How can I tell if my 2000 TJ has california emissions? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How can I tell if my 2000 TJ has california emissions?
50 in light bar /A pillar mount less than 500 at JeepHut.cFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectThanksgiving holiday sale in effect @ oconeeoffroad.com
Unread 02-21-2012, 09:49 AM   #1
26679cj5
26679cj5's Avatar
So my ECM is out of a cherokee and I want to put the correct one in it. It works fine,but it always throws a code due to not being able to detect the fan relay for the cherokee's electric fan. I'm also getting an oxygen sensor code, so I'm going to replace all of those with new sensors since the jeep has about 130,000 miles on it.
Do I just need to pull the sensors and see if there's part numbers on them? 2000 was a split year and earlier models only have 2 sensors, while later models like mine have 4 sensors, 2 before the precats and 2 directly after the precats. The problem is that I have also read 4 sensors means I have california exhaust,but i'm not sure if that's true.
26679cj5 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2012, 10:26 AM   #2
26679cj5
26679cj5's Avatar
nevermind, looked under the hood and found the sticker that states that it does have the california emissions
Unread 07-22-2013, 12:50 PM   #3
dbsimpkins
Where was this sticker? It's my understanding that if you have the pre-cats, you've got a cali jeep... if not, it's not. Got o2 issues on mine, but no pre-cats, so I'm searching for verification that it's not a cali-jeep... sensors being $100+ each, I don't wanna screw around with the wrong ones.
dbsimpkins is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 12:54 PM   #4
biffgnar
biffgnar's Avatar
Where are you buying sensors? Get them from Rock Auto or somewhere similar on line. A lot cheaper.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
