Horn wont work, relay and fuse ok and horn works if direct wired - JeepForum.com
post #1 of 6 Old 01-01-2010, 07:52 AM Thread Starter
Redskin
Can someone help?
The horn works if direct wired. the fuse and relay work, must be a problem in the steering wheel but pulled it apart and can find anything, airbag 1997 renegrade.
Redskin is offline
post #2 of 6 Old 01-01-2010, 08:03 AM
southernss
clockspring is bad.
southernss is offline
post #3 of 6 Old 01-01-2010, 08:59 AM Thread Starter
Redskin
how do you fix that?
Redskin is offline
post #4 of 6 Old 01-01-2010, 09:08 AM
Pillswoj
Order a new clockspring and install it.
Friends don't let Friends run Bosch
Pillswoj is offline
post #5 of 6 Old 01-02-2010, 12:07 PM
southernss
order new clockspring from dealership.
make sure wheels are straight.
disconnect battery and let sit for 5 min
take shroud off steering column
take 2 screws out from under steering wheel which hold the airbag in place
unbolt steering wheel and set aside
unclip clockspring and replace with new one then reassemble everything.
post #6 of 6 Old 01-02-2010, 04:24 PM
Slithering_Joe
Slithering_Joe is offline
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 02:11 PM
tilt steering wheel horn wont work m_t_r_86 YJ Wrangler Technical Forum 2 09-01-2009 07:27 PM
Horn Wont Work... TjWranger98 TJ Wrangler Technical Forum 9 07-14-2009 04:05 PM
Horn relay and fuse Yeti342 TJ Wrangler Technical Forum 2 03-26-2007 08:59 AM
Horn not working......not wires, fuse or relay. luv2hmr TJ Wrangler Technical Forum 12 04-12-2006 03:33 PM
