How to adjust door? - JeepForum.com
post #1 of 7 Old 11-13-2004, 04:09 PM Thread Starter
Big Brutal
Big Brutal's Avatar
How to adjust door?
I have a 97 sport with full doors and hardtop and somehow the drivers side door come out of square and is now pinching the frame at the top on the windshield side. There is a larger gap near the latch area than on the passenger side door.
How do I adjust the door back and down?
Big Brutal is offline
post #2 of 7 Old 11-13-2004, 11:02 PM
supertj4415
supertj4415's Avatar
thats pretty strange.
Id make sure nothing is stuck/jammed in the hinges on the body. also try checkin the door surrounds, the are held on with the 2 large hand bolts the screw into the roll cage
2000 TJ Sport
3.5" RE SF-- LoD--35" BFGs--Pioneer System
FUTURE MODS:
44 front/9" rear w/ 4.88s and ARB
JEEPS won a war....your Honda mowed my lawn
supertj4415 is offline
post #3 of 7 Old 11-14-2004, 05:44 AM
Jeepin_Jeffster
Jeepin_Jeffster's Avatar
Have you ever removed or loosened the hinges on your doors? It looks like they are out of alignment. You should be able to loosen them, adjust the position of the door, then tighten them back up.
'01 TJ with mods... :)
White Jeep Club Member #22
Jeepin_Jeffster is offline
post #4 of 7 Old 11-14-2004, 09:48 AM
jeepin_coug
They're torx-40 screws. Make sure you don't strip them. I had to use a impact driver to get mine loose.
jeepin_coug is offline
post #5 of 7 Old 11-14-2004, 03:34 PM Thread Starter
Big Brutal
Big Brutal's Avatar
I brought it used in august. I just noticed it or it just happened. There isn't any damage to the door anywhere. I can't imagine that I would not have noticed that before. I was getting water in the drivers side.
I have never touched the hinges or any part of the door.
Do I adjust the the hinge side on the door? Also, will it slide as I unloosen the three bolts?
post #6 of 7 Old 11-14-2004, 05:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
With the door closed and latched, loosen the torx-head bolts on the door-side of the hinge slightly, just enough so you can move the door around. Center it up in the door frame then tighten the torx-head bolts real snug.
Jerry Bransford is online now
post #7 of 7 Old 11-14-2004, 05:26 PM Thread Starter
Big Brutal
Big Brutal's Avatar
Thanks for the info. I'll try to fix it tomorrow.
Adjust door latches Wrangler_91 TJ Wrangler Technical Forum 1 04-05-2009 01:49 AM
Door latch won't adjust right spd500 YJ Wrangler Technical Forum 8 12-07-2008 07:19 AM
how to adjust door strikers (the pins) cueball YJ Wrangler Technical Forum 4 05-11-2006 07:15 PM
How to adjust TPS Why J? YJ Wrangler Technical Forum 8 08-09-2005 11:52 AM
can you "adjust" half door hinges? hmk_21 YJ Wrangler Technical Forum 7 02-11-2005 12:28 PM
