncar is offline
post #5 of 24 Old 05-05-2007, 06:43 PM Thread Starter
JeeperAbe
where might i be able to get it pre-dilluted?? Do you have maybe an idea where?
post #6 of 24 Old 05-05-2007, 06:52 PM
robncar
robncar's Avatar
I'm sure there are others but Prestone sells it pre-diluted, it's called "Prestone 50/50". Try:
Advance
Aid Auto
AutoZone
Bi-Lo
Brunos
Checker / Schuck's / Kragen
Coolants Plus
Food City
Harris Teeter
Kmart
Lowes Food
Meijer
Murray's Discount Auto
O'Reillys
Parks
Pep Boys
Piggy Wiggly
Service Auto Parts
Strauss Discount Auto
Wal-Mart
...no, I didn't make up this list, or know it off hand, I copied it from the Prestone site.
robncar is offline
post #7 of 24 Old 05-05-2007, 06:58 PM Thread Starter
JeeperAbe
haha ....Thanks very much you sig pictures is pretty cool..Love red jeep!
post #8 of 24 Old 05-05-2007, 07:00 PM
BORY
TJ Wrangler
stick a hose in the filler neck and open the plugs in the block and let it clean the system it works good.
BORY is offline
post #9 of 24 Old 05-05-2007, 07:04 PM Thread Starter
JeeperAbe
How much antifreeze do i need? Two Bottles? 3 bottles? there a gallon each in think,
post #10 of 24 Old 05-05-2007, 07:09 PM
robncar
robncar's Avatar
Should be 9 quarts for the 4 cylinder total + some for the resevoir. 10.5 quarts for the 6 cylinder. Looks like you'll need to buy 3 gallons if you go with the 50/50 pre-mix!
robncar is offline
post #11 of 24 Old 05-05-2007, 07:12 PM Thread Starter
JeeperAbe
Thank you so much....Looks like got a project for tomarrow.
post #12 of 24 Old 05-05-2007, 08:12 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
I picked up one of those cheap Prestone flush and fill kits at Autozone. It worked great for really getting all the old stuff out......and watering my lawn at the same time. They are cheap and easy to use. Rinse out your resevoir while you are at it. I removed mine, filled it halfway with water, dish soap and a little sand. Shook it up and rinsed it really good. Got it back to the point where you can see through it again.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #13 of 24 Old 05-05-2007, 08:16 PM
TJ_Firefighter
TJ_Firefighter's Avatar
prestone also sells a flush kit....it works really good actually....you just cut one of the heater hoses and install a fitting that will hook up to a garden hose...turn hose on....and flush away
1999 TJ
4.0L
2" BB 2"BL, ProComp Adj. Front Track-bar, SkyJacker Hydro 7000 shocks
33x12.50 Dunlop RV
Kahki Jeep Club Member #42
U.S.C.G. Jeep Club Member #1
Firefighting Jeep #2
Soon to come: HomeFab Rockers
TJ_Firefighter is offline
post #14 of 24 Old 05-05-2007, 08:18 PM
cheesycook
cheesycook's Avatar
TJ_Firefighter, beat you to it. I am a firefighter in training.....so I am over-eager!
Hermiston, ORL
post #15 of 24 Old 05-05-2007, 08:23 PM
TJ_Firefighter
grrrrr......thats cool man, just remember "When all others run away, firefighters run in."
1999 TJ
4.0L
33x12.50 Dunlop RV
Coolant flush TheMatrix TJ Wrangler Technical Forum 1 01-14-2009 04:39 PM
4.0l coolant flush valacech TJ Wrangler Technical Forum 10 05-10-2008 09:03 AM
coolant flush? shinigami YJ Wrangler Technical Forum 5 08-25-2007 08:05 PM
Coolant flush bryris YJ Wrangler Technical Forum 1 03-31-2006 07:07 AM
coolant flush dazed TJ Wrangler Technical Forum 2 12-14-2005 01:22 PM
