Quantcast How do I replace a rear axle seal on Dana 44? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How do I replace a rear axle seal on Dana 44?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 03-31-2009, 03:35 PM   #1
Mino
I noticed a small amount of fluid leaking from my rear passenger side drum the other day and initially thought it was brake fluid. Well there's no brake fluid loss from the master cylinder so I'm guessing a leaky axle seal is the problem. How would I go about changing this seal? I believe I read that there is a bearing on the shaft that would require special tools to remove. I also believe I read that there is an inner and outer axle seal on the shafts. Is this something I could do with regular tools? I'm no mechanic but I did install my lift and SYE kit amongst other things. Thanks.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline   Reply With Quote
Old 03-31-2009, 03:38 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Here you go... http://www.stu-offroad.com/axle/d44/d44-1.htm
When replacing the seal, you'll need to replace the bearing too. No real special tools are needed other than the bearings and bearing retainer will need to be pressed on using a shop press which any machine shop can do for you.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-31-2009, 09:44 PM   #3
mudb8
want it rite or rite now?
mudb8's Avatar
you may only need to put a bead of silicone around the seal, the bearing and seal amount to around 40 bucks, each side.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 04-03-2009, 10:51 PM   #4
Mino
Thanks for the response guys. I'm really thinking I can do this job myself and save myself the labor costs.
'05 Jeep Wrangler X
Old 04-03-2009, 10:55 PM   #5
thejafe
It's a piece of cake, really. For me the hardest part was removing the brake rotor . Damn thing just wouldn't budge.
In regards to having the bearing / seal / retainer pressed on... my local truck supply shop did it for under $30.
Visit My Homepage!
thejafe is offline   Reply With Quote
Old 05-17-2009, 09:42 PM   #6
huskerjeeper
just to clarify my front passenger side axle shaft has developed a trickle of fluid onto the hub assembly to correct this issue i'll need to replace the seals inner and outer correct?
the seal in the diff housing and the one at the end of the axle tube left and right sides or just leaky side?
huskerjeeper is offline   Reply With Quote
Old 05-17-2009, 09:46 PM   #7
mudb8
mudb8's Avatar
the front has inner seals only.. you get to pull the axles and carrier to change those ones... the outers are dust boots.
Old 05-17-2009, 09:55 PM   #8
huskerjeeper
good i can leave the bearings as they are then
Good news less work = Happier camper
Old 05-18-2009, 12:18 AM   #9
mudb8
mudb8's Avatar
lol, not quite.. if you have a front axle seal leaking, thats about the most work you could possibly have to go through to change a seal..
Old 10-08-2010, 11:04 AM   #10
ItsaFinRubicon
Maresca
ItsaFinRubicon's Avatar
so if i bought superior axle seals from quadratec (quadratec.com link).... i sill need another out seal or inner seal?
2004 Jeep Rubicon :: |R.C. 4"|PSC|Smittybilt|35" KM1|QTec|R.C.|
Originally Posted by Dtowngoalie View Post
rausch frock rauschhhhhhhhhhhh
Originally Posted by ajamison View Post
trails frock trailssssss!
ItsaFinRubicon is offline   Reply With Quote
Old 10-08-2010, 11:21 AM   #11
solarpower
the front only has seals that are inner..or located at the housing.
Those superior "seals" are to keep stuff from getting in your axle tubes and mount at the ends of your tubes.
They are not really axle seals.
78 CJ5
04 TJ "U" package
06 XK Commaddy
Jeep mods do not fix poor driving or stupidity.
solarpower is offline   Reply With Quote
Old 08-10-2011, 06:02 AM   #12
Sampson104
Guys, any idea of approx labor time for rear axle seals at a dealer, 03 TJ?
Thanks in advance...
Sampson104 is offline   Reply With Quote
Old 08-10-2011, 11:55 AM   #13
Robert J. yates
Originally Posted by mudb8 View Post
you may only need to put a bead of silicone around the seal....
This. Its an easy driveway fix that can be done in an hour or less without any special tools or the need to pull and replace a perfectly good bearing. We use RTV around all of these seals now... its actually a pretty common problem.
I think you should forego any further forays into researching lift and suspension parts and just throw your credit card at Rough Country.
Robert J. yates is offline   Reply With Quote
Old 08-11-2011, 12:03 PM   #14
Sampson104
So you recommend cleaning the outer seal area from residual oils and RTV the immediate area? Will these contain the leak for awhile or is this a permanent fix that should be good for year(s)?
The reason I ask is I had the rearend rebuilt, new bearings seals etc... from a local guy who cut me a deal and I think he did the job without cutting corners but this drip is not a huge issue but if I can plug it Id rather go this route rather than make a big deal out of it...
Thanks agiain for your time
Old 10-09-2011, 04:06 PM   #15
ram03
98 Wrangler wheel seal leak
I have a 98 wrangler and the driver side wheel seal is wet and the same wheel smells after awhile of driving. Can someone help by telling me how to fix it and what is involved if i have to replace the seal?
I see someone said they use RTV on there seals so I was wondering what it is? I also seen someone say about silicone on the seal and how long does this last and is it the silicone you by from Lowes in a calk tube and doe you still have to replace the seal.
Please help me and thank you for your time.
ram03 is offline   Reply With Quote
Glock Forum
