How do you know whitch one is bad, Master Cylinder or Slave Cylinder? - JeepForum.com
post #1 of 20 Old 07-31-2008, 11:13 AM Thread Starter
Morgan_TJ
97 TJ, my clutch will not disengage when you push it to the floor. the pedal still has some resistance when you push it down but you can feel it still trying to pull. Does this sound like I am on the right track with the master or slave cylinder or could this be something else? I don't see any leaks around the master or the slave and i don't seem to be losing any fluid from the master reservoir.
Morgan_TJ is offline
post #2 of 20 Old 07-31-2008, 11:31 AM
ArrizX
1997 XJ Cherokee
Well dont quote me on this but the clutch works off the brake master right? So, if your brakes still work with out pumping them up then my process of elimination the slave cylinder has to be it.
That or something else, but i'm not sure what it could be. Very possibly a bad throw out bearing inside the tranny. Kinda an important little bugger.
ArrizX is offline
post #3 of 20 Old 07-31-2008, 12:13 PM
kloppk
Originally Posted by ArrizX View Post
Well dont quote me on this but the clutch works off the brake master right? ...
Negative.
They are completely seperate systems.
The problem is likely a bad clutch master cylinder or possibly a bad throwout bearing.
kloppk is offline
post #4 of 20 Old 07-31-2008, 12:21 PM
Bill_Dunnigan
brakes have nothing to do with the clutch
2005 LJ Rubicon - 6 Speed - Modded
2004 TJ X - 5 Speed - Modded - Long Gone & Missed!
1999 TJ Sahara - Auto - Long Gone!
2008 KK - Wife's Grocery Getter!
Bill_Dunnigan is offline
post #5 of 20 Old 07-31-2008, 12:36 PM
Bill_Dunnigan
i replaced my slave cylinder with a bimba pnuematic cylinder and 5.1 DOT brake fluid, this fixed my issues just fine and cheap too
post #6 of 20 Old 07-31-2008, 12:37 PM
ArrizX
1997 XJ Cherokee
Originally Posted by kloppk View Post
Negative.
oh, sorry.
ArrizX is offline
post #7 of 20 Old 07-31-2008, 01:26 PM Thread Starter
Morgan_TJ
Is there a way to tell which one is bad or is it going to be a trial and error process to see which one is bad?
post #8 of 20 Old 07-31-2008, 01:44 PM
Jim Miller
On my '91 YJ I had the same problem. The shop had to replace the Master and Slave cylinders because a seal was breaking apart in the Master and small pieces were lodged in the Slave and in the lines. If it turns out that you find any trash in either cylinder (tiny pieces of rubber seal) - be sure to flush-out the line between the two cylinders as well. Or - you will get to do this all over again in about a week.
Jim Miller is offline
post #9 of 20 Old 07-31-2008, 01:56 PM Thread Starter
Morgan_TJ
Thanks, I was hoping i could get away with only replacing one or the other and not both.
post #10 of 20 Old 07-31-2008, 02:46 PM
VICTIM_OF_PAIN
VICTIM_OF_PAIN's Avatar
In my 2001 the master and slave were one unit, it was called the hydraulic assembly. Not sure if that helps.
Ex - 2001 Wrangler, 2" BB, 32" BGF AT's. JKS Quicker Disconnects, Oil Pan Skid, Steering Box Skid. Hard Top, Soft Top, Safari Top, Olympic Mountaineer Rack.
Current - 2008 Unlimited Wrangler Rubicon. Rock Krawler Stock Mod 2.5" lift, 35x12.50x15 Cooper STT's on Pro-Comp D-Windows, Husky Floor Liners, Mastercraft Grab Handles, Weathertech Side Window Deflectors, Hitch mounted D-Ring, Rancho Oil Pan Skid, Rugged Ridge E-Disco Skid, and a Skid Row Evap Canister Skid plate.
It is better to keep one's mouth shut and be thought a fool.... than to open it and remove all doubt.
VICTIM_OF_PAIN is offline
post #11 of 20 Old 07-31-2008, 02:52 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Have you tried bleeding the system?
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #12 of 20 Old 07-31-2008, 03:01 PM Thread Starter
Morgan_TJ
No, I haven't. do you think that could be the problem? If so the there has to be a reason that air is getting into the system i guess.
post #13 of 20 Old 07-31-2008, 03:17 PM
IslandTJ
Hopefully it's as easy as replacing the slave. If the slave isn't defective, the issue may be a failure in your clutch fork/throwout bearing.
Now Jeeping in Oregon
IslandTJ is offline
post #14 of 20 Old 07-31-2008, 11:46 PM
bigchevyman24
bigchevyman24's Avatar
I had the exact same problem...push the clutch to the floor and it will not let loose of the gear/engine. Does the clutch not want to come back up? I would push the clutch all the way down and not be able to get into a gear or out of a gear. Replace the slave and be done with it. Pretty simple process. If it was the throwout bearing, most likely the clutch wouldn't move at all. About a $50 fix...
CURRENT: 2001 WJ V8 LIMITED - Quadratrac, 60th anniversary, Fat Bob's 2.5/2 lift, HID's, roof rack, 31" Rugged Terrains, 5k lb Curt Hitch
SOLD: 2000 WJ 2WD CONVERTED TO 4X4, 97 TJ ON 35'S, 95 XJ ON 33'S
bigchevyman24 is offline
post #15 of 20 Old 08-01-2008, 09:23 AM Thread Starter
Morgan_TJ
I think i will start there. Hopefully that will be all there is to it. What was the best way to bleed the system when i get the slave installed?
how to tell if your master or slave cylinder is bad vball1socr4 YJ Wrangler Technical Forum 7 03-06-2012 10:34 PM
Slave/Master Cylinder Fluid T.Maxwell YJ Wrangler Technical Forum 4 09-11-2009 09:17 AM
Replacing the Slave Cylinder - master too? Duncan71 YJ Wrangler Technical Forum 13 07-28-2008 02:23 PM
Master or slave cylinder? jazzplr YJ Wrangler Technical Forum 2 04-07-2007 11:46 PM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 09:37 AM
