How do I remove my TJ's Shifter Knob? - JeepForum.com
post #1 of 25 Old 03-20-2006, 11:52 AM Thread Starter
Modfatha
1991 MJ Comanche
Ok, I must fess up here! I want to put a gimmickly stainless steel skull shifter knob on my 2002 TJ. I cant seem to figure out how to get my factory knob off though... has anyone done this before? How to I get that sucka off?
Thanks!
Modfatha is offline
post #2 of 25 Old 03-20-2006, 11:56 AM
engus
It should just unscrew
engus is offline
post #3 of 25 Old 03-20-2006, 12:01 PM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
If it is a stick shift you need to pop the shift position chart piece off the knob with a small flathead screw driver. Then you can see the bolt that needs to come off.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top. Classic4x4 tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
AtoZ Where Zach makes me toys!
Stu-Offroad, because I don't have a clue, but Stu does!
cheesycook is offline
post #4 of 25 Old 03-20-2006, 12:04 PM
Jeepin' Rock Cl
Pop the legend off with a small screwdriver, remove 15mm nut, unscrew.
Jeepin' Rock Cl is offline
post #5 of 25 Old 03-20-2006, 12:08 PM Thread Starter
Modfatha
1991 MJ Comanche
Got it, thanks... so if I replace this shifter knob would I need another that uses that 15mm nut or can I just use any that thread onto the rod?
Modfatha is offline
post #6 of 25 Old 03-20-2006, 12:10 PM
cheesycook
cheesycook's Avatar
Anything that threads onto the rod or something with a plastic sleeve and tightening screws. koolknobs.com has some sweet stuff cheap.
Hermiston, ORL
post #7 of 25 Old 03-20-2006, 12:39 PM
rugger81
rugger81's Avatar
i would think you can't just use any old thread, you pretty much are limited to the 15mm. I took mine off without popping off the center diagram. I just twisted the thing off, and it came off pretty easy. Its really easy to make a shift knob out of anything. My uncle helped me make a pool ball into one for my jeep. Just drill a hole, thread it with a tap and bam you're done.
02 wrangler X
jeep + new to me house =
d35 3.07 gears with 31in AT tires
5sp
the jeep
rugger81 is offline
post #8 of 25 Old 03-20-2006, 01:06 PM
sickboy98tj
my TJ shift knob just unscrews. I want to get an 8-ball shift knob at some point
'98 TJ-"Stomper": LOCKED, LOADED, LONG ARMED. Rock Krawler, Warn, and ARB equipped.
'06 Dodge Charger Daytona- Go Mango! 3680/4000
BLEED TEAL.
sickboy98tj is offline
post #9 of 25 Old 03-20-2006, 01:47 PM
Jgw50
Ski pole handles work great!
Jgw50 is offline
post #10 of 25 Old 03-20-2006, 02:28 PM Thread Starter
Modfatha
1991 MJ Comanche
Modfatha is offline
post #11 of 25 Old 07-09-2010, 05:37 AM
ArmyPT
Just put on a custom knob myself. If you take a very thin flathead screwdriver you can pop off the gear shifter cap by placing it between the "1" and "2" side of the cap. There is a small gap where the screw driver head can fit under to pop it up. Also, for my 2005 TJ the nut under the cap is 15mm but the shifter thread itself is a 3/8" x 16 course thread. Weird that they mixed metric with standard on the same piece of harware.
Hope this helps,
Army
Black 2005 TJ Rubicon, 4" lift, 33" x 12.5" Mickey Thompson MTZ's on MT Classic Lock II's
ArmyPT is offline
post #12 of 25 Old 07-09-2010, 05:46 AM
Cuder
The shifter thread is M10 X 1.5, pretty close to 3/8 X 16.
Cuder is offline
post #13 of 25 Old 07-09-2010, 06:00 AM
ArmyPT
Wow, you are right they are very close. I would go with the metric then, M10 x 1.5.
Thanks cuder.
ArmyPT is offline
post #14 of 25 Old 07-09-2010, 06:22 AM
RiponredTJ
Happy Member No. 1
RiponredTJ's Avatar
Yup. M10 x 1.5 is correct. For a pool ball shifter, just drill a hole and epoxy the nut from the stock knob in there.
This City is what it is because our citizens are what they are.
RiponredTJ is offline
post #15 of 25 Old 02-10-2011, 11:17 PM
cotyallen
Epoxy the old nut into it! that is GENIUS. Haha, i'm about to do a grenade and the hold in the bottom was too big.... couldn't figure out how to tap it lol. WOW i feel dumb. Thanks for the tip!
cotyallen is offline
how to remove shifter knob??? PITBULL1967 TJ Wrangler Technical Forum 23 12-03-2012 10:39 PM
How can I remove the stock 2007 JK manual Trans Shifter knob?? crabmonk JK Wrangler Technical Forum 15 07-19-2010 09:19 AM
Hurst style shifter knob for NSG 370 (6 speed for TJ's/LJ's) WILLY348 Wrangler General Discussion 5 12-20-2009 10:53 AM
Yj Shifter knob echoduckjr. YJ Wrangler Technical Forum 6 03-04-2007 07:20 AM
how do i remove shifter knob bigdog67 TJ Wrangler Technical Forum 4 03-25-2004 08:01 PM
