How to check if an axle housing is bent? - JeepForum.com
post #1 of 13 Old 09-06-2011, 07:38 AM Thread Starter
Erik T.
Erik T.'s Avatar
I found a HP D30 axle housing from a 92 XJ, with 3.73 gears, and good ball joints... for $50.
No shafts/unit bearings/brakes. (I'll be swapping mine over anyways)
But the seller says it may be bent.
Around here I can pick n' pull HP D30's for $100 all day long. There's 5 at the local yard right now. But I've yet to find anything other than 3.55. (So this 3.73 will save me from buying a new carrier for the regear).
How do I check it? Preferably with an easy method, that I can check when we meet instead of taking it to a mechanic/machinist to check.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #2 of 13 Old 09-06-2011, 07:45 AM
DivineKaos
I believe the proper method is on v-blocks.
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #3 of 13 Old 09-06-2011, 07:45 AM Thread Starter
Erik T.
Erik T.'s Avatar
V-Blocks? Can ya explain that a bit more?
-Erik.
Erik T. is offline
post #4 of 13 Old 09-06-2011, 04:25 PM Thread Starter
Erik T.
Erik T.'s Avatar
No other options besides the mysterious V Blocks?
-Erik.
Erik T. is offline
post #5 of 13 Old 09-06-2011, 04:33 PM
jpross
I too would like to know. Ive heard you can take the carrier out and run a string all the way through. Make sure the string is centered at each end and when you look inside the pumkin the string should be centered going into each axle tube as well if it is straight.
jpross is offline
post #6 of 13 Old 09-06-2011, 04:36 PM
little_Jeep
Use a straight edge, compare one side to the other. Also, look very closely at axle tube where they connect to pumpkin.... look at the joint for signs of new metal being exposed. You will need to look close. If seller says "maybe bent", I would assume they are bent until proven other wise.
little_Jeep is offline
post #7 of 13 Old 09-06-2011, 05:16 PM
99_TJ_Wyoming
"maybe bent" usualy means - 'Its bent, but you might not notice right away, it only chews up bearings every few months'
99_TJ_Wyoming is offline
post #8 of 13 Old 09-06-2011, 05:51 PM Thread Starter
Erik T.
Erik T.'s Avatar
That's sort of what I'm thinking. I had thought there was a method involving shining light on one end and looking down the tube.
-Erik.
Erik T. is offline
post #9 of 13 Old 09-06-2011, 06:04 PM
wushaw
Rockin jeep
wushaw's Avatar
A straight edge works.
wushaw is offline
post #10 of 13 Old 09-06-2011, 07:02 PM
dmgiff
Sitting here thinking about how you would do this.... I don't know how a straightedge would work... unless you remove the diff cover and carrier then have someone hold a long straightedge against the pumpkin on the machined surface. You could then check the straightedge against the height of the axle tube at several locations with another straightedge? You would have to rotate the axle housing and check all four sides maybe. And I don't know how you would check the other sides since you wouldn't be able to hold the straightedge against anything flat.
I'm sure someone else will come up with the method and I will look like an idiot for not figuring it out. I only went to high school, what can I say?
The string method sounds promising though I don't know how you would set it up. Maybe a couple jackstands at the perfect height on either side of the axle, then tie the string to the jack stands?
A modified V-block method would be to set the axle housing on two jack stands which would take the place of the v-blocks. Then take several measurements hopefully from a nice flat garage floor, to the axle tube in several locations. Rotate the axle housing so you get all four sides. Good luck.
dmgiff is offline
post #11 of 13 Old 09-06-2011, 07:15 PM
TJRUSSELL
four metal pucks and a steel rod. Two of the pucks to fit in place of the carrier bearings. The other two fit into the recess on the flanges where the bearings would mount. Next, the rod would be passed through all the pucks which would align the flanges perfectly
My 2.4 turbo TJ-6 stretch build
http://www.jeepforum.com/forum/f22/my-lil-2-4-tj-build-1092494
TJRUSSELL is offline
post #12 of 13 Old 09-06-2011, 07:20 PM
dmgiff
^^ OK, that's a good idea. Probably cost more to manufacture the pucks than one of the unbent $100 HP30's though....
dmgiff is offline
post #13 of 13 Old 09-06-2011, 07:21 PM
hatfield44
http://www.jeepforum.com/forum/f9/hp...43/index7.html
hatfield44 is offline
Easy way to identify a bent axle housing? Brazos609 TJ Wrangler Technical Forum 8 08-14-2011 01:44 PM
Help wanted with bent axle housing (AUSTRALIA) dragonman TJ Wrangler Technical Forum 4 01-23-2011 04:05 PM
Bent D44 Front Axle housing taftech TJ Wrangler Technical Forum 9 02-09-2010 10:53 AM
Bent Rubicon Axle Housing 514rem TJ Wrangler Technical Forum 3 03-16-2008 07:54 PM
Bent D30 Axle Housing...anyone else? Scafone TJ Wrangler Technical Forum 8 07-04-2006 07:31 PM
