How to change Rear shoes and emergency brake on a 2005 tj unlimited?? - JeepForum.com
post #1 of 8 Old 12-09-2009, 08:13 PM Thread Starter
brucey2003
It has a different setup, then what i'm used to.
brucey2003 is offline
post #2 of 8 Old 12-09-2009, 08:15 PM
Prryan45
Search function is your friend.
Prryan45 is offline
post #3 of 8 Old 12-09-2009, 08:16 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
It is pretty easy just take you time and do one side at a time and have the other side off so you can compare.
Take the rotor off and inspect. Are you really sure the ebrake shoes are bad? Unless you left the ebrake on while driving they should never have to be replaced.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #4 of 8 Old 12-10-2009, 12:18 AM
prd_cdn
prd_cdn's Avatar
Engines & Drivetrain
JeepForum.com - Search Forums
Google
Also fill your profile out dude.. it will help with the responses your going to get !!
prd_cdn is offline
post #5 of 8 Old 12-10-2009, 05:46 AM
BigRigoTJ
Rear shoe's and emergency brake pad's? You got one or the other not both.
Rear shoe's are your E-brake (parking brake) pad's as well.
If you got rear disc brakes then you might have seperate parking brake pad's in side the rotor unless you got the cable attatched to the caliper.
What do you have? Rear disc or drum?
BigRigoTJ is offline
post #6 of 8 Old 12-10-2009, 06:01 AM
Pillswoj
Its an LJ so it should be Rear disc's.
OP - I assume your e-brake is not holding? Most likely it needs adjustment. I am not sure how they adjust on an LJ but someone will chime in.
Friends don't let Friends run Bosch
Pillswoj is offline
post #7 of 8 Old 12-10-2009, 07:10 AM
geepguy99
This isn't for an LJ but should work...
Jeep Rear Drum Brake Remove - Install and Adjust
geepguy99 is offline
post #8 of 8 Old 12-10-2009, 07:27 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
The LJ's use a rear disc brake setup, which has drum brake pads INSIDE the disc for the E-brake. This isn't LJ specific, its very common on rear disc brakes.
he's rear discs, so that isn't really applicable...except maybe somewhat for the e-brake.
heres a Youtube video on front discs, the rears are much different- http://www.youtube.com/watch?v=xts0Cggc0bo
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
Need to change rear brake shoes...have some questions dolphy TJ Wrangler Technical Forum 20 08-19-2009 08:18 PM
Are these rear brake shoes the right fit for my jeep? Plowhoss YJ Wrangler Technical Forum 5 04-02-2009 12:12 PM
Rear Brake Shoes SteveJcoYJ YJ Wrangler Technical Forum 5 06-09-2007 11:34 PM
Rear brake shoes recommend dieselcrackel TJ Wrangler Technical Forum 0 10-29-2006 04:35 PM
replacing rear brake shoes wyldejackyl TJ Wrangler Technical Forum 9 05-23-2005 06:17 PM
