#1 | |
Horrible Horrible Chirping
I know I have seen something about this before, but I can't find the thread today....
My '06 Wrangler X has a horrible "chirp / squeek" noise. The sound seems to be coming from deep in the dash behind the center A/C panel. I have done some digging, pulling, and holding to try to stop the noise...it has not helped. It sounds like a metal on metal chirp. It's at its worst when driving on bumps, but also happens a bit during acceleration. The best solution so far is to either take the top off or turn up the radio.....I need something better. Suggestions??? thanks in advanced.
#2 |
i have the very same thing going on, have you had the door off or the window down since this has started? i originally thought mine was coming from in the dash till i had the window down and now i think its coming from the underbody.
#3 |
when does it make the noise?
#4 |
If it only makes the noise while the vehicle is moving then its the CV joint in your front driveshaft.
#5 |
what is the easiest fix, and by easiest i mean not expensive
#6 |
Do it right or not at all
![]() Join Date: Jan 2003
How many miles are on your '05? Do you do much offroading where your driveshaft could be immersed in mud or muddy water?
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#7 |
Is your heater or your fan motor on? Since you mention it's behind the dash, perhaps for some reason the blower motor is not up to par and causing some noise.
'01 TJ & '97 ZJ |
#8 |
This may be something totally different, but could be worth a try:
I had something similar happen the last time I was wheeling - turns out the front differential didn't fully disengage after the last time I took it out of 4WD. It was the most Godawful chirping/grinding noise I had ever heard. I stopped, re-engaged the front end, disengaged it again, and everything was back to normal.
[SIZE="1"]04 X Columbia Edition[/SIZE] Last edited by Igetit; 02-04-2008 at 07:50 PM.. |
#9 |
I know you mentioned that you think it's coming from behind the dash, but the softtop latches on the windshield frame do this on mine. Took me forever to figure out what is was. It was fixed with a little grease.
Does it do with the top down?
[b]'97 TJ[/b]: 2.5L, 4" Lift, 1" BL, 1" MML, 35's, 4.88's, Locker & Trutrac, Snorkel, Winch, Rockers, Snorkel, etc... [b]'06 XK[/b]: Limited HEMI 4x4 with QDII - DD [url]www.cypressoffroad.com[/url] |
#10 | |
![]() ohh and it has around 21,000 miles on it |
#11 |
Yeah that kind of regular mud immersion is really harsh on u-joints and the CV joint itself. I wouldn't doubt your driveshaft needs to be rebuilt with a new CV and u-joints. When those go bad, it causes the dreaded "angry sparrows" sound that sounds like what you're describing.
Personally I avoid mud at nearly all costs. ![]()
#12 |
I had a similar issue in my 06, one of 3 of the bolts that holds the air box to the fender lost it's nut, it was horrible and annoying $1.00 fix at home depot...I originally thought it was suspension, dealer thought it was brakes and turned the rotors...
Fix Thread (with pics) http://www.jeepforum.com/forum/f9/found-my-squeek-squeak-1-00-fix-495220/
2006 Wrangler X, 6 speed manual 4.0 I6, BFG T/A's 31x10.50x15 on Promcomp )97 Soft 8 Steelies, stock sunrider soft top, KC Replacement fogs, westin step bars (yeah I know). RED JEEP CLUB MEMBER #442 |
#13 |
im having the same problem, except its only when the clutch is out, as soon as i put even the slightest pressure on the clutch, it stops, it sounds like a shaft spinning on a chalkboard with pieces of chalk glued to it, or like a canary in my transmission, please, make the noise stop!!!!!
1946 CJ-2A 225/T90/D18 1966 CJ-5 231/T86/D18 1986 CJ-7 258/TF999/D300 1984 C-10 6.2/SM465 Yeah it's a Diesel |
#14 | |
edit: I took a call while I was posting, didn't realize the most probably answer was already posted, lol.
YELLOW Jeep Club Member #5606 13 mpg - edit: 12 mpg No hi-lift on the hood (yet) Odd noises Still can't get it to take off from a treadmill.... Last edited by GringoLoco; 02-04-2008 at 08:29 PM.. Reason: Failure to submit post in a timely manner. |
#15 |
One thing about clutch problems after wheeling in deep mud... the secret (ok, not so secret) is to not push in on the clutch pedal when the tranny is in deep mud. Doing so just allows mud to flow in between the clutch and pressure plate. Don't shift gears in mud, and if it stalls don't push in the clutch to start the engine. Keep it in 1st gear while you're in mud so if it stalls, leave it in 1st gear and just re-start it while it's in gear without stepping on the clutch. You DID already insert the fuse so you can start your TJ without stepping on the clutch didn't you?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
