How do you know if you have a cracked exhaust manifold? - JeepForum.com
post #1 of 8 Old 10-23-2003, 10:16 AM Thread Starter
wrangler2002
Except for the wierd noise I here at high RPMs, can I do a visual check. Do I have to remove the intake manifold to get a complete view?
wrangler2002 is offline
post #2 of 8 Old 10-23-2003, 10:40 AM
RockPaws
RockPaws's Avatar
Normally you can see the cracks (if their is one) with a good flash light and maybe a mirror. I find most of the cracks around the collector (where the 2 pipes come together above the flange at the bottom of the header). It will crack around the welds. Also check around the rear 5 and 6 cylinder tubes. Some will aslo crack at the bellows (if installed) off cylinder 1-2.
It's best to view from the drivers side and or under side of the engine.
With some cracks, the sound is more apparent when cold then when hot. This is due to heat expansion.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 8 Old 10-23-2003, 10:59 AM Thread Starter
wrangler2002
Thanks. .
post #4 of 8 Old 10-24-2003, 12:13 AM
RckyMtnTJ
When mine went I noticed the noise.. When I looked under the Jeep (under where your feet are when driving) I fount where the two collectors combine to become one, I could see black soot where the crack was.. Here's a pic:
98 TJ with some stuff
RckyMtnTJ is offline
post #5 of 8 Old 10-24-2003, 04:16 PM
SniperFire
It may be hard to notice especially if you run mud and the headers are caked. One trick to spot a leak is to go out at night and start it up and look in the vicinity that RckyMtnTJ posted in the diagram with a flashlight.
Here's the real deal so you can kinda see what you are looking for:
Regards,
SniperFire
http://www.darksiderz.co.uk
SniperFire is offline
post #6 of 8 Old 10-31-2003, 07:59 AM Thread Starter
wrangler2002
Regards,
SniperFire
I don't get it, I don't see any cracks.
post #7 of 8 Old 10-31-2003, 10:52 AM
SniperFire
Maybe you oughta take two flashlights
post #8 of 8 Old 11-04-2003, 08:27 AM Thread Starter
wrangler2002
good point, maybe i should use two flashlights
My exhaust manifold is cracked czjeeper YJ Wrangler Technical Forum 15 05-07-2009 10:21 AM
Cracked NEW exhaust manifold Nonya TJ Wrangler Technical Forum 18 06-28-2008 07:20 PM
Cracked Exhaust Manifold BS fcknmaw TJ Wrangler Technical Forum 17 09-02-2006 08:56 AM
cracked exhaust manifold eep3 TJ Wrangler Technical Forum 20 04-04-2005 06:12 AM
Cracked exhaust manifold Anthen27 TJ Wrangler Technical Forum 15 10-21-2004 04:04 PM
