How a differential works - Page 2 - JeepForum.com
post #16 of 23 Old 01-27-2011, 03:11 PM
MO2500
I know you have the answers to these questions but I'll try and play a long and will most likely learn something I did not know
I have a question. Can you mesh a pinion gear into a reverse cut ring gear without reversing the rotational direction the gear teeth spiral around the pinion gear head?
I'm struggling to picture the gears meshing without having a ring and pinion in front of me. However, I believe (and I know I could very well be wrong) that you may be able to mesh a standard cut pinion gear into a reverse cut ring gear if you flip the ring gear over to the other side of the pinion. This would however, change the direction that the ring gear rotates.
Thinking about it more this might make the coast side of the pinion mesh with the drive side of the ring gear so I guess they really wouldn't mesh correctly.
Please, enlighten me if you could. I'm curious now
Can you think of a way to run a low pinion gear set in a high pinion application and still run hypoid gears?
Possibly a flipped low pinion axle running portals that reverse the rotation of the hub. Modifications to the oiling passages and such to keep the pinion bearings alive.
That or run flipped axles with a drivetrain setup that reverses the direction the driveshafts are rotating. Like rear engine buggies and using FWD engines that spin the opposite direction. This I know little about.
What distinguishes the drive from the coast side on a ring gear?
The drive side of a tooth on the ring gear is more vertical and therefor more efficient at transferring the forces as the teeth of the pinion and ring gear mesh. Greater percentage of the force applied goes into rotating the ring gear.
The coast side of the tooth is more angled and therefor there is a significant force vector perpendicular to the direction of rotation that makes the ring and pinion want to push away from each other (ofcoarse, using the example of a low pinion D30 in front application while driving forward). With enough force, the housing will deflect, the teeth on the pinion gear will ride up to the thinner potion at the top of the ring gear tooth and the tooth will fail.
Instagram: @omsmike
MO2500 is offline
post #17 of 23 Old 01-27-2011, 10:02 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You missed the key part which was the reason they are called reverse rotation is the rotation of the direction the teeth spiral around the pinion is reversed from a standard gear set. No, the teeth do not mesh between the two.
What if you extended the pinion to the back of the ring and pinion and turned it from there?
Yep, the coast side is ramped and tries to push the pinion away from the ring gear under load. When the pinion tooth walks out high enough to push on the thinner top edge, you break teeth off or crack them at the root of the tooth.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #18 of 23 Old 01-28-2011, 06:06 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Perhaps this is sticky worthy
Whybu1 is offline
post #19 of 23 Old 01-28-2011, 08:20 AM
MO2500
Ahh, I see. So "reverse rotation" is a correct term for the gear set. I feel that it is easier to call them "reverse cut" for the simple reason of not confusing people. "reverse rotation" makes some believe that they in some way changes the direction of rotation of the ring and pinion gear which is not correct. It only changes the direction the teeth are cut around the pinion and ring gear
I suppose that would have the same reversing effect. Do you have an example of an axle like this or is this just an idea that would, in theory, work?
Instagram: @omsmike
MO2500 is offline
post #20 of 23 Old 01-28-2011, 08:29 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Reverse cut and reverse rotation are both correct and like you, I've chastised many a folk over what I thought was a misnomer until I had someone who owns a large axle company hand my butt back to me.
I think there is a Corvette axle like that, but I've never looked it up.
I am Savvy
post #21 of 23 Old 01-28-2011, 01:03 PM
My01Sahara
This is very worthy of Sticky classification. Would be nice if there were a bit of info to include after the video regarding how lockers tie this together (automatic and manual).
My01Sahara is offline
post #22 of 23 Old 02-07-2011, 01:17 AM
btn
I would like to know how this scenario would work:
You take a LP front diff, but instead of having forward torque applied to the coast side (angled side) of the gearset teeth, you flip flop the gear pitch angles on the ring and pinion so that the gears would mesh on the "drive" side whilst torquing forward? That way you could have a LP front but without the R and P pushing eachother apart whilst driving forward.
Another idea is to have symmetrical pitch angles on both sides of the gear teeth so that they would be just as strong in forward or reverse directions?
I am sure there is some reason why this wouldn't work, but I don't have any hands-on experience.
btn is offline
post #23 of 23 Old 02-07-2011, 07:38 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not sure why you think you want a low pinion front, but you can do it the way you describe. It's done the other way all the time with low pinion axles to make them hi pinion. They simply flip them upside down and then run the motor the other way. As in the engine points backwards.
It wouldn't be a hypoid gear then, it would be more like a spur and pinion gear and would make a lot of noise.
I am Savvy
4H works but 4L doesn't djfred YJ Wrangler Technical Forum 8 12-13-2010 09:06 PM
what works best? gamble3527 TJ Wrangler Technical Forum 3 09-23-2009 02:18 PM
Great Video, How a Differential Works impish123 TJ Wrangler Technical Forum 3 08-06-2009 08:15 PM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 12:38 PM
4wd 4H works but not 4L Jakesteads YJ Wrangler Technical Forum 5 06-21-2006 09:22 AM
