How Fast is too Fast in 4-wheel drive? - JeepForum.com
post #1 of 62 Old 12-06-2007, 03:21 PM Thread Starter
rfoster458
Just a quick question. My wife is driving my 04' TJ that has the automatic overdrive because of bad weather (finally some snow to play in!). She has some highway driving where the road is clear and she doesn't need to be in 4-wheel, except that her driving to get to that point, the road is bad. So she can't really stop to take it out of 4-wheel because she needs it when she gets off of the highway as well. Anyway, let me get to the point. How fast is too fast to drive our 6 cyl. 4 speed auto when it is on the highway and it's in 4-high?
Thanks!
Rob
Fishers, IN
2004 Sport automatic, Moab wheels with 265's, 2.5" spring lift, quick discos, and etc. More to come over time...
rfoster458 is offline
post #2 of 62 Old 12-06-2007, 03:24 PM
BadAddetude
They say 40 mph, but the way it should be viewed, if you have to have it in 4wd, then you shouldn't be going faster than 25-35 mph. 4wd keeps you in a strait line and gets you going, it doesnt stop it.
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread:
BadAddetude is offline
post #3 of 62 Old 12-06-2007, 03:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Who says 40 mph in 4HI? Check the owner's manual and follow it.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 62 Old 12-06-2007, 03:34 PM
03silversport
I have always heard 55 mph.
03silversport is offline
post #5 of 62 Old 12-06-2007, 03:36 PM
DBLJ
DBLJ's Avatar
If you need it then you shouldnt be going fast.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #6 of 62 Old 12-06-2007, 03:38 PM Thread Starter
rfoster458
She doesn't need it on the highway, but needs when she exits. The exits are crap and don't get plowed. And I don't have a manual to refer to unfortunately.
Rob
Fishers, IN
post #7 of 62 Old 12-06-2007, 03:40 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
I would recommend that she only drive as fast as she feels comfortable with; And she doens't have to stop to take it out of 4wd - the 231 is a shift on the fly TC. I believe the manual says up to 55 mph. So when she gets to the good part of the road all she has to do is push the TC handle forward and she's good to go...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #8 of 62 Old 12-06-2007, 03:41 PM
mdm
Farm Wheeler
Originally Posted by rfoster458
...she can't really stop to take it out of 4-wheel because she needs it when she gets off of the highway as well...
You don't have to stop the shift between 2Hi and 4Hi. It is an "on the fly" shift. Depending on the year model the manual may say you can make the shift at speeds up to 55 mph or "at any legal speed".
They say 40 mph,...
Who is "they"? I've not seen this anywhere.
...if you have to have it in 4wd, then you shouldn't be going faster than 25-35 mph. 4wd keeps you in a strait line and gets you going, it doesnt stop it.
I do pretty much agree with this part. If you need to be in 4Hi because of road conditions your speed should be pretty low.
If you are in road conditions that require you to be shifting in and out of 4Hi on a regular basis your speed should be fairly low. If you are hitting ice/snow patched that require you to be shifting into 4Hi, what are you doing? Driving in 2Hi at 50+ and then slamming into 4Lo and slowing down when you hit the ice/snow? What happens when you don't see it in time because of a hill or curve?
mdm is offline
post #9 of 62 Old 12-06-2007, 03:42 PM Thread Starter
rfoster458
Awesome, thanks! I know the 231 is a shift of the fly TC, but I've always been scared of doing that since I'm used to my old Jeep. Thanks for the info though!
Rob
Fishers, IN
post #10 of 62 Old 12-06-2007, 03:43 PM
Crashnburn80
Crashnburn80's Avatar
Exactly.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #11 of 62 Old 12-06-2007, 03:46 PM
Brian P
Thanks!
Short answer... 0 mph! The 4-wheel drive system in our TJ's need slippage when in 4wd. You do NOT have to stop to go into or out of 4HI. You can go from 2HI to 4HI and back at any legal speed. You do not have to be in nutral either, just let up a little on the gas and pull the lever up to 4HI or down to 2HI.
Brian Phillips
05 Unlimited
Brian Phillips
05 Unlimited
Brian P is offline
post #12 of 62 Old 12-06-2007, 03:48 PM Thread Starter
rfoster458
The highway is completely clear of snow and ice, but the side roads are not. There are people flying by her going like 80 and she asked me how fast she could go while in 4-wheel. I thought 55, but I wasn't for sure, so I thought I would ask. Yes, I understand that if it needs to be in 4-wheel then you shouldn't be going that fast, but humor me here. Thanks for all the input. And why does our 4-wheel need slippage?
Rob
Fishers, IN
post #13 of 62 Old 12-06-2007, 03:51 PM
mdm
Farm Wheeler
Originally Posted by Brian P
Short answer... 0 mph! The 4-wheel drive system in our TJ's need slippage when in 4wd...
Longer question - How far can you drive in 4Hi on pavement before you do damage to the drive train?
mdm is offline
post #14 of 62 Old 12-06-2007, 03:52 PM Thread Starter
rfoster458
That's a good question mdm. I am curious to know that and to know why the TJ needs slippage?
Rob
Fishers, IN
post #15 of 62 Old 12-06-2007, 03:53 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
it locks the front and rear axles going the same speed, if there is any difference in rotation from the front to the back, all that energy is bound up in the transfer case, if the tires cant slip to release that, then boom, there goes your t-case.
its part time 4wd for a reason, not meant to be used on dry roads.
maybe you should get your wife a grand cherokee, with all-wheel drive.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
Can you drive fast without killing your JK girly04LJ JK Wrangler Technical Forum 36 01-20-2010 09:06 PM
Need Help Fast!!! I Need To Drive Tomorrow!!! headstrong50 YJ Wrangler Technical Forum 40 01-20-2010 07:43 PM
I need super fast suggestions on this wheel. BloodThirsty TJ Wrangler Technical Forum 49 02-21-2009 10:12 AM
How long, far, fast Is it permissible to drive w/ only front DS? Sky Hye TJ Wrangler Technical Forum 4 09-19-2007 01:19 PM
how fast in front wheel drive?? coorsmgood TJ Wrangler Technical Forum 13 10-08-2005 01:27 AM
