How to adjust the handbrake ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > How to adjust the handbrake ?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 04-04-2010, 02:40 PM   #1
protix
Hey guys how do you adjust the handbrake need it to pass a vehicle inspection.
"Death is lighter than a feather, duty heavier than a mountain."
al'Lan Mandragoran
"Never gamble without knowing a back way out."
Matrim Cauthon
protix is offline   Reply With Quote
Unread 04-04-2010, 03:16 PM   #2
Anschutz
Up underneath the jeep you will see a cable running back and then splitting to got to the rear drums. You will need two wrenches and you just tighten the nut. Good luck.
Anschutz is offline   Reply With Quote
Unread 04-04-2010, 03:30 PM   #3
VanBCguy
Your profile says you have a D44 rear. Are you disc or drum on that D44?
If you're drum, it's one way. If you're disc, I've been advised (but I am NOT a brake expert) that the best way is to adjust the pads is on the brakes themselves and not to adjust the cable.
That's very little information and may make things a little more confusing, but hopefully someone will jump in here and feed on my post and give you accurate info.
Good luck on the V.I. I hate them!
Christchurch..... I'm jealous. I love your city!
Savvy Off-Road: http://www.savvyoffroad.com
VanBCguy is offline   Reply With Quote
Unread 04-04-2010, 03:31 PM   #4
Benderff
MEMBER
Benderff's Avatar
Ummm No. About the only reason you would ever adjust that is if you had made the mistake of screwing with it before. Per the FSM.
ADJUSTMENT - WITH ADJUSTING TOOL
Adjustment can be made with a standard brake
gauge or with adjusting tool. Adjustment is performed
with the complete brake assembly installed
on the backing plate.
(1) Be sure parking brake lever is fully released.
(2) Raise vehicle so rear wheels can be rotated
freely.
(3) Remove plug from each access hole in brake
support plates.
(4) Loosen parking brake cable adjustment nut
until there is slack in front cable.
(5) Insert adjusting tool through support plate
access hole and engage tool in teeth of adjusting
screw star wheel
(6) Rotate adjuster screw star wheel (move tool
handle upward) until slight drag can be felt when
wheel is rotated.
(7) Push and hold adjuster lever away from star
wheel with thin screwdriver.
(8) Back off adjuster screw star wheel until brake
drag is eliminated.
(9) Repeat adjustment at opposite wheel. Be sure
adjustment is equal at both wheels.
(10) Install support plate access hole plugs.
(11) Adjust parking brake cable and lower vehicle.
(12) Depress park brake lever and make sure park
brakes hold the vehicle staionary.
(13) Release park brake lever.
Benderff is offline   Reply With Quote
Unread 04-04-2010, 03:36 PM   #5
epeck87
adjusting it on the cable has the same effect. theres no reason you cant adjust the nut on the cable above your driveshaft. when you replace your shoes you will prob have to adjust it again but adjusting the cable is how i have always done it for years and i have never had any problems. its the easiest and fastest way to do it
Associates Degree in automotive technology
Toyota Expert Chassis Technician
ASE:
A1(engine repair)
A3(manual drive train and axles)
A4(suspension and steering)
A5(brakes)
A6(electrical/electronic systems)
OIIIIO
epeck87 is offline   Reply With Quote
Unread 04-04-2010, 03:42 PM   #6
Benderff
MEMBER
Benderff's Avatar
Again from the FSM
Parking brake adjustment is controlled by a
cable tensioner. Once the tensioner is adjusted at
the factory, it should not require further attention.
However, there are two instances when adjustment
will be required. The first is when a new tensioner,
or cables have been installed. And the second, is
when the tensioner and cables are disconnected for
access to other brake components.
I am by no means an expert, but it's bad advice to adjust the cables.
Unread 04-04-2010, 03:44 PM   #7
VanBCguy
freely.
support plates.
screw star wheel
wheel is rotated.
drag is eliminated.
This is essentially what I've seen done on my rear D35 drums and now on my rear D44 discs. Manual adjustments that are not just a simple tightening of the handbrake cable. Adjustments that are directly on the brakes themselves.
Again, I'm no expert (I don't do my own brakes..yet. I let the pros do them for me), but this seems to support my line of thinking and I'm sure someone else will concur with another post.
Unread 04-04-2010, 04:18 PM   #8
epeck87
in that case i stand corrected. i knew you could do it at the star wheel too but i didn't think it mattered if you used the star wheel or did it farther up on the cable. i guess i have been adjusting mine the wrong way although it has worked fine for me for the last couple years. if the fsm recommends a certain way id recommend following the manual
ASE:
A1(engine repair)
A5(brakes)
OIIIIO
Unread 04-16-2010, 08:10 PM   #9
epeck87
just out of curiosity what harm would it do if i adjust my parking brake by tightening the nut on the adjuster under the body instead of in the drum.
ASE:
A1(engine repair)
A5(brakes)
OIIIIO
Unread 04-16-2010, 08:24 PM   #10
tjsean0308
tjsean0308's Avatar
nevermind.
Last edited by tjsean0308; 04-16-2010 at 08:52 PM.. Reason: read the profile before typing next time.
tjsean0308 is offline   Reply With Quote
Unread 04-16-2010, 08:48 PM   #11
epeck87
i have a ford 8.8 with disc brakes in the rear
ASE:
A1(engine repair)
A5(brakes)
OIIIIO
Unread 04-17-2010, 04:27 AM   #12
epeck87
bump anyone? if i cant get a good answer then im gonna keep adjusting it at the point on the cable instead of messing with the drum.
ASE:
A1(engine repair)
A5(brakes)
OIIIIO
Unread 04-17-2010, 05:52 AM   #13
Pillswoj
By adjusting the cable, the pads are not meeting the drum evenly, only one end of the pads will make contact. The cable causes the pads to pivot, but the star wheel adjusts the pivot point. It is hard to explain but if you look at the system and see what the star wheel does and compare it to what happens if you tighten the cable it will make sense.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 04-17-2010, 06:12 AM   #14
Kiwi Jeeper
Use the star adjuster method, that works.
BTW, my WoF guy has stopped checking for handbrake on my TJ (it never stays adjusted). If brakes are otherwise okay, he is happy with TJ handbrake the way it is.
'01 TJ Renegade I6 4.0L Auto D30/D44, BFG Muds, Currie springs, OME shocks, Brown Dog MML, ARB Front and Rear Bars, Rokmen Gas tank skid and LCAs, RE UCAs, JB Conversion Super Shorty with Truspeed and TW shaft, Warn 9.5xp
'03 WG Limited V8 4.7L stock standard
Kiwi Jeeper is offline   Reply With Quote
Unread 04-17-2010, 08:23 AM   #15
mrblaine
mrblaine's Avatar
The actuation lever inside the drums (same holds true for the shoes inside the drums for rear discs as well) that attaches to the brake shoe only has so much travel. You're defeating that function by continually shortening the cable.
At some point, you will have the cables short enough and all the travel in the actuation lever removed, you will pull on the parking brake handle, it will feel really tight, but the shoes inside the drums won't move because you've defeated it's function and they no longer can move.
The correct way to do it has been outlined as per the FSM. Feel free to keep on keeping on, but don't get on here and snivel one day when your parking brake becomes less effective.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
