How do I replace my rear shocks! - JeepForum.com
post #1 of 13 Old 05-07-2009, 01:42 PM Thread Starter
j2roch
Have never done this before! Trying to save money and do myself. Not sure where to start! Looks like 2 bolts per side though. Can anyone guide me through the process of replacing the rear shocks on my 2001 TJ.
Thanks,
Jf
j2roch is offline
post #2 of 13 Old 05-07-2009, 01:48 PM
Dravintoad
Dravintoad's Avatar
One bolt through the axle (bottom)on each side, and two bolts (top), per side, on either side of the gas tank.
Spray some PB blaster on the bolts and let em soak before you try to remove them
Nothing to see here.
Move along.
Dravintoad is offline
post #3 of 13 Old 05-07-2009, 01:49 PM
jeepn012
Unbolt top and bottom, insert new shocks, reinstall bolts. Easy-squeazy. Hardest part is pushing the bracket through the bushings. A large vice will be your friend, but it can be done without one.
If you don't already have one, now is a good time to invest in a long 3/8" extension for your ratchet to reach the top bolts.
Have fun!
jeepn012 is offline
post #4 of 13 Old 05-07-2009, 01:49 PM
lumpster
lumpster's Avatar
the shocks attach with one bolt at the bottom, and 2 at the top. jack up the frame of the jeep and support it so you have a little more room under there. you dont have to remove the wheels, and you dont have to have the tires off the ground.
unbolt the bottom bolt, get a long extention and remove the top two bolts, put them back that way they came out.
it should take 10 minutes tops.
my bilstein's already had the "bracket" in them. the "bracket" is called a barpin.
lumpster is offline
post #5 of 13 Old 05-07-2009, 01:50 PM
CCJ
I use search. It really helps get those bolts loose.
CCJ is offline
post #6 of 13 Old 05-07-2009, 01:51 PM
Mayfair_Jeeper
Mayfair_Jeeper's Avatar
spray the top bolts every day for 2 weeks with PB blaster. You will need a LONG extension and I think it was a 1/2 inch socket to get them out. I used my impact wrench to get them out. Not easy and lots or them break off in there. I figured the inpact wrench would slowly work it out by applying quick burst of torque instead of constant pressure. I could be wrong though and just got lucky : ).
2006 Jeep TJ X Modded with toys
2008 Jeep Liberty Sport Stock
1987 Cherokee 4.0 Renix...Build in Process
Mayfair_Jeeper is offline
post #7 of 13 Old 05-07-2009, 03:08 PM
MikeBK
You have an 8 year old Jeep, and you live in the north east, expect to use heat on the upper bolts, if not you will most likely be wasting alot of time drilling and tapping, ask me how I know. After the first nightmare, I bought a cheap Benzomatic torch, now they come right out.
Consider Obama the lesson many in this country need to learn, the rest of us just have to pay for it!
MikeBK is offline
post #8 of 13 Old 05-07-2009, 03:12 PM
silverjeep
i used soap to get the bracket through the bushing.
Jeep parts and accessories
silverjeep is offline
post #9 of 13 Old 05-07-2009, 03:14 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Takes 20 minutes if nothing snaps up top.PB blaster for 2 days if you have a Jeep older than 5 years.Here's the basics.XJ,TJ same problems.
http://jeephorizons.com/tech/xjshock.html
TheBoogieman is offline
post #10 of 13 Old 05-07-2009, 04:12 PM Thread Starter
j2roch
Hey guys,
thanks for all the advice. Used WD-40. Let soak for 30 minutes. No problems getting the bolts out. Took about 45 minutes total. Jeep has only been in the NE for 4 years. 5 years on the West Coast. Probably explains how easy the bolts came out. Also, put anti-seize grease on threads when inserting bolts back on.
Once again, thanks everyone!
Jf
j2roch is offline
post #11 of 13 Old 05-07-2009, 04:32 PM
BlackBellamy
BlackBellamy's Avatar
Don't use WD-40. If you're going to be wrenching on your Jeep from now on buy a couple of cans of PB Blaster.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #12 of 13 Old 05-07-2009, 08:42 PM
BoatCop
I did mine last a few weeks ago. 2001 with the original shocks. No WD-40. No PB Blaster. Bolts came out like butter.
I love having desert vehicles.
Alan
2001 Wrangler TJ
2009 Chevy Tahoe
2007 Ford Expedition (Work Truck)
1999 Fleetwood Southwind 34' MH
BoatCop is offline
post #13 of 13 Old 05-07-2009, 08:59 PM
ductape1000
ductape1000's Avatar
dry weather makes me feel like a spoiled rotten little brat!!
wrenching is much easier without all that underbody rust stuff.
The only thing I know is ... I know nothing!!
Insert clever saying by someone well known here...
ductape1000 is offline
Replace shocks or not keithert TJ Wrangler Technical Forum 16 04-08-2008 10:56 PM
when to replace shocks? ScottJ83 TJ Wrangler Technical Forum 1 07-05-2007 08:54 AM
Should I replace the front or rear shocks first? abnormal TJ Wrangler Technical Forum 1 02-22-2007 12:50 AM
how to replace shocks? berniebesnard TJ Wrangler Technical Forum 5 05-13-2002 09:45 PM
hoe to replace shocks? berniebesnard TJ Wrangler Technical Forum 1 05-11-2002 05:33 AM
