How do I get to the flasher relay? - JeepForum.com
post #1 of 17 Old 09-27-2006, 05:07 PM Thread Starter
zband
zband's Avatar
Put in some LED tail lights and figured I would pick up a EP-26 flasher. So here I am LEDS are in but I cant for love of all that's holy gain access to the flasher, which is apparently on the top of the steering column. The sides of the upper steering column cover come loose but the part that is behind the steering wheel does not budge. is there a screw that I need to loosen ? a technique (pull up then back- wait I tried that)
How do I get to it?
zband is offline
post #2 of 17 Old 09-27-2006, 05:09 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Position yourself head-down in the footwell and start it clicking, you'll be able to spot it once you locate its clicking. I've replaced mine without removing anything.
Jerry Bransford is online now
post #3 of 17 Old 09-27-2006, 05:21 PM
Rocky529
Rocky529's Avatar
On 2003+ TJs (it could be 2001+, not sure on the exact change over date), the flasher relay is actually on top of the steering column. You are going to have to remove the two phillips screws on the bottom, and then the steering column snaps apart. The prongs actually face towards you, so you are going to have to pull it out towards the windshield. It is on the right side, on top of the steering column.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 17 Old 09-27-2006, 06:48 PM Thread Starter
zband
zband's Avatar
Thanks - that was the problem - 2 screws ! By the way if anyone does the LED tail light conversion the flasher is EP-26 and make sure that it says "LED" on the relay. It is a 4 prong that replaces the factory 5 prong. Not sure why the replacement is only 4 prong but every works flashers and hazards. I'll post some pics
zband is offline
post #5 of 17 Old 09-27-2006, 07:23 PM
Rocky529
Rocky529's Avatar
Indeed, that is what I have. Just be aware it will still work when the key is removed.
Rocky529 is offline
post #6 of 17 Old 09-27-2006, 09:36 PM
Stu Olson
Stu Olson's Avatar
By the way, the EP-26 flasher is NOT a replacement unit for your year TJ, which is why it is a 4 pin unit vs. a 5 pin unit. The EP-26 is for early model TJs.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #7 of 17 Old 09-27-2006, 10:30 PM
05fulltraction
05fulltraction's Avatar
relay
I must ask, what is the correct relay for an 05' and where can i get one? i have leds and i just got used to them blinking onnoyyingly fast! thanks Aa ron
05fulltraction is offline
post #8 of 17 Old 09-28-2006, 07:54 PM
Stu Olson
Stu Olson's Avatar
I am not aware of a drop-in replacement flasher for the newer TJs.
Users either modify their existing flasher or go with the fast flashing rate.
Details on modifying your own are at:
http://www.stu-offroad.com/electrical/led1/led-4.htm
Stu Olson
ARB Locked & Loaded
post #9 of 17 Old 09-28-2006, 08:04 PM
Rocky529
Rocky529's Avatar
I have an '04 TJ and use the EP26 flasher relay that says LED on it with no problems.
Rocky529 is offline
post #10 of 17 Old 10-01-2006, 05:39 PM
EaglesSJ
EaglesSJ's Avatar
Where did you get the EP-26 at? Also do I just ask for the EP-26 flasher?
EaglesSJ is offline
post #11 of 17 Old 10-01-2006, 06:15 PM
Rocky529
Rocky529's Avatar
I got it at AutoZone. Make sure it says LED on it.
Rocky529 is offline
post #12 of 17 Old 10-01-2006, 06:35 PM
EaglesSJ
EaglesSJ's Avatar
So they will know what I am talking about if I say "give me a EP-26 flasher relay" or is it out on the main floor somewhere with the fuses and stuff.
EaglesSJ is offline
post #13 of 17 Old 10-01-2006, 06:37 PM
Rocky529
Rocky529's Avatar
It's on the main floor.
Rocky529 is offline
post #14 of 17 Old 10-02-2006, 08:10 AM
EaglesSJ
EaglesSJ's Avatar
I found it but it doesnt say LED on top so can I just cut that small trace off of the circuit board like in older TJs or what? I went to NAPA, Autozone, and Advance and all of them said they couldnt get the LED model. Somebody please help.
EaglesSJ is offline
post #15 of 17 Old 10-02-2006, 07:56 PM
EaglesSJ
EaglesSJ's Avatar
this one blinks way to fast, any ideas?
EaglesSJ is offline
flasher relay bad? 99heeptj TJ Wrangler Technical Forum 15 12-04-2009 11:36 AM
Flasher relay that works with LED?? RedMountainYJ YJ Wrangler Technical Forum 8 11-07-2007 06:52 PM
Flasher Relay? 2000TJwrangler TJ Wrangler Technical Forum 14 10-29-2007 10:31 PM
Where is the flasher relay? ROUGHSHOD TJ Wrangler Technical Forum 3 10-28-2006 02:35 PM
Relay for flasher Harry Hood TJ Wrangler Technical Forum 2 03-03-2006 03:35 PM
