HORRIBLE MPG Help - JeepForum.com
post #1 of 42 Old 01-30-2012, 03:01 PM Thread Starter
Doubblea
HORRIBLE MPG Help
I have a 99 wrangler tj with AEM air intake and banks header, 4.0L, and 3.5" lift with 33x12.5. I drive my jeep like a grandma and i still get around 10 mpg. most of this driving is going 55 to school. I realize i did not buy this jeep for mpg, but honestly 10? ive read of the normal being 15 and good around 20 on this forum. any suggestions on what to check or replace is greatly appreciated.
Doubblea is offline
post #2 of 42 Old 01-30-2012, 03:04 PM
Jrob05
Lugging the motor kills mileage, Lifts kill mileage, and so does a improperly calibrated speedometer.
Jrob05 is offline
post #3 of 42 Old 01-30-2012, 03:05 PM
rlkelley
i know this is a dumb question but how old is your air filter ? if its several years old and has never been cleaned or replaced it could affect mileage.
also, the lift doesnt help, but you should get more than 10 i would think. has the jeep ever had a tune up ? same factory plugs, wires etc........
rlkelley is offline
post #4 of 42 Old 01-30-2012, 03:06 PM
duhamel17
Not sure what gears you have, but I have a 3 speed auto with 4.10's and 33's. With this combo I am getting about 12mpg on a good day. I think this has a lot to do with the three speed auto tranny. That is all I now on that. I hear about some people getting 20 or better, but not sure if that is actually possible.
duhamel17 is offline
post #5 of 42 Old 01-30-2012, 03:40 PM
schwany01
i get 10mpg with a 4 inch lift and 33s, stock gears with D44, with 31s for the winter i get 13-15mpg
schwany01 is offline
post #6 of 42 Old 01-30-2012, 03:52 PM
jkiech
From what I've learned either drop down to smaller tires or re-gear to different gears like 4.56's.
96 ZJ - FOR SALE! 3300 OBO! Message me for details or visit the classifieds!
jkiech is offline
post #7 of 42 Old 01-30-2012, 04:29 PM
Dangermouse
I used to get that but now it's up to 11 mpg. Sounds normal to me.
Dangermouse is offline
post #8 of 42 Old 01-30-2012, 06:49 PM Thread Starter
Doubblea
First off I would like to thank everyone for the replies. I have 3.07 gears, and the 5 speed ax15. I cleaned the air filter out a month ago when I bought the jeep. I do not know if they are the factory plugs or wires, anyone know what to look for on that?
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
Doubblea is offline
post #9 of 42 Old 02-03-2012, 05:44 PM
ACRay
4'' lift, 33'' BFG KM2s, 4.56 gears in my 06 TJ with a 4.0 and an automatic with a correctly calibrated Speedo (GPS checked with 3 different GPS units) and I get almost 19 mpg..... maybe I'm the exception, either way, I win
ACRay is offline
post #10 of 42 Old 02-03-2012, 05:50 PM
vanek11
Important...Check to make sure the speedo is correct. I thought the same also but then realized my speedo is about 10% off. I have a 4" lift and 33" tires also. Just calculated roughly yesterday and found to be getting 14mpg in 75% city driving. When I am going 50 I am actually going 55, so assuming that the odometer is also going to be off, meaning if I travel 50 miles I am actually going 55 miles. Someone correct me if I am wrong but if the speedo is off it would be common sense to me that the odometer would also be off. I am happy at 14mpg with the lift and tires and not driving easy.
vanek11 is offline
post #11 of 42 Old 02-03-2012, 05:51 PM
FZY1
You Drive a Jeep, with the aerodynamics of a brick.
FZY1 is offline
post #12 of 42 Old 02-03-2012, 05:56 PM
hesterj
I really thought this was a joke....like all the other million same posts here.
FIX IT TILL it's broke
hesterj is offline
post #13 of 42 Old 02-03-2012, 06:17 PM
cjtheodo
Check your rpms when driving.It seems that to get better gas mileage it needs to be around 2200-2800. There are different ways to get it there.
cjtheodo is offline
post #14 of 42 Old 02-03-2012, 06:19 PM
djflyy
Your problem is the same as every other person that has created one of these threads (scroll to the bottom here and click ANY of the resembling thread links).
- Check your speedometer gear, make sure it's appropriate for your tire size and axle ratio. There's also a speedo swap thread on here, you might be able to get one for free.
- Swap your plugs for new ones. AutoLite is a favorite of many. Get a new distributor cap, and new plugs. Below is a pic of the old ones from my TJ just to give you an idea.
- Make sure your tires are appropriately inflated (read: do not overinflate)
- Check air filter condition
- Re-gear.
djflyy is offline
post #15 of 42 Old 02-03-2012, 06:21 PM
DevilDogDoc
I have the same setup as you but without the bull**** "power adders", running 33/11.5's and I get 15 MPG all day everyday. Look at tuneup stuff first....
An ugly Jeep with some stuff.
DevilDogDoc is offline
help needed , mpg , tj , wranger
Horrible Gas Mileage??? WJL TJ Wrangler Technical Forum 56 11-13-2010 09:24 PM
Horrible Mpg bushusmarine TJ Wrangler Technical Forum 19 01-27-2010 02:09 PM
Horrible shackle angles, horrible flex, horrible ride... SleddinJeeper YJ Wrangler Technical Forum 29 10-12-2008 09:39 PM
how horrible is it? brundz TJ Wrangler Technical Forum 7 06-10-2008 07:53 PM
Horrible Horrible Chirping msumike1 TJ Wrangler Technical Forum 21 02-15-2008 02:22 PM
