How to eliminate smells from the Jeep - JeepForum.com
post #1 of 30 Old 01-06-2009, 06:10 PM Thread Starter
MB98XJ
My Jeep smells bad.
I've pulled the all the carpets and pressure washed and used professional carpet cleaner and used laundry detergant on them. I also keep my Jeep empty and vaccumed at all time. The odor makes the Jeep smell musty and bad. I'm guessing the previous owner smoked or something, so I'm thinking that the smoke went up into my soft top. I hope to fix that problem soon by replacing with a hard top. What do you guys do to keep your Jeep smelling good. I'm tired of getting into my perfectly clean Jeep and it smelling bad. It smells like body odor and people complain when they get in. How to I clean the seats or the inside of the soft top?
How do you keep your Jeep smelling good and how can I resolve my issue?
Thanks
YELLOW JEEP WRANGLER 2000 4.0L SPORT AUTOMATIC
JEEP CHEROKEE LIMITED 1999 BLACK LEATHER INTERIOR 4X4
MB98XJ is offline
post #2 of 30 Old 01-06-2009, 06:22 PM
bddisi
When it gets warmer, take the top off completely and wash the inside the same as you would the outside. Let dry, reinstall. As for the seats, if they are a cloth like material, dont be scared, take them out of the jeep and wash them in a simular fashon, take a shop vac or wet vac and extract what you can, after rinsing. Let dry, reinstall. Use a laundry like detergant or something like Woolite. Same for the carpet, go over lightly with press washer if you have access to one. Good luck.
Scorpion-Offroad-Concepts
bddisi is offline
post #3 of 30 Old 01-06-2009, 06:26 PM
Genericusername
haha like the seinfeld episode, whats that smell... B.O.
seriously though it might be the seats or something in the a/c
1997 ZJ 5.2L V8 256,000 miles "Fart"
Originally Posted by m_amilli View Post
by the thing that spins when you drive underneath
Genericusername is offline
post #4 of 30 Old 01-06-2009, 06:35 PM Thread Starter
MB98XJ
Yes I have cloth seats. How complicated is removal of the seats? I know the backseat is fairly simple. How should I soap them? Spray them? Don't want to ruin them you know...
MB98XJ is offline
post #5 of 30 Old 01-06-2009, 06:36 PM
vtx531
I like fabreeze and those pinetree air fresheners. The pine trees are quite potent. The cherry version is good too but its a jeep so you gotta go for pine.
vtx531 is offline
post #6 of 30 Old 01-06-2009, 06:37 PM Thread Starter
MB98XJ
I've used Fabreeze and Odor Eliminator sprays all over the seats, carpet, and I soaked the inside of the soft top with it. Still that smell...
MB98XJ is offline
post #7 of 30 Old 01-06-2009, 06:37 PM
madmax79
I'm Old Gregg!
madmax79's Avatar
Febreeze it!
'88 YJ, getting newer one part at a time. Details on my profile, you should fill out your profile too.
Early YJ Club, Member #1, Check out our group:
Epic adventures usually start with something like: "I was looking at a topo map..."
madmax79 is offline
post #8 of 30 Old 01-06-2009, 06:41 PM
BlaketheSnake
BlaketheSnake's Avatar
Quit farting with the doors on
Tread lightly or we all will be tree hugging hikers!
BlaketheSnake is offline
post #9 of 30 Old 01-06-2009, 06:53 PM
bddisi
Slightly wet them, then spray them down with a upholestry, or carpet cleaning solution. Woolite will also works. The main thing is not to use anything with bleach and rinse well, very well. You want them to dry evenly. No soapy spots left here or there. Extract them until you can tell there is nothing comming from them. Then wipe down with a clean towel. Let them air dry. Then if you feel you need air freshener, this will be the time to do this.
bddisi is offline
post #10 of 30 Old 01-06-2009, 07:02 PM
Dmcastino
Taking out the seat just requires removing the four bolts that bolt them to the floor. Super easy. Although if I remember right, to get at the ones in the rear, you have to tilt the seat forward and then flip back these little plastic covers to see them, again though its really easy.
All this is unnecessary though, you live in Georgia, pull the carpet, top, and doors off and run like that year round and enjoy the fresh air smell
Dmcastino is offline
post #11 of 30 Old 01-06-2009, 07:14 PM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
And stop leaving rusty nails on your seats.
Maybe you want to look at your ventilation system and clean it out.
This City is what it is because our citizens are what they are.
RiponredTJ is offline
post #12 of 30 Old 01-06-2009, 07:34 PM
BomberJeep
2011 WK
Also wipe down everything in the interior with a mild soap
Never get between a man and his Jeep - Stacey David.
BomberJeep is offline
post #13 of 30 Old 01-06-2009, 07:46 PM Thread Starter
MB98XJ
How do I look in my ventilation system easily
MB98XJ is offline
post #14 of 30 Old 01-06-2009, 07:53 PM
spokanistan
If the smell is still around come summer time then "bake" it out. Park your jeep in direct sunlight, top up, doors on, and just one window cracked open a little bit and let it sit there and bake and it will kinda burn out any smells.
I know it sounds odd but the above has proven itself to me.
Superman never made any money for saving the world from Solomon Grundy.
spokanistan is offline
post #15 of 30 Old 01-06-2009, 07:57 PM
Fjguercio
1978 CJ7
Odor is bacteria.... if it was summer I would say take your carpets out and let them sit in the sun for a day or two. The UV of the sun will kill bacterial. Since it is winter I would spray Fabreez or Oust Spray on the seats and carpet. Try to do on nice warm sunny day so it does not stay wet long.
Walmart also sells Ozium Spray in the auto section. Ozium kills smoke smell almost instantly. I would spray a good amount in back, under seats in the air and button up the jeep. Repeat 1 hr later. When spraying the Ozium try to hold your breath. Good for the fireplace backs up with smoke and stuff like that. Good stuff...
Ck your cowl hole infront of windshield. Debree, leaves, seeds fall in there and can decay and cause smells... this is where your fresh air for vent and heater come from. Do you park under a tree???? that can add odors too. Do you park outside that means more moisture.
I would also ck for leaks in the top. Smell means mold and mold needs moisture to grow.
Hope that helps,
Fred
Fjguercio is offline
jeep smells as gasoline metalroses YJ Wrangler Technical Forum 12 08-06-2009 01:48 PM
My jeep interior is wet and smells ? chaznad TJ Wrangler Technical Forum 10 07-02-2009 05:29 PM
Jeep problem: Check engine comes on, idle raises, smells like gas Hotimportcrx YJ Wrangler Technical Forum 4 07-18-2008 06:52 PM
Jeep still smells hot months after SYE install 01amberfirewv TJ Wrangler Technical Forum 7 12-25-2006 09:42 AM
my jeep smells zuck2001 YJ Wrangler Technical Forum 13 10-26-2001 02:03 PM
