How To Figure Out Wheel Size - JeepForum.com
post #1 of 4 Old 07-14-2010, 08:07 PM Thread Starter
CONNOR_99TJ
2010 JK Wrangler
I am looking at new wheels for my TJ, but the only thing is how do I figure out the wheel size I need. I see that there are 15x8 and then 5x?(number). How do you figure out those numbers? Thanks!
CONNOR_99TJ is offline
post #2 of 4 Old 07-14-2010, 08:19 PM
BlueFlame
BlueFlame's Avatar
Let's make it easier.
The most common and aruguably best 15" wheel for the TJ is 15x8 with 4" backspacing.
3.5" to 4.5" backspacing works fine.
The bolt pattern is 5x4.5" (That's 5 lugs/ 4.5" circle)
What size tires do you want to run?
BlueFlame is offline
post #3 of 4 Old 07-14-2010, 09:07 PM Thread Starter
CONNOR_99TJ
2010 JK Wrangler
31x10.5
post #4 of 4 Old 07-14-2010, 09:22 PM
Jay12
get 15x8 wheels for your tire size
Jay12 is offline
wheel size , bolt pattern , width , wheel
Figure out lift size? ImNotStuck TJ Wrangler Technical Forum 2 10-25-2009 05:25 PM
how to figure out max tire size? MC_NickP TJ Wrangler Technical Forum 7 01-04-2009 01:29 PM
wheel center hole size vs hub ring size thartman YJ Wrangler Technical Forum 8 10-27-2008 09:22 PM
When counting drive shaft revolutions to figure out gear ratio,does tire size matter? chaznad TJ Wrangler Technical Forum 11 08-23-2005 08:19 AM
Trying to figure out what size lift i have wildhorse TJ Wrangler Technical Forum 13 04-14-2005 01:16 PM
