How to Burp Radiator? - JeepForum.com
post #1 of 13 Old 08-31-2011, 12:23 PM Thread Starter
VnutZ
VnutZ's Avatar
This is probably a dumb and simplistic question - but how do you burp the radiator?
My cooling system is all stock and was recently flushed. They used the HOAT because I brought it to them. A prior service center put in the non-HOAT stuff before (because I didn't know at the time and it's what they put in there) ... could there be any residual effects from that?
BACK STORY
I just want to work through some stuff on my cooling system. After driving from MD to AZ over the past 48 hours, I was nearly overheating on several spans especially across TX. I had to run the cabin heat on full to keep the engine temperatures at 220 otherwise it rose into the 240s (and this is measuring with ScanGauge off ECU - ignoring the stupid dash temp which says I was at 210). I could maintain a steady engine temp if I kept my speed at 60mph with the heater on.
I did call Warn up about the PowerPlant blocking the radiator for any advice on mounting it on different plates, etc. and they told me it was fine (from their Death Valley and load testing with MOPAR) to run the Jeep continuously in the 230s up to 240. They did advise that sustaining temps above 240 was a bad idea but I could stop in my cooling quest once I maintain a steady 230s range.
And Yes - I've already searched and the search tool just keeps finding threads telling you to burp it, not how to burp it.
2006 Black Unlimited on Cummins 4BT
31.5 Gallon Genright Safari Tank (~900 mile range)
4" Long Arm and OME Shocks on 35x12.5"
Vanco Brakes, Ox Lockers and Warn VR10000 Winch
VnutZ is offline
post #2 of 13 Old 08-31-2011, 12:26 PM
biffgnar
biffgnar's Avatar
Besides search on JF there is a really cool thing called Google, here let me show you: http://lmgtfy.com/?q=How+to+burp+your+radiator
Romney in 2020!
biffgnar is offline
post #3 of 13 Old 08-31-2011, 12:27 PM
chris142
Remove the heater hose from the thermostat housing. Fill the Radiator untill water comes out of the nipple where the heater hose was.
Put the heater hose on and continue to fill the Radiator. Once it's full put the Radiator cap on, start the engine and hold it @ 2000 rpm untill the thermostat opens. Turn it of. Check and fill the Radiator after it has cooled.
chris142 is offline
post #4 of 13 Old 08-31-2011, 12:58 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
JF strongly frowns on just telling our fellow members to do a Search in response to a question. I can't wait for you to ask a question that could conceivably be found by searching for the answer.
Getting
Jerry Bransford is online now
post #5 of 13 Old 08-31-2011, 01:21 PM
biffgnar
biffgnar's Avatar
When I do, please point it out to me!!
Romney in 2020!
biffgnar is offline
post #6 of 13 Old 08-31-2011, 02:37 PM
freeskier93
Starting with a cold engine remove the radiator cap and run the engine until the thermostat opens. However with a full radiator that might be a bit messy. I would normally do that when refilling the system.
Unless there is TON of air in the system any little bit left will eventually work its way out through the overflow bottle. Usually a couple days after re filling everything the lid on my overflow bottle will pop open.
freeskier93 is offline
post #7 of 13 Old 08-31-2011, 04:58 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
yup, pretty much how I do it...a modified version of the FSM procedure...just pour fluid in till it comes out the cap. with the engine off & cold, I squeeze the upper hose and push as much air out as I can, then keep filling the radiator till no more bubbles come out. then i fill the overflow bottle above the "Hot/Full" mark and go for a drive. it usually sucks in most of the fluid in the overflow bottle on that drive, and later I top it off as necessary till its at the "Cold/Full" mark when cold.
if you overfill it the worst that happens is it sprays the inside of the engine compartment with glycol if you're smart, you'll clamp on a 5/8" line to the overflow spout and route it down (i'm not smart enough yet).
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 13 Old 08-31-2011, 08:03 PM
ytowntj
Kind of a side question about trapped air in cooling systems, but since 2 mods are already here and it might help the OP
A buddy of mine is having sporadic overheating problems. His cooling system is completely rebuilt, hoses, radiator, tstat, oem water pump. New ATK motor and still over heats.
It runs perfect 208* for about a week and the all the sudden starts pegging the gauge ~260 degrees. It has one of those prestone flush kits with the "T" connection on the upper heater core hose. Once it starts overheating we have found we can open the T on the heater core hose and let it release air for almost twenty minutes as it cools down. I know the system is under pressure, but its an absurd amount of air. After it releases the air its good for another week until the air builds up again. If you only let it cool and not open the T it will overheat again in minutes.
Where is the air getting trapped?
Thanks and sorry for the hijack, hopefully it helps OP
ytowntj is offline
post #9 of 13 Old 08-31-2011, 08:06 PM
chris142
A closed cooling system won't "make" air. Your buddy has either a small leak and it's slowly leaking untill it gets low enough to over heat or a blown headgasket or cracked head.
chris142 is offline
post #10 of 13 Old 08-31-2011, 08:11 PM
ytowntj
I realize how a closed system works, thats why Im puzzled.
It has a brand new ATK stroker in it, comps fine.
Literally every component is new in the cooling system and the coolant is still all there. its just building air someway/somehow. Im starting to wonder if maybe the stem coming out of the radiator to the overflow bottle is clogged, or never open from the factory as its an aftermarket radiator.
Im completely at a loss and tired of watching 20 minutes of steamy air whoosh out of the heater hose when on the trail
ytowntj is offline
post #11 of 13 Old 08-31-2011, 08:15 PM
Jerry Bransford
Administrator
One thing that can help make trapped air a distant memory is to install a thermostat with an air bleed hole in it. Or if you can't find one, drill a 1/8" hole into your thermostat mounting flange. The hole allows any trapped air to bleed out and into the radiator where it can be passed.
The first pic shows an aftermarket thermostat with a bleed hole, the second pic shows one that has been drilled. Mount the thermostat with the bleed hole at the top. Make sure too to only use a 195 degree thermostat in the TJ.
Getting
post #12 of 13 Old 08-31-2011, 08:27 PM
ytowntj
Interesting Jerry.
Ill see what his tstat looks like and possibly drill it. Ill try anything at this point as Im tired of being the designated go to guy for his cooling issues
ytowntj is offline
post #13 of 13 Old 08-31-2011, 09:10 PM
Yucca-man
Interesting Jerry.
Jerry knows what he speaks of - then again I've heard him saying it for what...a dozen or more years now? The hole in the t-stat does an amazing job for getting rid of bubbles in the coolant. Been doing it in my Cherokees ever since living in Arizona.
Yucca-man is offline
radiator leak. get the radiator fixed or replace? LiveAndLearn TJ Wrangler Technical Forum 32 11-24-2011 11:06 AM
Oil Burp? Pressure Release...... vtwildabeast YJ Wrangler Technical Forum 3 04-28-2009 01:08 PM
How Do I "Burp" My Cooling System roadking TJ Wrangler Technical Forum 0 09-19-2008 10:52 PM
can't burp cooling system old school style! fish4life TJ Wrangler Technical Forum 4 06-19-2008 06:07 PM
burp highrisetj39.5 TJ Wrangler Technical Forum 3 06-19-2007 09:35 PM
