How to change oil filter with out a mess? - JeepForum.com
post #1 of 14 Old 07-01-2010, 07:22 PM Thread Starter
popeyesides
popeyesides's Avatar
Does anybody have any tricks to change oil filter on 06 LJ without getting oil on side motor and starter. I am ready to buy a remote filter and mount it the right way. Thanks for any help.
popeyesides is offline
post #2 of 14 Old 07-01-2010, 07:25 PM
DevilDogDoc
It's a challenge, I just put some rags down to catch what I can to keep it off the starter..
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #3 of 14 Old 07-01-2010, 07:26 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
just think of it as rust prevention for the cat pipe, upper control arm bolt, engine block and starter.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 14 Old 07-01-2010, 07:32 PM
tjsean0308
I have had luck with a piece of cardboard bent into a 90 degree just long enough to clear the starter. Just break the filter loose with your wrench or both hands and then stick the cardboard up against the block under the filter and unscrew the filter. The cardboard is usually quite oil soaked but it usually helps keep the oil going all in one place. Wax coated might work better never tried it. Your mileage may vary. best of luck .
tjsean0308 is offline
post #5 of 14 Old 07-01-2010, 07:51 PM
jstruck
jstruck is offline
post #6 of 14 Old 07-01-2010, 07:58 PM
jonrjen
2011 KK Liberty
Take an old rag and hold it under the filter as you turn the filter to remove it. It will catch most all of the draining oil. I just changed my oil a few hours ago, this worked pretty good, secret is to use a rag that will allow the oil to get sucked into the material. I used an old cloth diaper.
jonrjen is offline
post #7 of 14 Old 07-01-2010, 08:04 PM Thread Starter
popeyesides
Thanks for the replys.
post #8 of 14 Old 07-01-2010, 08:52 PM
J-Mox
I've tried several things with similar results.
Wrap oil filter in an old sock while removing. Helps to catch oil and also helps with the heat.
Hold rags under filter against block while removing.
Punch hole in the lower corner of filter, and one in the center to act as a vent, and drain filter before attempting to remove.
All work pretty well but it's a messy job if your not careful.
2004 Wrangler X, 6-cylinder, 5-speed, Dana 30 w/ARB, Alloy USA front shafts, Dana 35, 2" BB, 1" BL, OME shocks, Brown Dog MML, UCF Ultra High-Clearance Skid, Lo-Pro Mount, SYE, Pro Comp Adj. Control Arms, Savvy Gas Tank skid, JKS Quick Disconnects, Rock Hard Sliders, 31" BF Goodrich KM2's on Ravine wheels, Hard Top, Bestop Soft-top, Bestop Safari Top
2010 Moab Trip Thread with JeepForum Members
Dont hate on the guy that keeps his Jeep clean....
Hate on the guy that doesn't get his Jeep dirty....
J-Mox is offline
post #9 of 14 Old 07-01-2010, 08:58 PM
jonrjen
2011 KK Liberty
If you choose to go the punch a hole in the filter as a vent route....make sure you loosen the filter a little bit. Not enough to allow it to leak, but enough to know it is not stuck in place. Nothing worse than having drained the oil, having punched a hole in the filter and then not be able to get the filter off....that sucks big time....don't ask me how I know, please.
jonrjen is offline
post #10 of 14 Old 07-01-2010, 09:21 PM
Unlimitedlou
Just use brake clean when you are done to clean up the mess. Put your oil catcher, whatever it is, under the filter and spray it off. It will clean everything and you will be good.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #11 of 14 Old 07-01-2010, 09:54 PM
chadsmeltzer
chadsmeltzer's Avatar
Put a plastic bag over the filter, like the bag the new filter came in. Keep it over the filter as much as possible and almost all the oil goes into it. Just make sure the bag doesn't have holes in it.
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #12 of 14 Old 07-01-2010, 10:00 PM
FM117
Edit Above poster beat me to it
FM117 is offline
post #13 of 14 Old 07-01-2010, 10:41 PM
ManInBlackTJ
x2 on the brake clean. no sense in wasting time and making a bigger mess of yourself than your rig
ManInBlackTJ is offline
post #14 of 14 Old 07-01-2010, 10:56 PM
CaptGeno
CaptGeno's Avatar
i just finished changing my oil and i warped the rag around the filter...but that bag trick sounds like a good idea, gonna try it next 3,000 mi, or 3 months which ever comes 1st
CaptGeno is offline
oil change , filter , mess , tj , lj , wrangler
Air filter change? rondawg JK Wrangler Technical Forum 8 05-24-2007 11:33 AM
No mess oil filter change 4.0 billy boy TJ Wrangler Technical Forum 43 12-14-2006 08:57 AM
Oil change mess Flashman1 TJ Wrangler Technical Forum 4 03-17-2006 11:03 PM
oil change - same filter? okstatendn TJ Wrangler Technical Forum 7 03-10-2006 07:59 AM
Oil & Filter Change Mike5150 TJ Wrangler Technical Forum 29 02-10-2006 01:09 AM
