Horn Wont Work... - JeepForum.com
post #1 of 10 Old 08-02-2006, 10:58 PM Thread Starter
TjWranger98
Horn Wont Work...
Hi I just bought a jeep yesterday and one of the problems with it is that the horn doesn not work...
what do you think some of the reasons the horn wouldnt work and how can i get this working soon so i can pass inspection!!
thanks
TjWranger98 is offline
post #2 of 10 Old 08-02-2006, 11:24 PM
UCTJ
UCTJ's Avatar
Have you tried the fuse behind the glove box? Replace that one first, if it doesnt work under the hood there is another fuse block open it up and replace that one...most likely its the one behind the g-box.
UCTJ is offline
post #3 of 10 Old 08-02-2006, 11:25 PM
thesherm
thesherm's Avatar
try the relay under the hood. swap it with one next to it and see if it works
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline
post #4 of 10 Old 08-02-2006, 11:38 PM
ixl4
ixl4's Avatar
2015 JK Wrangler
sounds to me like a time for an upgrade dear sir... i'd go with a train horn myself
DR. Z MUST BE STOPPED Club Member # 1
CJC website:
2000 Sport Manual.
Mods: RE 3.5 / JKS 1.25" BL / M.O.R.E. 1" MML / Rough Country Adjustable Trackbar / Dunlop Rover 33s Cragar 397 Soft Wheels / Winch / Nates4x4 Front Bumper & Rear w/ Tire Carrier / RE .75" Spacers / P.O.R.C. SYE / RE CV DS / Nth Degree Adjustable Rear Upper Control Arms / SkyJacker Front and Rear Lower Arms
ixl4 is offline
post #5 of 10 Old 08-03-2006, 12:58 AM
mingoglia
You could always get one of those, "horn broke, watch for finger" bumper stickers. Come on, I couldn't resist. . .
Mike
mingoglia is offline
post #6 of 10 Old 08-03-2006, 04:27 AM
cwlongshot
cwlongshot's Avatar
Fuses are the best place to start......
Its possible the PO dis mantled it....TJ's have a problem with the button over the airbag. the factory uses a cheap opencell foam to keep the contacts seperated. when the TJ is left with te top off alot the sun's heat deteriates the foam. causing the horn to blow all by itself at 03:00 hrs!!!
I pulled the horns relay out to kill mine. Its in a blk box on the pass side inner fender well.
Just ask me how I know.....
I know have a button on my center console as I waasnt going to pay $60 for a new cover!!!
CW
'99 TJ 4.0 5 spd D30 W/AUSSIE & 8.8 W/ECTED 4:10's
'89 MJ 4.0 AW4 Hi-Pinion D30 with SPARTAN D44 W/DETROIT LOCKER 4:56's
cwlongshot is offline
post #7 of 10 Old 08-03-2006, 04:30 AM
ncb76
ncb76's Avatar
Check the fuses, like everyone else said. Also, if you push the horn button, you should be able to hear the relay "click" if it's getting power. If you have a meter or test light, the easiest thing to do would be to check for power at the horn. Mine went dead a while back and I've never gotten around to replaceing them. I like the idea of an air horn.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
post #8 of 10 Old 08-03-2006, 08:21 AM
jeeptj19992001
Clock Spring Is Bad
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #9 of 10 Old 08-03-2006, 08:45 AM
NWilhelm
yeah my jeep got wet the other day and the check engine light came on. It turned out to be the clock spring. Now cruise control works fine but the horn wont work. I bet its the clockspring, like 19992001 said.
Nick
: Black Hard Top/Strapless Bikini/Viking Fast Back Top | Warn Rock Crawler Front Bumper | Homemade Rear Bumper | Black Herculiner interior | Rokmen Rear Corner Guards |
NWilhelm is offline
post #10 of 10 Old 07-14-2009, 04:05 PM
jonegar
Glove Box Relay Center
I have been searching for a diagram indicating what is what in the relay center located inside the glove box on my recently aquired 93 GC Ltd. When the horn button is pressed the fuse blows (#13 in the passenger side of dash I believe) I replaced what I'm assuming was the horn relay in the "power distribution center" as it is called in the manual (also referenced in the Haynes book I bought) but the there was no change - hit the horn button, relay clicks, and "pop" goes the fuse. Anyone have a diagram to this relay block? Anyone have any other ideas to look for?
jonegar is offline
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
tilt steering wheel horn wont work m_t_r_86 YJ Wrangler Technical Forum 2 09-01-2009 07:27 PM
YJ Horn Will Not Work mpd295 YJ Wrangler Technical Forum 15 03-22-2009 07:05 PM
Horn doesn't work... Aiden80013 TJ Wrangler Technical Forum 9 12-22-2008 02:05 PM
My horn doesn't work! geusey YJ Wrangler Technical Forum 9 07-27-2008 01:52 PM
