How to change manual transmission fluid? - JeepForum.com
post #1 of 64 Old 01-28-2011, 09:06 PM Thread Starter
josh_br
2003 WJ
I would like to change the fluid in my 1997 Wrangler's transmission. It is a 5 speed manual. I'm asking about it because this is something I haven't ever done before. As I understand it, you just remove a drain plug, drain the old fluid, and replace the plug. Then there's another plug up higher, so you take that plug out and then add the new fluid until it gets level with this plug. Sound correct?
I also wondered if anyone knows of anything unexpected a person can run into doing this, and if anyone knows what the best fluid to put back in the tranny would be. Most of the Jeep's miles are driven on-road, but it does get the occasional trip off-road when time permits. My local auto parts store is Advance Auto.
Thanks!
Josh_Br
2003 WJ (Laredo), 1990 Toyota pickup
Used to have a couple TJ's and ZJ's
josh_br is offline
post #2 of 64 Old 01-28-2011, 09:12 PM
George Dickel
George Dickel's Avatar
I can't recall without looking but I believe you can find that info in one of those stickys up top of the screen. If not, it's pretty straightforward. My only issue I want to say was the crowded area makes getting the new fluid back in tough without a pump of some sort.
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
post #3 of 64 Old 01-28-2011, 09:13 PM
2jhanna
first make sure you can get the fill plug out first (drivers side about mid way up), the last thing that you want to happen is to drain the fluid and then not be able to get the fill plug out because of it being too tight or stripped.
having a "bottle fluid pump" is handy to get the new fluid in.
i think for your year, most here have switched to 10/30 motor oil. others can correct me if this is not correct.
jhanna
denton county, tx
2jhanna is offline
post #4 of 64 Old 01-28-2011, 09:16 PM
freeskier93
Remove fill plug, then remove drain plug. The rain plug has a magnet in it so make sure you clean the metal shavings off. You can even drain it with the skid plate on, I use cardboard to deflect the oil.
Put drain plug back on. There are two ways of doing this:
1. Remove the shifter from the transmission and poor the oil in there until it comes out the fill hole.
2. Get a handheld pump and pump the oil into the transmission through the fill hole until it runs out.
I personally like option 1.
^^^Yes, 10w-30 motor oil is the "new" spec. It's what I put in there and am really happy with it. Really smoothed out the shifting.
freeskier93 is offline
post #5 of 64 Old 01-28-2011, 11:42 PM
AlphaTJ
http://www.stu-offroad.com/engine/ax-15/ax-15-1.htm
I used a flexible cookie sheet to channel the old fluid over the skid plate and a quart pump to pump the Redline MT-90 in. The problem I had was my washer from the drain plug fell into the fluid and I didn't notice until I was getting rid of the old fluid had already re-filled the transmission.
AlphaTJ is offline
post #6 of 64 Old 01-29-2011, 05:31 AM
cfmiller58
redline mt-90 or royal purple synchromax (ive got RP in mine now and will switch to redline). i have not heard of anyone using 10w-30 wt oil and would not use it in your manual transmission. in fact without doing any research into it i would say that it could damage your synchronizers because the oil meets nowhere near the viscosity requirements or has the right properties (waiting to hear the correct answer from jerry now). and if i remember correctly the fill plug sits decently high up, if you were to fill all the way to that, you would have way too much fluid, im pretty sure its 4 qts. better by yourself a manual to see what the factory specs are for amount of fluid and what specs the fluid needs to meet. only about 15 bucks from your local parts store. well worth the investment.
oh and if you get a fill tube long enough, the bottle will fit up in front of the fire wall allowing the oil to drain in the tranny. either that or a pump will work.
edit: in just reading the link real quick from stuoffroad, about 3.25 qrts.
Black Jeep Society
cfmiller58 is offline
post #7 of 64 Old 01-29-2011, 05:38 AM
BriansCJ
1994 XJ Cherokee
I use 10w-30 and it works great. Its the new oil your supposed to use in the AX-15.
First remove the FILL plug.
Then the drain
put the drain back in
Fill it up with 10w-30 using one of those crappy pumps from autozone
Fill plug back in
Your good to go
IIRC the fill/drain polugs are 15/16".
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #8 of 64 Old 01-29-2011, 06:34 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
10w30 is the current recommended fluid from jeep for the ax15.
ratmonkey is offline
post #9 of 64 Old 01-29-2011, 07:10 AM Thread Starter
josh_br
2003 WJ
That is just the kind of info I was looking for, such as that I'll need a pump or something to get the new fluid in. Thanks all!
Josh_Br
josh_br is offline
post #10 of 64 Old 01-29-2011, 09:59 AM
freeskier93
1st, gear oil and engine oil use different scales. 2nd, 10w-30 is the new recommended oil from Chrysler. 3rd, while Jerry is a wealth of information there are a lot of other people who happen to know what they are talking about. 4th, 3.25 quarts is almost exactly to the fill plug.
post #11 of 64 Old 01-29-2011, 10:32 PM Thread Starter
josh_br
2003 WJ
I visited Advance Auto this afternoon. They recommended gear oil...I don't remember what weight. They said 3.4 quarts were required. Hopefully tomorrow I will to change the fluid.
Josh_Br
josh_br is offline
post #12 of 64 Old 01-29-2011, 10:41 PM
freeskier93
What gear oil did they recommend? GL-4 I hope...
post #13 of 64 Old 01-29-2011, 10:51 PM
Max-Q
1983 CJ7
You're right on the money on all counts. I've got a '97 with a manual and I switched to 10/30 last year. The tranny shifts way better than it ever has and i no longer have problems shifting into 2nd gear on cold mornings.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #14 of 64 Old 01-30-2011, 06:35 AM
jschroeder423
I've read that you should use synthetic 10w30, is that true?
jschroeder423 is offline
post #15 of 64 Old 01-30-2011, 06:43 AM
crusher242
^^^ Correct.
Hold onto something... Quick!!!
crusher242 is offline
"Manual transmission fluid change" bigdogdaddy TJ Wrangler Technical Forum 103 02-10-2014 09:03 AM
Manual Transmission & Dana 44 Fluid Change nsjeep TJ Wrangler Technical Forum 13 04-09-2009 02:31 PM
Manual Transmission Fluid Change--Need Opinions!! kylebgt TJ Wrangler Technical Forum 20 12-21-2008 08:06 PM
Manual Transmission Fluid Change luk4mud TJ Wrangler Technical Forum 4 06-30-2007 08:11 AM
manual transmission fluid change question houndog TJ Wrangler Technical Forum 9 06-03-2007 05:51 PM
