How do you release the fuel pressure at the fuel rail on a 2005 4.0? - JeepForum.com
post #1 of 8 Old 11-13-2010, 09:11 PM Thread Starter
msully
I am installing a Savvy gas tank skid and the instructions say to release the fuel pressure. On my 05 I am not seeing the schrader valve on the fuel rail like the earlier models. What is the trick?
msully is offline
post #2 of 8 Old 11-13-2010, 09:16 PM
Nick_Knipp
1986 MJ Comanche
dang i forgot this part, i know theres a line somewhere in the engine that u can twist off and release pressure. ill check on this
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
post #3 of 8 Old 11-13-2010, 09:16 PM
DevilDogDoc
Pull the fuel pump fuse,start it it will quit after a bit.
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #4 of 8 Old 11-13-2010, 10:05 PM
pdangerp
pdangerp's Avatar
The fuel pump relay or fuse should be pulled and start it 'til it runs out of gas.
pdangerp is offline
post #5 of 8 Old 11-13-2010, 10:17 PM
DevilDogDoc
I'm confused isn't that what I just said?
post #6 of 8 Old 11-13-2010, 10:28 PM
pcoplin
If there's no valve, I would just pull the fuel line connector with a few shop towels around it. It doesn't release very much.
Odd that there isn't one though...
FullStack MotorSports
pcoplin is offline
post #7 of 8 Old 11-13-2010, 11:21 PM Thread Starter
msully
Thanks guys, I ended up just pulling the line and putting a rag around it. A fair amount of fuel came out initially but stopped pretty queick.
msully is offline
post #8 of 8 Old 11-14-2010, 12:11 PM
pdangerp
pdangerp's Avatar
Yes. I was trying to agree with you and it came out funny.
pdangerp is offline
High fuel pressure at the fuel rail ChiroSean YJ Wrangler Technical Forum 5 12-17-2008 01:02 PM
Fuel Pressure release, 06 Rubicon? Howitzer TJ Wrangler Technical Forum 4 12-30-2007 09:43 PM
Is this an acceptable way to release fuel pressure? jon_gilbart YJ Wrangler Technical Forum 9 12-16-2007 05:59 PM
Fuel pressure release Im Rebel TJ Wrangler Technical Forum 7 08-20-2005 08:37 AM
Fuel Pump !!! No Pressure at Fuel Rail!!! turfman* YJ Wrangler Technical Forum 2 11-18-2002 10:26 PM
