How do I separate the a/c lines? - JeepForum.com
post #1 of 12 Old 07-09-2010, 04:38 PM Thread Starter
MattJeep
2003 WJ
Anyone know how to seperate the a/c lines on the TJ? I've got the "tools" but they just look like something to help you grab the line. Do I just pull? Theres no freon in the system so I don't need to take it anywhere to be recovered, just trying to seperate a line to replace the o-ring. My freon sniffer was going off near a connection. Trying to get my a/c working. Thanks.
1997 TJ Sport
MattJeep is offline
post #2 of 12 Old 07-09-2010, 04:45 PM
wushaw
Rockin jeep
wushaw's Avatar
Ya slide the tool up into it and wiggle & pull.
wushaw is offline
post #3 of 12 Old 07-09-2010, 04:58 PM
ScreamSalvation
There is a groove on the tool that slides in the back. Use the right size tool and give it a little push into the groove on the line and pull. Sometimes the lines come off easy as can be, other times it takes forever to get them
to "pop".
ScreamSalvation is offline
post #4 of 12 Old 07-09-2010, 05:05 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
For fuel & A/C lines with quick connects.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 12 Old 07-09-2010, 09:27 PM Thread Starter
MattJeep
2003 WJ
Hey thanks, I finally got it. Jeepair.com had a pretty sweet set of pictures detailing how it works too. I replaced the two O-rings in there and charged it back up. Blows cold like usual, just still think its leaking out. I had it at a local shop to see if they could find the leak. They couldn't and decided its a leak in the evaporator. But there was no uv in the water dripping out either. So I took my father-in-law's freon sniffer and stuck it in the vents, even in the drip hose exit coming out the firewall, nothing. But it keeps going off near the passenger side front, near where the two lines enter the condenser i think. Thats why I changed the o-rings in the line coming from the compressor. We'll see, if it still blows cold tomorrow, that'd be an improvement. Its usually gone within several hours.
MattJeep is offline
post #6 of 12 Old 07-10-2010, 02:42 PM Thread Starter
MattJeep
2003 WJ
Yup. All gone. I can't believe it leaks out that fast and theres no sign of where its exiting.
MattJeep is offline
post #7 of 12 Old 07-10-2010, 03:09 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Did you use freon with leak detector dye? If so & it doesn't appear to have dye around any fittings or seals, you know already what the answer is:
Evaporator core.
Might as well replace the heater core while it's apart.......
Max
Mean Max is offline
post #8 of 12 Old 07-10-2010, 03:20 PM
maddiver
Matt - I'm in the same boat. This week I replaced the Condenser, Compressor, Accumulator, liquid line w/orifice tube. All that and it turns out a leak in my evap. Yuck.
So, now at the end of the month (payday) I gotta take the whole dashboard off, replace the evap core AND since the system is getting opened AGAIN gotta replace the accumulator again too. ARRRGGGGGH.
Good luck with yours, I'm done for a few weeks.
maddiver is offline
post #9 of 12 Old 07-10-2010, 03:42 PM Thread Starter
MattJeep
2003 WJ
Ya but like I said, I don't have any clues that point to the evaporator. Not that I want it to be the evaporator thats bad, but no dye in the drip water, and no sniffing freon from the vents while air is on (and while theres still freon in the system). I'd just hate to tear the whole dash apart and find the evap is fine. Not that this jeep is in pristine condition, I can imagine it being corroded. What and where do they usually go bad? I've never seen a picture of a bad one. I really wanna fix it, being teased by cold air coming out when its charged makes it hard to let it go.
Maddiver: how did you surmise that the evap was where your leak was?
MattJeep is offline
post #10 of 12 Old 07-10-2010, 04:53 PM
maddiver
Well - I haven't COMPLETELY ruled that it is the evap but with EVERYTHING else replaced - it's the only thing left that it could be.
Seriously, we couldn't sniff any leaks anywhere either - BUT - at one point right after filling my detector went off on the passenger side floor as well. Then, 4 days later I had the level checked. Initially they put in 1.25 lbs as required. When we checked it there was only .85 in there. Sooooo.
Then, this morning I was looking over the whole underside of the jeep and to my amazement there was a drip of leak check/pag oil on the drip line.
That was enough for me. Everything I've read, heard, seen, says that a leak in the Evap is the most prevalent but also the hardest to diagnose. Since everything else has been replaced I'm gonna bite the bullet and replace it too.
maddiver is offline
post #11 of 12 Old 07-10-2010, 04:54 PM
wushaw
Rockin jeep
wushaw's Avatar
I know you don't have to do this but if you lay your windshield down it helps with the top bolts & cover. I just put mine back together a few weeks ago for a roll bar install, it's not hard just takes time.
wushaw is offline
post #12 of 12 Old 07-11-2010, 06:01 AM Thread Starter
MattJeep
2003 WJ
Yay. Oh well better just order an evaporator We've got another 3 months it can still be hot so. Plus I wanna wheel with the air on! lol.
MattJeep is offline
ac , a/c , freon , lines
Do I have to have a separate switch for aftermarket fog lights? bgaeta84 TJ Wrangler Technical Forum 4 03-02-2009 11:22 PM
Powerplant or Separate systems Sgalway JK Wrangler Technical Forum 3 02-15-2009 11:53 AM
I think we should start a separate post for 4-Doors Rhino64 Wrangler General Discussion 26 07-10-2008 03:45 PM
Separate Tranny and TC when replacing clutch? Poppy360 TJ Wrangler Technical Forum 1 04-18-2006 06:05 AM
Do you reuse the same drain container or have separate ones? Johnny World YJ Wrangler Technical Forum 15 03-24-2006 07:17 AM
