How can I get the front wheel hub off the axle? - JeepForum.com
post #1 of 29 Old 10-10-2005, 12:28 PM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
I'm replacing the U-joints in my front axle... got the passenger side done without any problems but now on the driver side I can't get the hub off the knuckle. I've been soaking it with WD-40 and banging around edge with a hammer and screwdriver for a while but still nothing. Even managed to break the screwdriver. Any tips or tricks for getting this off so I can pull the shaft out??
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #2 of 29 Old 10-10-2005, 12:49 PM
TJ Rat
I used a two jaw puller. You might want to try some PB Blaster or Kroil instead of WD40.
USMC - When America needs 911.
Growing Old is Mandatory, Growing Up is Optional.
Mud is a Requirement Either Way!
TJ Rat is offline
post #3 of 29 Old 10-10-2005, 12:53 PM
wyldejackyl
WD-40 is best for Water Displacement..every other use is secondary. PB Blaster is good stuff, as is liquid wrench.
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline
post #4 of 29 Old 10-10-2005, 02:20 PM
jeepfury
What I did was pretend that I was a baseball player and beat the hub "carefully" with a small sledge until it came off. Make sure you hit around and not just one spot.
JOOP
00 Cherokee Classic- Stock
jeepfury is offline
post #5 of 29 Old 10-10-2005, 02:27 PM
Stu Olson
Stu Olson's Avatar
mrBlaine gets the credit for this handy little trick! Hopefully I pass it on correctly....I've not tried it myself as I've never had to deal with that much rust.
Rotate the tire until the yoke ears on the outer stub shaft are parallel to the ground.
Obtain proper length grade 8 bolt and insert as shown in the below picture.
Turn the wheel, causing the yoke to press against the bolt head....this causes the unit bearing to push out a bit on that side of the knuckle.
Now turn the wheel back and bit and relocate the bolt on the other yoke ear and turn the steering wheel until it contacts the bolt.....pushing that side out a bit.
Alternate back and for, a bit at a time, until the unit bearing is free of the knuckle.
And yes, use penetrating oil like PB Blaster, not WD-40.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #6 of 29 Old 10-10-2005, 03:02 PM
DavidC
What a cool idea!
Makes me want to replace my axle U-jonts...... again.
We in the rust belt salute you.
2012 JKU Rubi,Auto, 4.10's "takes a licking and keeps on ticking"
99 Sahara D30/44 w ARB's and 4.10's, Warn 9.5TI,AA SYE & Wood's shaft,Raingler nets,Jeeperman trail skids,Warn gas tank and steering box skid's, BDS 2" springs, Currie control arms,32" MTR's,AEV Bridger wheels, custom made tire carrier bumper,Dynomax cat back JKS quicker disco's.PSC Trail Cage,Banks header,LiteDots.PSC Trail Corners.
92 CDN M101 trailer, 33" TSL Swampers,camo paint. Original camo tarp.
DavidC is offline
post #7 of 29 Old 10-10-2005, 10:06 PM Thread Starter
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Alright I get it... no WD-40! ... It was all I had in the garage at the moment and I was hoping to bang this project out quick without going to the store before I drove back to school today. I was afraid of dystroying the hub though since I didn't have alot of time to run to the parts store so I ended up putting everything back together and saving the U-joint for another time so I could get on the road.
Some good ideas here though... that bolt trick looks especially interesting... I'll try that first next time I can tackle this again but for some reason I'm thinking my power steering pump is no match for this much rust haha... although the axle in those pics looks worse than the 18 year old one in my Jeep! We'll see what happens.
post #8 of 29 Old 10-10-2005, 11:12 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by DavidC
What a cool idea!
You're welcome and if you notice, there was no penetrants of any variety used. Just leverage and a bit of ingenuity. Pops the unit bearings right out of the knuckle.
As Stu said, do a little on each side so as to push the bearing out of the knuckle as straight as possible.
mrblaine is offline
post #9 of 29 Old 10-10-2005, 11:14 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It was done without the engine running. There is a phenomenal amount of leverage generated.
mrblaine is offline
post #10 of 29 Old 09-17-2010, 07:47 PM
johnboy68
HIP2BSQR
johnboy68's Avatar
I know this is an old thread but it is timeless advice. I used this method this evening and had my hubs off and axles out in about 5 minutes!
-John-
johnboy68 is offline
post #11 of 29 Old 09-17-2010, 07:59 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Added to the FAQ. Thanks for bringing this back.
Search terms: unit bearing, hub bearing, wheel bearing, D30 unit bearing, dana 30 unit bearing, unit bearing removal, stuck unit bearing, seized unit bearing, remove unit bearing.
Wheelin98TJ is offline
post #12 of 29 Old 09-17-2010, 08:32 PM
Mousejockey
I use that method to pop the hubs out fo the Dodge 3500's at work also (Unlike mrblain I use oil as I go along)
Mousejockey is offline
post #13 of 29 Old 08-31-2011, 12:59 PM
holt03
for easy removal screw the two out side bolts in to about 1/8 inch from tight and hit them with lead hammer alternatlly. make sure to use lead or brass hammer so as not to damage the bolt head
holt03 is offline
post #14 of 29 Old 08-31-2011, 02:00 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
If you ever try the bolt trick, you'll throw your lead hammer in the trash.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #15 of 29 Old 08-31-2011, 02:13 PM
bbuske
This Worked great for me, I'm just glad I visited Stu's site before breaking out the BFH.
Originally Posted by Robert J. yates View Post
Now don't be bringing logic into this
Looking to Buy Full Doors and a HardTop near Northern California, PM me if you have them for sale or have a lead on some
bbuske is offline
bearing removal , hub bearing , knuckle , seized , unit bearing , wheel bearing
How to remove front wheel bearings/hub from front axle? Tshark299 YJ Wrangler Technical Forum 10 09-17-2010 08:55 PM
Superior Axle & Gear EVOLUTION SERIES Front Axle Tube Seals 95wrangler4life YJ Wrangler Technical Forum 3 02-17-2009 03:00 PM
Major problem: Front axle(4WD), Right wheel grinding, no longer powered. Duffboy YJ Wrangler Technical Forum 7 10-31-2008 06:42 AM
replacing front axle shaft u-joint to wheel vball1socr4 YJ Wrangler Technical Forum 4 08-26-2006 08:41 PM
Front Axle U-Joints and Wheel Hubs prossett YJ Wrangler Technical Forum 7 04-07-2005 08:36 AM
