How do I get a smoother ride on my DD?? - JeepForum.com
post #1 of 47 Old 03-27-2010, 02:06 PM Thread Starter
dougiefresh131
I have a 01 TJ, and the ride quality is terrible. Every little bump and it feels like I hit the biggest speedbump in the world. The suspension is all stock, and there is no lift kit etc installed. This is my DD, so I have my tires at 38 psi. I've read some threads and they all say lower your psi, but I still need to get the best mileage possible. So, what can I do to make my ride better? Shocks/springs. What brand is best etc. I don't wheel it and I don't really plan on it in the near future, so this would just be for an on road ride. Thanks
dougiefresh131 is offline
post #2 of 47 Old 03-27-2010, 02:10 PM
Pillswoj
Then put up with the crap ride and uneven tire wear. If you jeep is stock then the recommended pressure is on the door jamb, use it.
Friends don't let Friends run Bosch
Pillswoj is offline
post #3 of 47 Old 03-27-2010, 02:38 PM
BlueFlame
BlueFlame's Avatar
Raising your tire pressure TOO high won't necessarily get you any better mileage. Above a certain psi, more doesn't help. BUT - it can kill you. Do a bit of Googling about tire air pressure and overinflation, see what can happen when a tire is run overinflated at highway speeds. 38 probably isn't that bad, but still...
Aside from that,
Are you still on the stock shocks? They are probably long gone.
Have your springs sagged? You may be hitting the bump stops.
If you want a little lift (lets face it, even if never offroad, it will look better) a small coil lift and good shocks can improve ride considerably. I believe there are 2" coil lifts out there - OME perhaps?
BlueFlame is offline
post #4 of 47 Old 03-27-2010, 03:48 PM
wushaw
Rockin jeep
wushaw's Avatar
If your looking for better mileage then you may want to buy something that gets good mileage to begin with otherwise lower tha air pressure for a better ride.
wushaw is offline
post #5 of 47 Old 03-27-2010, 03:57 PM Thread Starter
dougiefresh131
i just lowered the air pressure by using the chalk method. so air pressure is out of the question. shocks/springs?
post #6 of 47 Old 03-27-2010, 04:07 PM
jake-cutter
Have you ever replaced the shocks or coils? How about the body bushing mounts? Might want to start there. Also how are your seats, has the cushion flattened out?
jake-cutter is offline
post #7 of 47 Old 03-27-2010, 04:08 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
So what did you lower your tire pressure too after the chalk test?
GOLENJEEPTJ is offline
post #8 of 47 Old 03-27-2010, 04:08 PM
Imped
Imped's Avatar
A stock jeep rides pretty darn good as long as everything's in good shape. Perhaps your point of view is a bit flawed. Go ride in a YJ then reevaluate.
OlllllllO
IndyORV
Imped is online now
post #9 of 47 Old 03-27-2010, 04:09 PM
Gary2
we don't know the mileage so I will say just maybe your shocks are finished. A stock TJ when new rides pretty soft from what I remember . I can't think of a reason to have 38psi in a TJ's tires .If you have stock tires do what the door sticker says or slightly less. If the person who told you to put 38psi in your tires told you to do anything else undo it .
Gary2 is offline
post #10 of 47 Old 03-27-2010, 04:10 PM Thread Starter
dougiefresh131
i bought it about a month ago so it's still relatively new to me. i know the ride can be better so I posted this. i have not replaced anything. the driver seat is decent. the passenger seat cushion is like new. it's not to the point yet where i'm almost sitting on nothing. i'd rather replace physical components first and then seats etc.
post #11 of 47 Old 03-27-2010, 04:15 PM
asknight
Well what did you lower the air pressure to? The number on the door jamb is 33psi. You'll be safe at 30psi and getting a better ride.
Edit: And it won't make a bit of difference in your fuel economy going down to 30.
asknight is offline
post #12 of 47 Old 03-27-2010, 04:17 PM Thread Starter
dougiefresh131
34.
i've ridden in other jeeps so I can compare it to something.
it has 127,000 miles on it. i do not have stock tires. slightly bigger at 29.5". and they are brand new.
post #13 of 47 Old 03-27-2010, 04:18 PM
GOLENJEEPTJ
He's got 17" rims????
post #14 of 47 Old 03-27-2010, 04:18 PM
freeskier93
If you want good gas milage while still getting a good ride then picked the worst car possible as you DD... Yeah Jeeps might have good rides stock and/or new, but nothing good ever lasts forever.
freeskier93 is offline
post #15 of 47 Old 03-27-2010, 04:20 PM
silver60th
OME shocks and springs will give you a remarkably better ride. Your control arms have a good bit to do with the ride as well...I know on XJ's we can use WJ control arms, which have an oval bushing. They make the ride smoother.
Other than that, lower your tire pressure (which you said you already did). Make sure you're not hitting your bumpstops. Also, something else not mentioned...what size rim are you using? The higher the rim diameter, the less tire you have to absorb the road with. A 15 or 16 in. rim would be your best bet.
silver60th is offline
ride , shocks , smoother , suspension
Smoother ride Thug Nasty TJ Wrangler Technical Forum 9 10-02-2011 10:29 AM
Smoother ride? 91whiteYJ YJ Wrangler Technical Forum 5 11-27-2007 07:27 AM
Looking for a smoother ride.... Airborne4X4 TJ Wrangler Technical Forum 6 12-30-2006 08:31 AM
Need Smoother Ride GA TJ TJ Wrangler Technical Forum 16 11-09-2006 02:47 AM
need a smoother ride rogasm TJ Wrangler Technical Forum 11 08-21-2004 06:08 PM
