How do i test stock lockers - JeepForum.com
post #1 of 18 Old 01-17-2012, 08:31 PM Thread Starter
Jeeperjake30
Ok here it goes my buddy has a tj rubicon he bought from a guy thinking every thing was there / worked. We went to go flip on his lockers and nothing so we crawled under the jeep (u could practicly walk under this thing) and we found that the po removed the air compressor tuding. So how do i test the locker ? What ammount of psi do i pump in the axle
Jeeperjake30 is offline
post #2 of 18 Old 01-17-2012, 09:05 PM
wushaw
Rockin jeep
wushaw's Avatar
Jack up a tire and put no more than "5 PSI" into the locker. You will need to get a low pressure regulator to achieve this. After you put pressure to it see if you can rotate the lifted tire.
wushaw is offline
post #3 of 18 Old 01-17-2012, 09:05 PM
dmgiff
Someone else will answer, I'm just getting it going for you.... Seems like I read somewhere it is very low pressure. Like 6-8 psi or something.
dmgiff is offline
post #4 of 18 Old 01-17-2012, 09:10 PM Thread Starter
Jeeperjake30
Constant pressure?
post #5 of 18 Old 01-17-2012, 09:14 PM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by Jeeperjake30 View Post
Constant pressure?
If you want it to stay locked. Air pressure locks it and keeps it there till pressure is gone.
wushaw is offline
post #6 of 18 Old 01-17-2012, 09:16 PM Thread Starter
Jeeperjake30
Ok now another question since this jeep had the hoses taken off the axles and its been pen is there risk of it getting ruined from lets say water
post #7 of 18 Old 01-17-2012, 09:18 PM
wushaw
Rockin jeep
wushaw's Avatar
Yup. Leaving that open is not good.
wushaw is offline
post #8 of 18 Old 01-17-2012, 09:19 PM Thread Starter
Jeeperjake30
And there hasnt been hoses on the jeep for the past 5 years i was a show rig, i have a jk rubicon thank god my axles are electronic
post #9 of 18 Old 01-17-2012, 09:19 PM
hustler905
Two questions:
Where is the tubing disconnected? At the pump, or at the diff, or perhaps totally gone?
Is it in 4-Low?
hustler905 is offline
post #10 of 18 Old 01-17-2012, 09:22 PM Thread Starter
Jeeperjake30
Totaly gone no pump nothing
post #11 of 18 Old 01-17-2012, 09:23 PM Thread Starter
Jeeperjake30
There isnt really 4wd at this moment the po put 5.13 in rear and left 4.10 in front so he had to take drive shaft off
post #12 of 18 Old 01-17-2012, 09:38 PM
hustler905
Wow - sounds like that's a mess.
4Low is needed to activate the lockers, unless it's been modified. Whether or not there is a front drive shaft does not matter, the harness needs to see the shifter in 4Low before the pumps will activate (if they were there to begin with).
post #13 of 18 Old 01-17-2012, 09:40 PM Thread Starter
Jeeperjake30
Originally Posted by hustler905 View Post
wow - sounds like that's a mess.
4low is needed to activate the lockers, unless it's been modified. Whether or not there is a front drive shaft does not matter, the harness needs to see the shifter in 4low before the pumps will activate (if they were there to begin with).
whel that should not matter since notinh is there correct???
post #14 of 18 Old 01-17-2012, 09:43 PM Thread Starter
Jeeperjake30
Does any one have a part number for the rubicon air pump
post #15 of 18 Old 01-17-2012, 11:33 PM
wushaw
Rockin jeep
wushaw's Avatar
wushaw is offline
lockers
lockers in stock Dana 35 platym TJ Wrangler Technical Forum 10 10-09-2011 08:11 PM
lockers on stock axles? nickstix YJ Wrangler Technical Forum 10 05-09-2010 04:38 PM
Rubicon Stock Lockers??? XJ Rocker TJ Wrangler Technical Forum 3 06-02-2008 10:32 AM
Stock Lockers Ares YJ Wrangler Technical Forum 5 06-24-2006 12:54 PM
87 YJ 4.2 stock - no spark - can I test ECU? m-keith YJ Wrangler Technical Forum 9 03-30-2004 12:47 PM
