how can you tell if ball joints are bad? - JeepForum.com
post #1 of 13 Old 03-08-2011, 06:38 PM Thread Starter
mediumdaddy
Never messed with anything like this before, but how can you tell if they are bad, or on the way. and how does one go about changing them? oh front ones, by the way. thank you!
-If you won't stand behind our troops, feel free to stand in front of them!!
Utah Jeepcrew #63
mediumdaddy is offline
post #2 of 13 Old 03-08-2011, 06:43 PM
WreckMaster
jack up the jeep from the axle until the tire is a couple inches off the ground. put a prybar under the tire. Then put a pipe under the prybar sideways. Push down (pry up) onthe prybar. if you feel play upand down then ur ball joints are bad. Always better to have somebody else look from in front if u can't see.
02 Grand Cherokee Limited, 4.7L. Bone Stock Family Truckster.
2" Rough Country BB, 255/70/17 Grabber AT2's
WreckMaster is offline
post #3 of 13 Old 03-08-2011, 06:46 PM
Benderff
Benderff's Avatar
Jack up the front end. Use jack stands also to keep it safe.
Grasping the top and bottom of each wheel, pull on the bottom and push on the top to feel for play. Then pull on the top while pushing on the bottom. You are rocking from the side of the vehicle to the center of it to test for clearance between the ball and the socket. You really need to but your back into it. If you feel ANY play you have a bad ball joint or the it may be loose wheel bearings (but you may be able to 'feel' where the clearance is). Replace both sides even if only one side feels loose.
Shade-tree style is to try to rock the top of the tire while it on the ground but that can only test the top ball joint
You only have front ball joints.
Do this to replace them. http://www.stu-offroad.com/axle/ball...alljoint-1.htm
Benderff is offline
post #4 of 13 Old 03-08-2011, 06:47 PM
mhcurlee
get a buddy to get behind the wheel and quickly steer the wheel back and forth while you get under and watch the joints. It should be easy to spot a bad joint (they will have slop/play )
mhcurlee is offline
post #5 of 13 Old 03-08-2011, 07:20 PM
WreckMaster
you won't see a bad ball joint from turning the wheel back and forth. Thats how you check tie roads and steering components. The weight of the jeep is on the bal joints, You need to jack it up from and support it from the axle. But pushing it by hand is not sufficient, but it will work if they are absolutely wasted. Like I said b4, Use a pry bar also. You will be surprised how much more efficient it is.
post #6 of 13 Old 03-08-2011, 07:34 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
There are almost zero lower balljoints in use after a few thousand miles that do not have some up and down play. Up and down play in the lowers will also translate into up and down in the uppers because the upper pins float up and down inside their races.
If you jack it up and lever the tire up and down and replace the balljoints because there is some up and down play, you're wasting time and parts.
I just went through this with John who was having serious DW issues and many many folks told him it was his balljoints including some mechanics at shops.
His DW is now gone and he still has his original balljoints with over 110,000 miles on them.
OTOH, if you have the slightest side to side or front to back play in the uppers, replace them because they will cause DW.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #7 of 13 Old 03-08-2011, 07:37 PM
lumpster
lumpster's Avatar
out of curiousity, what did you guys do to get rid of his DW? I know every jeep is different, and what worked for him, may not work for everyone.
lumpster is offline
post #8 of 13 Old 03-08-2011, 07:44 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Diagnose and replace. Or, he finally found all the worn out parts and replaced them from 100,000 miles of slightly out of balance tires. The list was long and expensive that would have been mitigated by keeping his tires balanced.
I am Savvy
mrblaine is offline
post #9 of 13 Old 04-19-2012, 02:21 PM
Danny0717
So are you saying its OK to have this up and down movement? I have this issue and its causing a real problem when driving on the freeway when i hit a bump. Should i replace them or not or what should i do?
Danny0717 is offline
post #10 of 13 Old 07-28-2015, 07:13 PM
mearsk
what if the camber is off (top of tires lean in) would be a sign the ball joints are worn (no DW)
mearsk is offline
post #11 of 13 Old 07-28-2015, 08:02 PM
Mousejockey
What he is saying is that it is normal for there to be 'some' axial movement. Many manufactures specify "Do not check for axial movement"
That being said there is a point where it is an issue, how much yours move I cannot say.
Mousejockey is offline
post #12 of 13 Old 07-28-2015, 08:06 PM
Mousejockey
Ball joints aren't checked by Camber measurements, They are checked by movement. Yes if Ball joints are worn enough, or Bent, they can cause Camber issues, A noticeable lean to the tire would indicate much more than a worn ball joint.
post #13 of 13 Old 07-28-2015, 08:08 PM
Mousejockey
For the OP, Also check that the knuckle rotates freely without any binding
Ball Joints Gone Bad? luk4mud TJ Wrangler Technical Forum 4 02-24-2009 03:51 PM
Ball Joints Rollin TJ Wrangler Technical Forum 12 12-24-2007 03:20 AM
New Ball joints? TJ_Jackson TJ Wrangler Technical Forum 6 11-05-2007 01:13 PM
Axle u-joints & maybe ball joints. CityJeep90 YJ Wrangler Technical Forum 2 06-04-2006 05:23 PM
Help with front end work... ball joints, u-joints kaffeene YJ Wrangler Technical Forum 5 04-27-2005 08:45 PM
