Hot brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Hot brakes
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 07-20-2013, 02:04 PM   #1
johnnybonkel
2006 YJ Wrangler
Hot brakes
HOW HOT SHULD REAR DISK BRAKES GET UNDER NORMAL DRIVING?
When the caliper is removed and hand brake off...how freely should wheel spin ...mine is stiff?
If not freely could this heat build p be the e brake? Any advise on how fix?...thanks 2006 TJ Rubicon discs all round.
Cheers!
A
johnnybonkel is offline   Reply With Quote Quick reply to this message
Unread 07-20-2013, 02:19 PM   #2
JBTJ
Well I have drum brakes and there is a very slight to almost no drag. Sounds like the e brake is way to tight.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 07-21-2013, 06:30 AM   #3
johnnybonkel
2006 YJ Wrangler
THANKS...how do I fix (ive checked cable tension and thats OK)...thx
Unread 07-21-2013, 07:57 AM   #4
SlackJaw
baby jeep
SlackJaw's Avatar
There is a little oval rubber bootie on the back side. You take that off and it reveals a star wheel that you can turn with a adjustment tool or a flathead screw driver. Jack up the wheel(s) and spin while adjusting to find the right tension (or lack thereof).
I always find it difficult to get exactly right, and also figure out the right way to turn the star. Someone posted recently the direction to turn, but I think it's also possible to flip the adjuster so you might could go either way depending on how a PO may have put it back together
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline   Reply With Quote Quick reply to this message
Unread 07-22-2013, 04:24 PM   #5
johnnybonkel
2006 YJ Wrangler
HEY THANKS FOR THIS...I KNOW THIS IS TRUE FOR DRUM BRAKES BUT MINE ARE DISC SO IM ONLY TALKING ABOUT E BRAKE. I THINK THEY ARE MEANT TO SELF ADJUSTING...CAN I DO MINE AS YOU DESCRIBE....? (Just e brake)
Thanks
Unread 07-22-2013, 04:35 PM   #6
SlackJaw
baby jeep
SlackJaw's Avatar
Thanks
Yes, the ebrake on your disc brakes is a little version of drum brake inside the drum part of the rotor. Cute little shoes in there and everything. It is NOT self adjusting to the best of my knowledge. But the manual adjustment is identical for all intents.
Unread 07-22-2013, 04:36 PM   #7
J03_TJ
J03_TJ's Avatar
Thanks
E brake adjustment on rear disks is just like slack jaw said. Gotta turn that star wheel.
J03_TJ is offline   Reply With Quote Quick reply to this message
