How can I tell what OME shocks and springs are on my TJ? - JeepForum.com
post #1 of 22 Old 07-31-2010, 07:45 PM Thread Starter
BarmyBeast
Hello,
I recently bought myself a 4.0 Wrangler TJ. It has already been modified with OME suspension kit and I can see that the suspension is higher. The trouble is I have no idea how to find out by how much this suspension has raised the car by.
Is there something on the product that will tell me what lift it is providing or is there a way of measuring to see how much it has been lifted from stock?
I want to know as I am looking into my options of further mods including larger wheels.
Cheers
BarmyBeast is offline
post #2 of 22 Old 07-31-2010, 08:08 PM
jdub36
Pictures will help. More than likely it is a 2in suspension lift from OME but it could have spacers added or a body lift to make it more.
And try not to call you jeep a car, you will get ripped for that on here.
jw
jdub36 is offline
post #3 of 22 Old 07-31-2010, 08:10 PM
inglisleslie
N66 and N67 shocks?
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #4 of 22 Old 07-31-2010, 08:18 PM Thread Starter
BarmyBeast
I have checked for spacers and body lift and neither are present so I know its just the suspension that is lifted.
I am just trying to upload some pics now.............if I can figure that out, haha
post #5 of 22 Old 07-31-2010, 08:29 PM Thread Starter
BarmyBeast
post #6 of 22 Old 07-31-2010, 08:32 PM Thread Starter
BarmyBeast
post #7 of 22 Old 07-31-2010, 08:33 PM Thread Starter
BarmyBeast
Are these of any help?
The tires I currently have are 31 10.50 R15
post #8 of 22 Old 07-31-2010, 08:36 PM Thread Starter
BarmyBeast
Originally Posted by inglisleslie View Post
N66 and N67 shocks?
How can I find out? Is it written anywhere on the shock or spring? I have had a good look but can't find anything other than the OME logos.
post #9 of 22 Old 07-31-2010, 08:50 PM
inglisleslie
I dont think so....I just installed mine this last week and i didnt notice any markings. It was just on the box.
/l ,[ ______],
()_) ()_)--O-)_)
post #10 of 22 Old 07-31-2010, 09:03 PM
Rubikahn
Rubikahn's Avatar
I just checked mine and they are stamped. Get underneath the jeep and wipe off the lower portion of the shock. My fronts are stamped N66 underneath the word MAN. As far as the springs I would look for any remnants of a tag attached to them. If there aren't any tags you could contact ARB directly they may have a way to identify them by what they look like. As crazy as this sounds you could also pull up on the next wrangler you see. Get out and verify it's stock and then whip out a tape measure, then you'll know for sure how much lift you actually have. GL
OME ZJ/LJ lift, 33" MT MTZ on AR-23 wheels, front and rear JKS trackbars, 1" seat risers, MORE 1" BL and MML, factory Ipod adapter. Light khaki jeep club #72
Rubikahn is offline
post #11 of 22 Old 08-01-2010, 06:24 AM
redo4x
That's the 2 inch kit. I have the same lift with 32x11.50's. I've since added a 1.25 body lift and mml to raise the skid plate back up and make room for 33's in the future. I'm also going to add a 3/4 spacer up front since the front sits about an inch lower with the winch and bumper.
redo4x is offline
post #12 of 22 Old 08-01-2010, 08:06 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
read the tags and numbers...the PN for the shocks is stamped right into the lower side of the shock body. the springs have tags on them should say A or B, and IIRC in really small print the PN. if you can't find the PN for the springs, you're SOL...they make a few versions.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #13 of 22 Old 08-01-2010, 05:50 PM Thread Starter
BarmyBeast
Gonna have a crawl under now and have a look. Cheers for that.
post #14 of 22 Old 08-01-2010, 05:55 PM Thread Starter
BarmyBeast
I like your set up. Its similar to the way I am thinking of going. I would like to get 33s on my Jeep, but want to do it properly so that my off road capability isn't compromised.
By raising the body 1.25 and having the 2 inch spring lift, is that giving you the clearance for 33s? Do you get any scrubbing on the fenders or when you turn the wheel to full lock? Have you had to use disc spacers on your 32q?
My 31s at the moment don't hit the fenders but do rub slightly on full lock and I am considering getting disc spacers to push the wheels outwards slightly.
post #15 of 22 Old 08-02-2010, 08:49 AM
-dirt-
http://www.jeepforum.com/forum/f9/fa...7/#post6077636
This might help too.
-dirt- is offline
ome , suspension height
New Springs and Shocks suppersready TJ Wrangler Technical Forum 0 06-15-2010 03:08 AM
OEM shocks & springs BringThaPain TJ Wrangler Technical Forum 2 06-11-2009 03:44 PM
SOA- what springs and shocks? wildman90 YJ Wrangler Technical Forum 11 11-30-2008 05:48 PM
OME shocks with 3.5 re springs bpowa TJ Wrangler Technical Forum 7 04-14-2008 09:44 PM
Springs / Shocks or Both Dave R. YJ Wrangler Technical Forum 1 05-27-2003 10:05 AM
