How to adjust hardtop? - JeepForum.com
post #1 of 13 Old 08-27-2008, 01:37 PM Thread Starter
magnato1
Hi everyone,
I can hear a lot of wind coming in between the hardtop and the windshield when I am on the freeway. Is there a way to adjust the hardtop so this will not happen, or do I need a new seal? What's the deal? I mean, I know it's a Jeep and it's going to be noisy, but the amount of wind coming in seems somewhat ridiculous. I tried searching for this topic, but found nothing. Look forward to hearing from you. Thanks
magnato1 is offline
post #2 of 13 Old 08-27-2008, 01:38 PM
john NC
john NC's Avatar
are you sure the latches are both latched all the way? it may sound stupid but i drove around for a couple weeks thinking i needed a new seal when i had just forgotten to latch one
john NC is offline
post #3 of 13 Old 08-27-2008, 01:47 PM Thread Starter
magnato1
Hahaha, no I am sure that they're fully latched. I was hoping that there is a way to adjust the latches. Anybody know?
magnato1 is offline
post #4 of 13 Old 08-27-2008, 02:39 PM
BlueFlame
BlueFlame's Avatar
No way to adjust the latches.
You could try putting a layer or two of duct tape on the edge of the opening the latch hooks into, to tighten it up a bit. Probably not a permanent fix.
You can try to slide the top either forward or most likely, rearward a bit. You want the edge of the top flush with windshield - if it's forward even a hair it gets noisy.
Otherwise your seal may be shot.
For a quick fix, a strip of black electrical tape on the seam (all the way across) will stop the noise.
BlueFlame is offline
post #5 of 13 Old 08-27-2008, 02:43 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Sounds like a new seal is in order!
GOLENJEEPTJ is offline
post #6 of 13 Old 08-27-2008, 02:50 PM
slate210
Can you feel any of the wind you're hearing? I'd imagine it would be pretty obviously breezy if that were the case.
2000 TJ 4.0 5-SP 115k mi. Patriot Blue - Bone stock...for now.
1997 TJ 4.0 5-SP 134k mi. Red Jeep Club Member
- Some mods...
2006 VW Jetta TDI DSG 54k mi. BLACK Rocketchipped, boostvalve, boost gauge.
slate210 is offline
post #7 of 13 Old 08-27-2008, 03:32 PM Thread Starter
magnato1
Guess I'll have to pull it off and look at the seal. Is there a seal on the windshield and the hardtop or just the hardtop?
magnato1 is offline
post #8 of 13 Old 08-27-2008, 03:48 PM
03silversport
Just the hard top i believe, it's been a few months since i have looked at my hardtop but i don't think there is a seal on the actual hard top, just the top of the windshield.
03silversport is offline
post #9 of 13 Old 08-27-2008, 04:42 PM Thread Starter
magnato1
Silversport, sorry, your response seems to contradict itself. First you say it's the hard top, then that the seal is on the windshield. Which did you mean?
magnato1 is offline
post #10 of 13 Old 08-27-2008, 04:53 PM
Jonasty
I had the same problem. I just got some of that foam sealing stuff that has a strip of double-sided tape on one side and put some on the front of the hardtop under the lip. It worked like a charm and has kept working even though I have taken the hardtop off and put it back on a couple times without replacing the tape.
Jonasty
2000 Solar Yellow TJ Sport
Jonasty is offline
post #11 of 13 Old 08-27-2008, 04:57 PM
Zoom By You
Zoom By You's Avatar
I just checked my hardtop hanging in the garage, there is NO seal on it, only the windshield....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #12 of 13 Old 08-27-2008, 04:59 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Sometimes a hard top will be bolted onto the rear first before it is properly seated to the windshield which can prevent a good seal at the windshield. Loosen all the rear hard top bolts that hold it to the tub, slide it forward until it seals properly and then clamp the windshield clamps down. After that you can tighten the rear bolts again.
Jerry Bransford is offline
post #13 of 13 Old 08-27-2008, 05:32 PM
GoldenP51
GoldenP51's Avatar
X2, I did this once a couple months ago the foam wasn't quite thick enough but it did help and since I had the hardtop off to carpet it I put on some thicker foam and now there is no wind noise. You can pick some up at your local hardware store.
Tape across the front also works, however it is a temporary fix
GoldenP51 is offline
Remove Hardtop Glass to Repaint Hardtop?? nibblesupreme TJ Wrangler Technical Forum 12 02-02-2010 09:56 AM
Storing hardtop on Lange hardtop hoist? TJDaveX Wrangler General Discussion 4 06-29-2009 11:20 AM
Cure for hardtop squeek and offroading with hardtop? 06WranglerX TJ Wrangler Technical Forum 15 07-02-2006 05:09 PM
Factory Hardtop vs. Bestop Hardtop (review) MadDawg TJ Wrangler Technical Forum 2 12-17-2005 08:35 AM
How to adjust TPS Why J? YJ Wrangler Technical Forum 8 08-09-2005 11:52 AM
