Horn not working......not wires, fuse or relay. - JeepForum.com
post #1 of 13 Old 04-12-2006, 02:38 PM Thread Starter
luv2hmr
Have a '98 TJ that the horn just stopped working. I've checked the wiring, fuse and relay but still no horn. Anyone have any ideas?
luv2hmr is offline
post #2 of 13 Old 04-12-2006, 02:39 PM
de6w6it
Check the contacts in the steering wheel, what actually contacts when you push on it, they could be not making a good connection.
'66 Mustang/200/C4/ground up resto
'88 4 runner/SAS/22re/W56/duals/31's DD
Build:
de6w6it is offline
post #3 of 13 Old 04-12-2006, 02:41 PM
Blake Rust
Blake Rust's Avatar
could be the airbag clockspring...there are other writeups...HERE is one.
like anything else, pretty expensive if done by dealership
EDIT: When my brother had this problem on his XJ, we just mounted a new horn button on the dash to keep him legal...it was a much cheaper solution.
Blake Rust is offline
post #4 of 13 Old 04-12-2006, 02:49 PM Thread Starter
luv2hmr
Is it possible to do this myself and not disturb the airbag?
luv2hmr is offline
post #5 of 13 Old 04-12-2006, 02:57 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Have someone push the horn button repeatedly on-off while you measure on the horn relay to see if it's getting anything from the horn button. One side of the relay needs 12 volts, the other side needs a ground. If it's getting both and the horn isn't getting 12 volts, the relay is bad. If the horn is getting 12 volts, the horn is bad.
Jerry Bransford is online now
post #6 of 13 Old 04-12-2006, 03:06 PM
novajeep
Sounds like the clockspring There was a service bulletin for it.
I had to replace mine. The airbag comes out easily and it stays contained. That being said, I wouldn't play catch with it once it's out or anything like that.
novajeep is offline
post #7 of 13 Old 04-12-2006, 03:17 PM Thread Starter
luv2hmr
I replaced the relay and it still doesn't work.........so i'm looking at other options.
luv2hmr is offline
post #8 of 13 Old 04-12-2006, 03:19 PM Thread Starter
luv2hmr
So how hard is the Clockspring to change yourself?
luv2hmr is offline
post #9 of 13 Old 04-12-2006, 03:20 PM
Jerry Bransford
Administrator
Sure but did you troubleshoot the horn circuit like I suggested?
post #10 of 13 Old 04-12-2006, 03:22 PM
gUanoTJ
Not to hijack, but since we're on the topic... what if the horn goes off randomly and will not shut off. I had to pull the relay just to make it stop. Any ideas guys??
gUanoTJ is offline
post #11 of 13 Old 04-12-2006, 03:24 PM Thread Starter
luv2hmr
No.....I'll give that a try.
Thanks!
luv2hmr is offline
post #12 of 13 Old 04-12-2006, 03:31 PM
novajeep
"So how hard is the Clockspring to change yourself?"
It's been a few years, but I remember it being very easy. You may need a steering wheel puller. I remember borrowing one, but can't remember if I used it. I think the Haynes manual had a section on pulling it apart. The part was between $60 and $100, and I got it from the dealer.
Sorry, but I can't really remember the details. The airbag comes out easily, and in one piece, then I think the clock spring is right under it.
It's not a repair to be scared of. That's coming from someone who is a true novice.
novajeep is offline
post #13 of 13 Old 04-12-2006, 03:33 PM Thread Starter
luv2hmr
Great....Thanks!
luv2hmr is offline
Horn wont work, relay and fuse ok and horn works if direct wired Redskin TJ Wrangler Technical Forum 5 01-02-2010 04:24 PM
Horn wires '99xjlimited YJ Wrangler Technical Forum 16 12-07-2007 07:25 AM
Horn relay and fuse Yeti342 TJ Wrangler Technical Forum 2 03-26-2007 08:59 AM
Tail lights not working ( hbl, switch, fuse and relay) JESSETHELJ TJ Wrangler Technical Forum 1 09-03-2006 12:48 AM
Wires to Horn sandman'sjeep YJ Wrangler Technical Forum 2 10-17-2005 06:11 PM
