how do lockers work? - JeepForum.com
post #1 of 22 Old 01-27-2009, 10:23 AM Thread Starter
jeepin1122
I am thinking about getting gears and a locker/ lockers for my 97 TJ. It is a 4 cyl. and I will be running 33's. What gear and locker set up should I run? I have read that some just run a locker in the front diff. How does that work? How will it handle on the street with just a front diff locker?
jeepin1122 is offline
post #2 of 22 Old 01-27-2009, 10:26 AM
TJSport01
http://www.jeepforum.com/forum/f27/why-do-i-need-locker-i-thought-i-had-4x4-242949/
search first
Build Thread:
2001 Jeep TJ, 1in JKS Body Lift, 35x12.50x15in Goodyear Mtr's and a RE 4.5 SF with AA sye, tom woods custom cv drive shaft, tnt tube fenders w/3in flares and flush mounted led turn signals, 1in mml, cobra cb and firestik, custom rock sliders, herced, trail scars
Looking for 4.88s (R&P) for a d44/d30 PM me
TJSport01 is offline
post #3 of 22 Old 01-27-2009, 10:34 AM Thread Starter
jeepin1122
Did search, but didnt see that one.... Thanks!
What about gearing for my set up? what would you recommend?
post #4 of 22 Old 01-27-2009, 10:39 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You can install a front locker without it affecting your steering on the street in 2wd at all, they only lock up hard when you're in 4x4. Good front lockers include the No-Slip, Aussie, and Lockright. The Aussie and Lockright will, at most click a bit during turns when you're in 2wd, the No-Slip (about $100 more) won't even do that... it's virtually silent and undetectable in 2wd.
Don't lock your rear axle, it's a Dana 35c and it's not strong enough for a locker.
For 33" tires, your 2.5L engine, and a 5-speed manual transmission, regear to 4.88... do NOT go to 4.56 which would only be correct for the 4.0L engine. 4.88 is ideal for your rig and 33" tires.
Jerry Bransford is offline
post #5 of 22 Old 01-27-2009, 11:12 AM Thread Starter
jeepin1122
thank you very much!
post #6 of 22 Old 01-27-2009, 11:15 AM Thread Starter
jeepin1122
Where is the best (cheapest) place to buy gears and lockers on the internet?
post #7 of 22 Old 01-27-2009, 11:19 AM
Jerry Bransford
Administrator
Don't buy the gears over the internet, have the installer provide them. Just know what you can buy them for on the internet and then negotiate with the installer for a reasonable discount on the parts to get the price a little closer. Most installers will discount the parts to get the labor $$$.
If you provided the parts to the installer and something went wrong during or after the installation, which DOES happen, he'd just blame the parts you provided and you'd have to take care of replacing the parts and paying him again to reinstall them. If the installer provides the parts, his warranty will cover everything, parts and labor. There's a lot of peace of mind you'll gain with that.
post #8 of 22 Old 01-27-2009, 11:19 AM
silverjeep
I just installed my Aussie Locker this last weekend. No problems on road in 2wd. Some clicking and ratcheting. Nothing big though. I do feel a slight difference in the steering. It feels more firm. Could just be me though. I got mine at northridge4x4.com $269 free shipping and no tax. They shipped the same day.
Jeep parts and accessories
silverjeep is offline
post #9 of 22 Old 01-27-2009, 12:16 PM
ram1500dodge
Im gonna hi-jack the thread for a second....I DD my rig, welding up the front is not a good idea correct? that would affect the steering am I correct on this?
Steve
Originally Posted by The Mean Fish View Post
......If hooking up some suspected terrorist's nads to a car battery yields a .001 % chance that we get a tiny bit of information that might save 1 American life I couldn't care less, red is positive and black is negative......
ram1500dodge is offline
post #10 of 22 Old 01-27-2009, 12:19 PM
Jerry Bransford
Administrator
That is correct, welding the front spider gears to make what is known as a "Lincoln Locker" would make steerng on the street extremely difficult. And there in Georgia where the roads can ice up, you'd hate it. Don't do it.
post #11 of 22 Old 01-27-2009, 12:19 PM Thread Starter
jeepin1122
that would be correct.... welded gears are the same as a solid spool.... there is never any give...... wouldnt want to do that to a daily driver
post #12 of 22 Old 01-27-2009, 12:24 PM Thread Starter
jeepin1122
I went to look at lockers and gears online..... some of them say that they only fit a carrier higher or lower that a certain gear ratio..... how do I know if I fall into that category without tearing it apart to check?
post #13 of 22 Old 01-27-2009, 12:52 PM
Jerry Bransford
Administrator
Your 2.5L TJ came with 4.10 gearing so you won't need new carriers for a lower ratio like 4.88. Read post #7 above thoroughly though, I don't advise buying your own gears if you are not going to install them yourself which shouldn't be done unless you know what you're doing with R&P installations.
post #14 of 22 Old 01-27-2009, 12:53 PM
TJSport01
jerry saves the day...yet again, i also have an aussie in the front best 250ish ive ever spent
Build Thread:
post #15 of 22 Old 01-27-2009, 12:58 PM Thread Starter
jeepin1122
I do plan on installing myself.... I am a do-it-yourselfer.... I cant see paying somebody else that kind of money to do something when it could be spent on more jeep parts ya know. I appriciate you help and info. I have installed gears and spools into toyota axels, and also into a chevy 12 bolt.... im guessing that jeep axels are prolly more like doing the chevy axel being that there is not a pumpkin to remove and work on......?
why dont my lockers work.. electrical problem 03rubiconMG TJ Wrangler Technical Forum 2 03-15-2009 08:13 PM
Air lockers - explain how they work roadbosstx TJ Wrangler Technical Forum 3 01-12-2009 08:51 AM
getting rubi lockers to work in a non-rubi got_4_lo TJ Wrangler Technical Forum 1 06-10-2006 05:25 AM
Rubicon lockers, why do they work how they do? Blackbart TJ Wrangler Technical Forum 20 01-08-2006 02:24 PM
Lockers in front, lockers in back biffstephens TJ Wrangler Technical Forum 30 12-04-2004 02:45 PM
