How To Determine If A REMOVED Steering Stabilizer Is Defective? (2003 Rubicon) - JeepForum.com
post #1 of 22 Old 08-25-2010, 07:04 PM Thread Starter
TJorDie
I am getting some intermittent death wobble. It usually appears @ 50 mph or when I hit some uneven pavement/bumps. It seems to be getting progressively worse. Stock Rubi, no mods. I search the intraweb and cant find any info about how you determine if a Steering Stabilizer is bad once it's removed ( I just took it off 1/2 hour ago). I can push it in & out without a lot of effort but it still has resistance. Should I have to use maximum force if it were good?
What say you Jeep experts??
'03 Rubicon. Inca Gold. Auto, Full Doors / OEM Hard & Soft Tops, All stock..... Hot Wife Mod
TJorDie is offline
post #2 of 22 Old 08-25-2010, 07:18 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
First, a bad steering stabilizer... even if completely blown out... is never the cause of Death Wobble.
Push-pull on your steering stabilizer, it should present an equal amount of very firm resistance in both directions. Being as it is hydraulic, it will stay put at whatever position you leave it at. It will not expand out on its own as gas-charged shocks do.
Jerry Bransford is offline
post #3 of 22 Old 08-25-2010, 08:19 PM
thel8one
is it leaking oil?
thel8one is offline
post #4 of 22 Old 08-25-2010, 09:33 PM
wpparker
You should have a fairly good amount of pressure in both directions. If you have over 50k or 60k on the rubi. then just replace it but that is not your death wabble issue.
wpparker is offline
post #5 of 22 Old 08-25-2010, 09:42 PM
bigtim6656
the guy who runs the auto shop at my college said it is likely the stabilzer causing my issue, but since the tires are bad he told me make sure goodyear checks everything when they balance it and that should tell me what is bad if anything.
bigtim6656 is offline
post #6 of 22 Old 08-25-2010, 09:59 PM
Gonewhln
You may want to check other items like a front end alignment, ball jointsm tie rod ends and anything that may be loose on the front end.
Gonewhln is offline
post #7 of 22 Old 08-25-2010, 10:09 PM
Jerry Bransford
Administrator
Originally Posted by bigtim6656 View Post
the guy who runs the auto shop at my college said it is likely the stabilzer causing my issue.
He is wrong about that. A stronger steering stabilizer can only temporarily mask Death Wobble symptoms but it is never the cure for the underlying root cause of the DW which is always caused by something else or a combination of problems.
post #8 of 22 Old 08-25-2010, 10:33 PM
bigtim6656
I figured as much, I do not think they deal with jeeps much, his thoughts where the stabilizer, tierod ends, trac bar but seem to think it was the stabilizer.
Hopefully when I have my new tires put on and it aligned they will know for sure, then if anything is wrong or busted the school can fix it for the cost of the parts
post #9 of 22 Old 08-26-2010, 06:51 PM
rmoonks
Just a FYI before you go throwing lots of money at parts, go get the front end aligned. That's what cured my death wobble. If you still have it after that, then you can start looking elsewhere. Good luck.
rmoonks is offline
post #10 of 22 Old 08-26-2010, 06:53 PM
g4x4xgeoff
get the front end aligned, look for loose bolts, and get your wheels balanced. 99% of DW falls into that area.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #11 of 22 Old 08-26-2010, 09:04 PM
Demp
Completely ignoring its at a college
You really have to drill your auto mechanics on their jeep intelligence. I had one tell me those "crossed bars" (Steering) were bent and needed replacing..... and i know otehrwise from greasing joints every so often
The fact he said the tires are bad but its the steering stabilizer, should make me think he has only a bare basic idea. You could technically run without a stabilizer but you might have to really fight those bumps.
Demp is offline
post #12 of 22 Old 08-27-2010, 01:07 AM
RogueSpear2023
It's not your steering stabilizer, I cracked mine and it didn't cause any death wobble. I have since replaced and like the new one better than stock, just does a better job, and the steering feels better. I would start looking for play in you steering set-up also make sure the alignment is good.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #13 of 22 Old 08-27-2010, 08:49 AM
-dirt-
OP - I just replaced the SS on my Rubi that has about 90k on it. Had the original stabilizer. I replaced it with a Monroe that looked exactly like the stock one.
The new stabilizer was very stiff to extend or compress. Really had to mean it. The old one has fairly easy to push or pull. Also, the stud that goes in the draglink was the same, so there was no need to remove the old one. Cut down on the time a bit.
Not going to dive to far into the DW comments (take most all of them with large grains of salt), but it is true that a SS cannot cause DW. But having a good, fresh one on there doesn't hurt anything either! With the exception that it might could inhibit the diagnosis of death wobble.
-dirt- is offline
post #14 of 22 Old 08-27-2010, 08:54 AM
pmccoy9876
When I had a death wobble problem, it was my ball joints. You can check that without spending any money. Jack up one side of the front end and see if there's any play in the wheel by trying to move it back and forth, pushing at the top and bottom. If there's play there, it's most likely your ball joints.
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
post #15 of 22 Old 08-29-2010, 04:17 PM
Hesher420
X2! I just cured my mini-DW (more of a shake/wobble really) problem with new ball joints. The push/pull trick on the tire was no help at all though. What finally showed where the play was, was sticking a pry bar inside the steering knuckle under the axle shaft and giving it a good downward push. this showed a good 1/16" of play in both ball joints the couldn't be felt in the push/pull tire test.
I know how much a pain tracking down DW can be, so, good luck
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
2003 -2006 Rubicon or post 2007 Rubicon WhatBump1 Wrangler General Discussion 5 06-08-2009 09:56 PM
Rough Country Stabilizer Defective? Hellbound13 JK Wrangler Technical Forum 2 02-20-2009 10:55 PM
rubicon? (2003 Rubi vs. 2003 Sport) Tom1 TJ Wrangler Technical Forum 10 09-08-2008 08:24 PM
Anyone Removed The Rubicon T-case Balancer? Manard TJ Wrangler Technical Forum 2 03-04-2008 10:32 PM
Rubicon Express Steering Stabilizer? moitura TJ Wrangler Technical Forum 2 08-24-2005 03:04 PM
