How to Adjust Full TJ Doors? - JeepForum.com
post #1 of 4 Old 11-30-2010, 10:24 AM Thread Starter
DezertTJ
My passenger side door needs to be adjusted just about a cm. How do i go about doing this? is it just the hinges?
DezertTJ is offline
post #2 of 4 Old 11-30-2010, 10:41 AM
Lawrence
A cm is not much and you should be able to do it with the upper hinge only. This will allow you to not worry about the paint getting chipped off the inside of the torx since the mirror covers that area.
Take your mirror off, loosen the hinge torx screws, adjust your door accordingly, tighten the torx, reinstall mirror.
Lawrence is offline
post #3 of 4 Old 11-30-2010, 10:42 AM
nikeo02
Also, the striker on the pillar is also adjustable, to an extent. This is useful if the door is in the correct position, but not closing.
2003 Yellow TJ
nikeo02 is offline
post #4 of 4 Old 11-30-2010, 11:09 AM Thread Starter
DezertTJ
ok cool. thanks guys
DezertTJ is offline
Half doors to full steel doors - '94 body, '88 doors xponce YJ Wrangler Technical Forum 8 02-20-2010 03:29 PM
how to adjust hard doors moldham YJ Wrangler Technical Forum 5 07-08-2008 11:46 AM
Adjust the doors? Fierdon JK Wrangler Technical Forum 4 02-28-2008 03:02 PM
anyway to adjust half-doors? brewc TJ Wrangler Technical Forum 3 02-11-2005 05:19 AM
Adjust Half Doors? GottaRam99 TJ Wrangler Technical Forum 3 04-22-2004 08:55 PM
