Quantcast How do you clean the engine and engine bay - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How do you clean the engine and engine bay
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 05-03-2009, 05:19 PM   #1
Yadster101
Washed and waxed my TJ today and every once in a while i just get a damp rag and clean the engine but that isnt very effective. Is it a smart idea to just get some simple green and hose down everything under the hood?
Yadster101 is offline   Reply With Quote
Old 05-03-2009, 05:21 PM   #2
zachbh
Engine degreaser really helps. Cover the electric stuff and the air intake and spray it down with the hose, or pressure washer.
2003 Inca Gold TJ
http://www.jeepforum.com/forum/f22/inca-gold-tj-build-thread-821298/
Looking to buy a kayak near Fort Collins, CO. PM me.
zachbh is offline   Reply With Quote
Old 05-03-2009, 05:29 PM   #3
2jhanna
at home, you can use simple green or 409 in a spary bottle on a luke warm engine. let it set for 5-10 minutes.then hose it all down, like said above cover air intake.
or at self service car wash. the one i use has a tire cleaner (green stuff) setting, wet everything down, let it set. then i use the presoak setting which is hot soapy water at medium pressure. then rinse. i also do the entire front end and undercarrage the same way. couple of bucks every time i change the oil. gets the oil from the filter change off.
have done it this way to all my vehicles, and i have been driving for 39 years.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote
Old 05-03-2009, 06:21 PM   #4
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Cover intake and pressure wash it.Those do it yourself car washes you won't have to worry about that high of pressure,cause they don't have it.Your electrical will be fine just use common sense when spraying?
GOLENJEEPTJ is offline   Reply With Quote
Old 05-03-2009, 06:23 PM   #5
JohnyPro
JohnyPro's Avatar
As long as you keep your engine running, you dont need to worry about covering your alternator, just don't aim in the air intake and you should be ok. I've used a pressure washer before with good success
CT Jeep Member #19
Yellow Jeep Member # 104
LJ Owners Group Member # 140
PMA: Positive Mental Attitude
- It's what reminds you as you're stuck in the mud, that at least you're stuck in the mud and not in an office cubicle!
God is great, Beer is good, an' people are crazy!
DEVILDG03
This is my Jeep. There are many like it, but this one is mine.
JohnyPro is offline   Reply With Quote
Old 05-03-2009, 06:27 PM   #6
rmb2485
I take mine to the self car wash which has an engine degreaser setting. Cover the air intake, wet everything down, spray the degreaser then rinse it off.
Before...
After...
rmb2485 is offline   Reply With Quote
Old 05-03-2009, 07:54 PM   #7
BlueFlame
Engine degreaser doesnt' do much unless it's ... greasy or oily.
I've never tried to 'clean' and engine (wouldn't even consider wiping it with rag!) but when pressure washing mud off after a trail run I lift the hood and blast the mud off. Don't see the need for more, certainly not a 'detailed' engine.
BlueFlame is offline   Reply With Quote
Old 05-03-2009, 08:01 PM   #8
SB99TJ
Simple Green and a power washer is the answer. One Gallon Jug of Simple Green from Home Depot or Lowes, a $3.00 spray bottle and simply mix 1/3 simple green to water. Use a 75% mixture if you have a lot of grease, up to 100% if you need a putty knife to get the grease off.
Spray down the entire engine, soak it good...it will take the entire spray bottle...They spray it with the power washer. In 20 years, I have never covered anything in the engine bay and nothing has ever happened as a result. Just don't spray down the intake...that's it. The Alternator will be fine.
Spray the underside of the hood, under the frame, the wheel wells...etc. Engine degreaser works worse than simple green, and it can damage the finish of your paint and aluminum metals. Simple Green is enviornmentally friendly and degreases better than any degreaser i have ever used when used in combination with a pressure washer. It also won't damage your finish.
2008 Black Rubicon Unlimited, fully loaded, Auto
AEV Premium Lift with High Steer
35x12.5/R17 Goodyear MTR Tires
AEV Argent Pintlers
AEV front bumper with Superwinch EPI9000
SB99TJ is offline   Reply With Quote
Old 05-03-2009, 08:10 PM   #9
Bishop Creek
Thumbs up on Simple Green!
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.”
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline   Reply With Quote
Old 05-03-2009, 08:13 PM   #10
lumpster
lumpster's Avatar
ive had pretty good luck with "greased lightning".
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Old 05-03-2009, 08:18 PM   #11
Yadster101
this is great advice i think im just going to cover the alternator and intake with plastic bag over it and just spray down with simple green and then hose off. I was just curious because although my engine bay is never really dirty its never cleanly detailed either and i was just wondering how some guys get this area to be so clean. thnkx for the advice
Old 05-03-2009, 10:49 PM   #12
fried_gold
Don't forget to remove whatever you use to cover the intake before driving off. For some reason, my Jeeps always wants to run funky when I forget that. Silly jeeps and their air-needing engines.
Amen. I've found the bright, almost neon, green tire cleaner is the best thing to clean dried mud off a Jeep. It will clean things that I've been trying unsuccessfully to clean for months.
fried_gold is offline   Reply With Quote
Old 05-03-2009, 11:31 PM   #13
TJ311
I worked for a shop long ago where the owner always wanted the engine near spotless before he touched it. I think he maybe had a grease phobia or something. He always had me use a kerosene (I believe) pressure washer that heated the water to hose down the engines. It worked like I charm and I never covered anything either. Again, use common sense.
I can't say my engine is always clean but I do like it almost spotless from time to time. It makes it easier to work on and can help it run cooler if there isn't an inch of grease or mud on it.
TJ311 is offline   Reply With Quote
Old 05-05-2009, 08:33 AM   #14
SECorBust
Wow, Kerosene, now that's environmentally friendly and good for the paint.
SECorBust is offline   Reply With Quote
Old 05-05-2009, 08:41 AM   #15
NotURMailman
Straight Up Fool!
NotURMailman's Avatar
He meant that the burner in the washer used Kerosene to heat the water, not wahing with Kerosene...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfuction or uninstall themselves at any time.
NotURMailman is offline   Reply With Quote
Glock Forum
