How do I get the dash covering off my 03? - JeepForum.com
post #1 of 5 Old 12-19-2008, 04:52 PM Thread Starter
PearlJam1003
I didn't get a whole lot of help putting this in the electrical section, so please don't move this.
How do I get the molding off around my radio and a/c and heat dials and whatnot? I need to get to the harness behind the radio and can't figure out how to get it off. On my 98 Cherokee, it was so easy to just pop it off and with the TJ, it feels like I'm going to snap the plastic.
Any help?
PearlJam1003 is offline
post #2 of 5 Old 12-19-2008, 05:18 PM
RVA_TJ06
The top bezel that runs from one side of the windshield to the other side pops up.. there should be 2 phillips screws on top of that and then it should pull forward.
Finally paid off...
RVA_TJ06 is offline
post #3 of 5 Old 12-19-2008, 06:15 PM Thread Starter
PearlJam1003
Alright I got the plastic covering off, but when I try to pull the radio out, there's a good amount of resistance. Should I just pull harder or is there a reason there's some good resistance?
post #4 of 5 Old 12-19-2008, 07:21 PM
US1
Reach behind your glove compartment and feel for the back of the radio. There is a mount bolted to your radio back to support the radio. Remove the 1 nut, then slide'r out.
US1 is offline
post #5 of 5 Old 12-19-2008, 07:50 PM
muskegonjohn
On my '98 Wrangler you need to take the ash tray out and remove the screw holding the center console onto the dashboard. There are also holes on the top of the center console that are visible if you pop off the plastic piece closest to the windshield (VIN is visible in hole in this piece) but the holes were empty (no screws) in mine. Maybe my jeep was a Monday or Friday production truck and that guy was on vacation.
muskegonjohn is offline
Soundbar Covering twhditto TJ Wrangler Technical Forum 5 08-01-2007 09:52 PM
Floor Covering OBK TJ Wrangler Technical Forum 2 04-24-2007 12:50 PM
Covering Air Vent mance YJ Wrangler Technical Forum 5 09-27-2005 04:28 PM
Covering up those Dings Optik45 TJ Wrangler Technical Forum 2 08-20-2004 08:02 AM
floor covering Dembones YJ Wrangler Technical Forum 19 01-08-2003 08:24 PM
