How do I get a smoother ride on my DD?? - Page 2 - JeepForum.com
post #16 of 47 Old 03-27-2010, 05:20 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Originally Posted by GOLENJEEPTJ View Post
So what did you lower your tire pressure too after the chalk test?
Again.... what is your pressure now, cold?
GOLENJEEPTJ is offline
post #17 of 47 Old 03-27-2010, 05:22 PM
06rubicon
2017 JK Wrangler
17" rims and low profile tires are adding to the harsh ride for sure!
06rubicon is offline
post #18 of 47 Old 03-27-2010, 05:26 PM
nitecop
Just what vehicle are you comparing your jeeps ride to? Jeeps may seem "primitive'' to many magizine writers, but I think most of them are out to lunch. Especially those from Comsumer reports.
Not every one wants a RAV-4 or a CR-V.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #19 of 47 Old 03-27-2010, 05:30 PM
counselor
I think he said now it's 34. Still too high.
edit: Actually now though that I think about it he's probably running car tires with really soft sidewalls, so maybe not.
counselor is offline
post #20 of 47 Old 03-27-2010, 05:31 PM
Gary2
If its a soft highway ride you are after I would find a place that sells OE type springs or buy a used set of low mileage OE springs from some one on the forums for next to nothing if you want no lift and a set of Sensatrac shocks . I have used Old Man Emu for years and it has never rode as soft as a completely stock TJ does on the highway. I only run 28 psi in a 12.50 x35/15 you could go with 29-30 I am sure .
Gary2 is offline
post #21 of 47 Old 03-27-2010, 05:35 PM
Gary2
it just sunk in also a 17" wheel with a tire only 29.5" tall is not something that you will get a soft ride out of that sounds like a tire for a ricer . the height is ok if it was on a smaller wheel likea 15" that way you would have a little more sidewall flex .
Gary2 is offline
post #22 of 47 Old 03-27-2010, 05:40 PM
asknight
34 is STILL too high. Though we find out he isn't nearly as stock as originally posted. He's running 29.5" tires on 17" wheels.
asknight is offline
post #23 of 47 Old 03-27-2010, 05:42 PM
GOLENJEEPTJ
This is why I stated his rim diameter!It will definitely change the shock absorption.I prefer a higher profile sidewall of rubber myself.Especially on a dinky tire and rim like that.You got no KOOOOOSH!
post #24 of 47 Old 03-27-2010, 05:49 PM
blubaru2002
lower the psi even more. change your shocks because they are probably dead. change your rim/tire combo.
Originally Posted by Patrick Bateman
I have to return some video tapes.
blubaru2002 is offline
post #25 of 47 Old 03-27-2010, 05:51 PM
kyle_craig
Bump down the air pressure to 30. Can't hurt anything to run em at 30. If the ride is still rough consider upgrading your shock absorbers. They really do make a big difference. If you ran a smaller wheel and a tire with more sideway that would help too. My last vehicle has 18s and a lower profile tire, it didn't ride worth *****.
kyle_craig is offline
post #26 of 47 Old 03-27-2010, 05:57 PM Thread Starter
dougiefresh131
alright so my tires definitely do not help. yes i have 17"s. 245/65. i will look more into the tire pressure deal. tires out of the picture, will replacing shocks/springs help my ride quality? or will it be minimal at best?
dougiefresh131 is offline
post #27 of 47 Old 03-27-2010, 05:58 PM
jerseyjeep22
check the load rating on the tire...a tire with a rating of E has thicker sidewalls etc. causing a harsher ride. I think C is more of a passenger car rating. you can look it up but definitly check your tires
jerseyjeep22 is offline
post #28 of 47 Old 03-27-2010, 06:12 PM
Gary2
Not knowing the condition of your existing shocks and springs , how old , what they are ,any answer is a guess >
Gary2 is offline
post #29 of 47 Old 03-27-2010, 06:16 PM
wushaw
Rockin jeep
wushaw's Avatar
15" tires would be best. If you go to a 35" tire with the 17" rims then you would be ok but you would have to change more than shocks.
wushaw is offline
post #30 of 47 Old 03-27-2010, 06:58 PM Thread Starter
dougiefresh131
shocks and springs, to the best of my knowledge, are stock. its an 01, so 9 years old. 127k miles on it.
ride , shocks , smoother , suspension
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 11:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 08:27 AM
Looking for a smoother ride.... Airborne4X4 TJ Wrangler Technical Forum 6 12-30-2006 09:31 AM
Need Smoother Ride GA TJ TJ Wrangler Technical Forum 16 11-09-2006 03:47 AM
need a smoother ride rogasm TJ Wrangler Technical Forum 11 08-21-2004 07:08 PM
