how to fix hole in air line - JeepForum.com
post #1 of 16 Old 05-08-2010, 01:04 PM Thread Starter
incagoldjeep
so one of my airlines touched my exhaust when i was offroading and has a hole in it now. its a black air line if that makes a difference. how can i repair this hole?
incagoldjeep is offline
post #2 of 16 Old 05-08-2010, 01:07 PM
LuckRider
LuckRider's Avatar
You should just replace it. There is no point in trying to fix it just to have a leak still.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #3 of 16 Old 05-08-2010, 01:22 PM Thread Starter
incagoldjeep
so theres no way i can repair the hole for good without it leaking? ive read online that i could put duct tape over it. ive tried electical tape but that didnt work. could i try anything else?
post #4 of 16 Old 05-08-2010, 01:37 PM
FLbuckeye
i suppose you could use a hose mender to fix it. you'd cut the hose wherever the leak is at and it's an insert that goes where you cut the hose then you just tighten both sides with hose clamps over the insert... might work
FLbuckeye is offline
post #5 of 16 Old 05-08-2010, 01:39 PM
zbob
Try A air line repair kit probably any hardware store would have them.No need to replace the whole line.
zbob is offline
post #6 of 16 Old 05-08-2010, 03:23 PM
MO2500
what's the line for? Is it a vacuum line somewhere or a axle vent tube? I don't see air lockers in your profile and unless you have installed on-board air there shouldn't be any air lines near your exhaust. Pics?
Instagram: @omsmike
MO2500 is offline
post #7 of 16 Old 05-08-2010, 03:30 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
ARBs or shocks.... and yes, please elaborate on what it's for?
GOLENJEEPTJ is offline
post #8 of 16 Old 05-08-2010, 05:47 PM Thread Starter
incagoldjeep
Its for and onboard air system and imma go an check the hardware stores tomorrow and see what they got. it goes from my air horn to my tank
post #9 of 16 Old 05-08-2010, 07:17 PM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Really man? You need to ask how you can cut and couple a rubber line together?
MAN CARD REVOKED.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #10 of 16 Old 05-08-2010, 08:50 PM Thread Starter
incagoldjeep
I wanted to cut it but wasn't sure what to use to put the 2 parts back together. What should I use?
post #11 of 16 Old 05-08-2010, 09:09 PM
chadsmeltzer
chadsmeltzer's Avatar
Use a hose barb and two hose clamps. Local hardware store should have them.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #12 of 16 Old 05-09-2010, 02:27 AM
wushaw
Rockin jeep
wushaw's Avatar
If it's a rubber air line then use the barb union, but if it's the nylon type then you need to use a different union.
wushaw is offline
post #13 of 16 Old 05-10-2010, 08:20 PM Thread Starter
incagoldjeep
alright guys got it fixed thanks for the help. i used a copper hose barb like the one pictured except it didnt have the 2 yellow things. i cut out the area with the hole and then bushed the barb in both side real good and now the air system is running good.
post #14 of 16 Old 05-10-2010, 08:28 PM
Apex
Recon death squad
Apex's Avatar
Now get that line away from your damn exhaust!
Apex is offline
post #15 of 16 Old 05-10-2010, 08:31 PM
LuckRider
LuckRider's Avatar
x2. Keep it from happening again.
Support Our Troops!
JFI Member #7:
BL installation & 1 hole won't line up outlawjosywales TJ Wrangler Technical Forum 11 03-29-2009 11:14 AM
hole on hard plastic fuel line, need help b3llo38 YJ Wrangler Technical Forum 4 12-15-2008 05:51 PM
temp fix for hole in brake line mitchf350 TJ Wrangler Technical Forum 17 06-30-2008 10:10 AM
front brake line relocation hole size base shakers TJ Wrangler Technical Forum 2 06-27-2008 09:41 AM
Hole and Thread size of D44 Axle Vent hole JeepRocks86 TJ Wrangler Technical Forum 1 12-31-2006 05:07 PM
