How fast can I go in 4WD Hi?? - JeepForum.com
post #1 of 26 Old 04-20-2004, 04:38 PM Thread Starter
gsdz28
gsdz28's Avatar
How fast and how long can I safely go in 4Wd high???
like if it's raining pretty hard outside does that make a difference?? someone told me the water splashing on the rear end/transfer case would help keep it cool.
and i don't have a owners manual
1993 Wrangler, I6, 5 speed, no mods.......YET
gsdz28 is offline
post #2 of 26 Old 04-20-2004, 04:42 PM
chris06
chris06's Avatar
55mph
2wd will be fine in rain.
2000 Black Sahara
Toys X Troy Croners
LED's
chris06 is offline
post #3 of 26 Old 04-20-2004, 04:52 PM Thread Starter
gsdz28
gsdz28's Avatar
Originally Posted by chris06
55mph
actually i have been having a bad time slipping and sliding and the tires are brand new!
gsdz28 is offline
post #4 of 26 Old 04-20-2004, 05:01 PM
MFairbourn
MFairbourn's Avatar
It is actually normal for tires to slide a little in the rain when they are brand new. Tires need to be scuffed a little before you get full traction on them..
03 Rubicon- Teraflex 3T, 285/75 MTRs.
99 WJ (Wife's)--She has tow hooks too.
77 CJ7--Everything works but the heater, and man is she Ugly.
MFairbourn is offline
post #5 of 26 Old 04-20-2004, 06:11 PM
bj-666
bj-666's Avatar
0 mph is good if you go any faster on pavment you can hurt the t-case if you have select track it is no prob but comand track is. the problem is that the front and rear tires move at different speeds when turning and you bind the gears/belt in the t-case if you have comand track. if there is snow or ice it is a different.
o i sound kinda stupid saying this but i might have the comand and select track mixed up
(edit) hahah somehow i am in the tj forum u guys might have different t-cases. sory no clue how i got in here o well
[COLOR=red]
96 xj sport 4.0 HO non-abs
218,000 runnin strong as ever
6" full traction, Q78's, 8.8 ECTED locker,Rocky-Road rock rails, proto fab front bumper, ramsey 8.5e, HPd44 ARB front, OBA, Quick disconects
bj-666 is offline
post #6 of 26 Old 04-20-2004, 06:15 PM
JeepN2
JeepN2's Avatar
Owners manual says 55 I do beleive. I've had mine up to 75 a few times when I forgot to shift out of 4wd high. It wont damage anything but will increase the wear since it cant slip like on ice or snow. What tires do you have? You shouldnt be getting that much slipping in rain that 4wd high is needed.
Happy JeepN
[COLOR="Black"]His:
00 White XJ-New hunt/fish rig project, here we go again! COLOR]
Hers:P
07 Blue Compass 4x4
JeepN2 is offline
post #7 of 26 Old 04-20-2004, 06:36 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
I got the "welcome kit" from Jeep a few weeks ago. In it is the Winter edition of the Jeep owner's magazin as well as a 10 page leaflet called "Living The Jeep Life" which contains among other things, "Trail Rated/4WD Tips".
There's a chart regarding the different 4wd systems and what surfaces you'd use them for.
For CommandTrac (TJ), RockTrac (Rubi only) and SelecTrac (XJ+) it says you can use 4H in **Wet Pavement**, Gravel, or Snow.
2010 Sahara
04JeepTJ is offline
post #8 of 26 Old 04-20-2004, 06:39 PM
ctavel
ctavel's Avatar
I'm going to have to disagree--Unless DC started something new, all TJ's come with the NP231, which is a part time unit. So you should not drive it on pavement unless you really want to blow your Tcase apart. The reasoning is that when in $WD a part time unit basically locks the front and rear driveshafts together. Which equates to them spinning at the same speed period. When cornering your inside tires will turn slower than the outside and cause a difference in speeds of axle shafts which will in turn either blow a diff or shoot up into the Tcase. I don't want to sound belittling or condesending but I really would not want anyone blowing their TCase apart.
ctavel is offline
post #9 of 26 Old 04-20-2004, 06:56 PM
kadmos
SO, what kind of tires are they?
kadmos is offline
post #10 of 26 Old 04-20-2004, 07:00 PM
AudioGuru
AudioGuru's Avatar
The tj owners manual says that you can shift into or out of 4wd hi at any legal speed. So, I guess you can take it up to 65-70mph.
Don't lie. God said so.
AudioGuru is offline
post #11 of 26 Old 04-20-2004, 07:09 PM
04JeepTJ
04JeepTJ's Avatar
2010 JK Wrangler
Yeah, I know how it works.. I'm just writing what it says - not that I believe them. Don't shoot the messenger..
2010 Sahara
04JeepTJ is offline
post #12 of 26 Old 04-20-2004, 10:43 PM
PrfctAggression
PrfctAggression's Avatar
If you can safely do 55 with 4wd engaged, you don't need 4wd. All 4wd does is to help you to get going. It doesn't do a damn thing for stopping or turning. In fact, skids are easier to recover in 2wd than in 4wd.
Also, rain on paved roads does not provide sufficient slippage to prevent damage to the t-case. You can use it when taking off from a red light or tollbooth or whatever, but once you're moving, put it back into 2wd. Continuous driving will cause windup and damage. Even in the snow, I rarely keep it in 4hi. I'll use it to get going, then shift back to 2hi.
PrfctAggression is offline
post #13 of 26 Old 04-21-2004, 04:21 AM
wile_e_mopar
wile_e_mopar's Avatar
I agree, if you feel you can go 55 in 4WD, then you should have it in 2WD. If it is raining hard enough for you to slip and slide, SLOW DOWN. You may be more comfortable in 4WD so you think you can go faster, but your brakes still work the same as any car out there, you always have 4 wheel stop, 4WD does not make you stop faster. Sorry about the rant, little rage left over last winter from a Bronco totaling my neon and the kid telling me it was my fault because I wasn't going fast enough when I decided to stop for the tree that fell out of the truck in front of me. Direct quote to the officer and me.
"I had it in 4WD, he's only got front wheel drive, I can go faster in the snow. That is why he was able to stop and I wasn't."
This made the officer laugh, but it wasn't funny enough to make up for him totalling my car, its OK now cause my SRT-4 rocks
2002 Solar Yellow Sport-mine
2008 Jeep Compass-wife's
2006 FXDLI-mine
wile_e_mopar is offline
post #14 of 26 Old 04-21-2004, 06:46 AM
airduds
airduds's Avatar
Driving in 4wd on a hard surface is not going to make anything explode. It will accelerate wear on the tires and to a lesser extent on the transfer case and differentials.
airduds is offline
post #15 of 26 Old 04-21-2004, 09:01 AM
audie
Actually the U-joints are likely to go first, they're the weak link. Driving with 4 wheel engaged on hard surfaces puts a lot of stress on the drivetrain. As for wet, rainy roads, I just slow down.
98 SE
audie is offline
'99 sport 4wd - how fast is too fast? hangwire TJ Wrangler Technical Forum 7 12-24-2008 07:39 PM
Need help fast jeepwrnglr92 YJ Wrangler Technical Forum 16 03-08-2008 01:12 AM
How Fast is too Fast in 4-wheel drive? rfoster458 TJ Wrangler Technical Forum 61 12-07-2007 08:01 PM
Need Help Fast, Krisfyr TJ Wrangler Technical Forum 1 09-07-2006 07:06 AM
Need help fast ! Anthen27 TJ Wrangler Technical Forum 1 11-12-2004 11:07 PM
