How do I get a smoother ride on my DD?? - Page 4 - JeepForum.com
post #46 of 47 Old 12-13-2012, 11:59 AM
Trailthumper
You should check all bushings starting with the front steering components. Check the front and rear sway bar bushings, the front and rear track bar bushings and tie rod ends. I worked on my suspension for a few months researching and changing out bad parts. I would start replacing the worn out parts first than work on the rest.
I was having alt of body roll and the jeep just drove and handled like crap, I changed the shocks replaced suspension bushing that where bad and it rides like a new jeep now.
Trailthumper is offline
post #47 of 47 Old 12-13-2012, 12:07 PM
PyroXian
Pretty sure in the 2 years 9 months since the last reply the OP has either solved the problem or moved on...
I wish I had enough money to drive stupid.
PyroXian is offline
ride , shocks , smoother , suspension
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 10:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 07:27 AM
Looking for a smoother ride.... Airborne4X4 TJ Wrangler Technical Forum 6 12-30-2006 08:31 AM
Need Smoother Ride GA TJ TJ Wrangler Technical Forum 16 11-09-2006 02:47 AM
need a smoother ride rogasm TJ Wrangler Technical Forum 11 08-21-2004 06:08 PM
