How a differential works - JeepForum.com
post #1 of 23 Old 01-26-2011, 09:46 AM Thread Starter
TJ_Jerry
This is the best explanation of how a differential works I have ever seen. And it is from the 1930's !
It has some cool motorcycle riding the first minute and a half but you can skip ahead to 1:45 and that is where the tutorial really begins.
No matter how smart you might feel that you are. Remember there once was a time your main goal was learning not to crap in your pants. True evolution is an awakening.
TJ_Jerry is offline
post #2 of 23 Old 01-26-2011, 09:59 AM
MO2500
This has been posted many times but it does provide a good basic understanding of how an open differential works
Instagram: @omsmike
MO2500 is offline
post #3 of 23 Old 01-26-2011, 10:08 AM
ajf1994
It even includes LP vs. HP! Too bad it doesn't include the strength bonus from a HP30.
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #4 of 23 Old 01-26-2011, 10:27 AM
Ric-san
Nice video..love the old scoots too...
Ric-san is offline
post #5 of 23 Old 01-26-2011, 12:32 PM
Jon-joN
thanks for the post, this was the first time ive seen a complete description and it really cleared up my mind
Jon-joN is offline
post #6 of 23 Old 01-26-2011, 12:51 PM
97_TJ_4L
Good explanation of a differential...I never knew that either. My uncle, who was one of the founding fathers of Mopar, tried to explain the concept of a differential to me one time and I had no clue what he was saying, but this really clears it up. Good vid!
97_TJ_4L is offline
post #7 of 23 Old 01-26-2011, 01:21 PM
tjtom
Dang that really cleared up my confusion
tjtom is offline
post #8 of 23 Old 01-26-2011, 03:00 PM
jeepbro's
awesome explanation of how spider gears work. That was the onlything i've never really figured out exactly how they worked on a diff.
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline
post #9 of 23 Old 01-26-2011, 03:16 PM
BriansCJ
1994 XJ Cherokee
I had an idea of how spiders worked but this makes it crystal clear now.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #10 of 23 Old 01-26-2011, 03:38 PM
Erik T.
Pew Pew Vroom Vroom!
Erik T.'s Avatar
So HP is when the driveshaft is high on the differential(More driveshaft clearance), and LP is when it's lowered... less clearance...
Right?
Atla.
- For those in the Trenches of Responsibility
Humorous, Witty, Slightly Obnoxious - Political and Social Commentary in a World Gone Mad.
New Post 10/16 -
Erik T. is offline
post #11 of 23 Old 01-26-2011, 04:03 PM
MO2500
Right?
Yes, basically. The pinion is above the centerline of the housing vs. being below it (which does raise the point where the driveshaft attaches, raising the driveshaft). The ring and pinion on a HP axle are reverse cut so that the pinion and ring gear mesh the same way at the top of the housing as they do in a LP axle. They are not "reverse rotation" as some incorrectly term them. Everything is rotating the same direction only cut differently which is why gears will not interchange between LP and HP axle housings.
A HP front axle is beneficial because the forces when in a forward gear are being placed on the "Drive side" of the ring and pinion gears which are designed to take the most load. With a LP axle, the forces in a forward gear are place on the "coast side" of the ring and pinion. This can cause more housing deflection and eventually gear failure if pushed too hard because the gears are actually trying to push each other apart due to the more angled faces of the gears.
A high pinion axle is strongest in the front and a low pinion axle is strongest in the rear. Keep in mind that this is when moving forward.
Instagram: @omsmike
MO2500 is offline
post #12 of 23 Old 01-26-2011, 08:05 PM
Erik T.
Erik T.'s Avatar
Excellent, now it makes sense!
Atla.
New Post 10/16 -
Erik T. is offline
post #13 of 23 Old 01-27-2011, 08:16 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Great video. Took me from "no idea how it works" to "that makes sense".
Whybu1 is offline
post #14 of 23 Old 01-27-2011, 10:42 AM Thread Starter
TJ_Jerry
It's and eye opener !!
TJ_Jerry is offline
post #15 of 23 Old 01-27-2011, 11:20 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have a question. Can you mesh a pinion gear into a reverse cut ring gear without reversing the rotational direction the gear teeth spiral around the pinion gear head?
Can you think of a way to run a low pinion gear set in a high pinion application and still run hypoid gears?
What distinguishes the drive from the coast side on a ring gear?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
4H works but 4L doesn't djfred YJ Wrangler Technical Forum 8 12-13-2010 10:06 PM
what works best? gamble3527 TJ Wrangler Technical Forum 3 09-23-2009 03:18 PM
Great Video, How a Differential Works impish123 TJ Wrangler Technical Forum 3 08-06-2009 09:15 PM
Limited Slip Rear Differential or Electronic Locking Rear Differential danw2 JK Wrangler Technical Forum 23 01-13-2008 01:38 PM
4wd 4H works but not 4L Jakesteads YJ Wrangler Technical Forum 5 06-21-2006 10:22 AM
