How do you route your winch power cables? Pictures? - JeepForum.com
post #1 of 9 Old 08-19-2005, 09:47 AM Thread Starter
loudog3114
Just curious as mine are router rather obtrusively going in through the hood.
92 YJ, 35's, 6", Locked
97 Honda CBR1100xx
08 336XI
loudog3114 is offline
post #2 of 9 Old 08-19-2005, 10:04 AM
James04TJ
James04TJ's Avatar
Mine go under the grill and then up the fender well. You could also just run them through one of the slots in the grill. I have never heard of anyone going up to the hood.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's)
James04TJ is offline
post #3 of 9 Old 08-19-2005, 10:13 AM
otisdog
2008 WK
Yep under the grille and up through the fender well. I put some of that cable protector stuff on mine. You can buy it at any parts store - the corrugated looking plastic stuff. A few zips ties and you are in business
Jim
08 Grand Cherokee Overland
otisdog is offline
post #4 of 9 Old 08-19-2005, 10:32 AM
Rusty the Scoob
Rusty the Scoob's Avatar
Yeah, through the grill. Thought about going under, but just went through.
2001 TJ Sport 2" coil lift, 31" TrXus, swapped in 3.73s, ORFab cage, Aussie front locker, A to Z Fab rocker skids, JeepMedic Oil Pan Skid, JeepMedic LCA skids, Alloy USA D30 Seals, Warn Diff Skids, Cobra 75wx CB, Jeeperman prototype front bumper, 9.5ti, custom rear bumper, Rokmen frame tie-in kit.
Rusty the Scoob is offline
post #5 of 9 Old 08-19-2005, 10:35 AM
jeephreak
jeephreak's Avatar
not to high-jack, are is there a relay hooked up to the winch, or does it go right to the battery and have constant power. I don't have a winch yet, but am starting to look and wanted to know what the typical wiring scheme was. thanks!!
2005 Rubicon
lifted, some big tires, some of this, some of that...
r.i.p. Cap'n Crunch
jeephreak is offline
post #6 of 9 Old 08-19-2005, 11:04 AM
BluesMan
BluesMan's Avatar
Throught the grill and along side of the air box.
Note - I did put some electrical tape over the paint where the wires rub, as it took only 2-3 weeks to rub through the paint.
Straight to the battery, I've thought about a heavy duty relay with an in cab switch. Warn makes one.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
post #7 of 9 Old 08-19-2005, 08:15 PM
James04TJ
James04TJ's Avatar
There are heavy duty disconnect solenoids available however most winch makes, including WARN, recommend that you do not use one and just go straight to the battery. Keep in mind that an 8000lb winch under full load can draw 400+amps.
post #8 of 9 Old 08-19-2005, 08:26 PM
Scoobert
I ran 2 wires straight to the battery and put a forklift battery connector on the end right behind the grill. All my power stuff has the same connector. That way I can give people a jump without ever opening the hood. Works pretty well.
Power Plug
Scoobert is offline
post #9 of 9 Old 08-19-2005, 08:35 PM
jrtdogbone
jrtdogbone's Avatar
This may help ya: http://users.adelphia.net/~jrtdogbone/winch.htm
The Dog
The Dog
2004 Jeep Willys
jrtdogbone is offline
+ - winch cables LovinFirstJeep JK Wrangler Technical Forum 4 08-06-2009 08:30 AM
winch question- what is power in/power out capabillity staquinas TJ Wrangler Technical Forum 1 08-04-2009 05:44 PM
2ga power cables for winch 80 CHOPPER TJ Wrangler Technical Forum 42 08-13-2007 04:33 PM
Making longer winch cables - #2 wire termination end question commodog TJ Wrangler Technical Forum 8 03-15-2007 10:46 PM
longer cables for MM winch snakehunter TJ Wrangler Technical Forum 3 12-30-2006 07:02 PM
