Hood Vent/Louvers question - JeepForum.com
 79Likes
post #1 of 113 Old 08-15-2017, 12:33 PM Thread Starter
Bigb75i
Hey guys... just wanted some feed back... i want to do hood vent/Louvers... but everything i see allows water or snow to enter the engine bay. So i did some research and found these. They are from eTrailer and they are use for trailers for venting. I liked they way they would work on the Jeep. Cause i can manually close them when the weather does not cooperate. What do you all think?
never look back your not going that way!
Bigb75i is offline
post #2 of 113 Old 08-15-2017, 12:36 PM Thread Starter
Bigb75i
Here is the link
https://www.etrailer.com/RV-Vents-an...xoCotYQAvD_BwE
Bigb75i is offline
post #3 of 113 Old 08-15-2017, 12:41 PM
Ironhead
water in the engine bay is a non issue. anytime you drive through a puddle the engine bay gets soaked. i've had genrights 3 vent kit on mine for 4+ years
Ironhead is offline
post #4 of 113 Old 08-15-2017, 12:48 PM
TJnBC
YUP ^^^^
No issues running hood louvers on several Jeeps. Water gets in anyways
2006 LJR...the madness begins again
TJnBC is offline
post #5 of 113 Old 08-15-2017, 01:41 PM
b00mb00m
I kind if like the dragon nostril look.
b00mb00m is offline
post #6 of 113 Old 08-15-2017, 02:58 PM
Chrisnvegas
Chrisnvegas's Avatar
What's it for?
My Jeep is NOT a Fiat!
Chrisnvegas is offline
post #7 of 113 Old 08-15-2017, 03:07 PM Thread Starter
Bigb75i
Originally Posted by Chrisnvegas View Post
What's it for?
To allow heat to escape from engine bay.
Bigb75i is offline
post #8 of 113 Old 08-15-2017, 04:25 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
I like them, but couldn't you (shouldn't you) rig up an a-frame on the hood with a series of pulleys and a nylon rope back into the cab so you can open them manually without getting out of the jeep? Say you are wheeling extra hard that day and you are on a super tough rock, you could pull the nylon rope, and actuate the pulley system, and then they would be opened and save your engine from all that heat without having to leave your drivers seat. Or better yet, an electrical solution of relays and electric motors for both up and down (open/close) of the covers. I bet you could wire that in about an hour.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now
post #9 of 113 Old 08-15-2017, 04:48 PM
jjvw
jjvw's Avatar
I don't like them at all. They look like dryer vents. Never mind that you are solving a problem that doesn't exist. Your engine gets wet from below every time you drive in the rain.
Chrisnvegas and Shark_13 like this.
2003 Rubicon
jjvw is online now
post #10 of 113 Old 08-15-2017, 05:28 PM
MarioM0one
Priceless!
Chrisnvegas likes this.
MarioM0one is offline
post #11 of 113 Old 08-15-2017, 05:29 PM
tjcj
Looks like ghetto Fab. I have louvers on my hood and yes the engine does get wet but guess what , It got wet before I added the louvers also. Every puddle you drive through enters via the wheel wells .
Sent from my phone using JeepForum
Tophog1 likes this.
Yakima Valley Mountaineers.
tjcj is offline
post #12 of 113 Old 08-15-2017, 06:18 PM
Chrisnvegas
I considered hood vents. But there is several square feet of open, unobstructed space under our Jeeps where the 4000+ cfpm fan quickly blows radiator wash and excess engine heat.
When the engine is off, I suppose it allows some heat to escape.
Are the vents to make the owner feel better?
Is the engine negatively affected by heat when we park?
Living about an hour from the hottest place in the hemisphere and never experiencing heat related issues, I question the need to cut holes in the hood to "let the heat out"
In fact, maybe the factory engineers who are here where I live right now testing and experimenting with new vehicles intended to direct the heat down and out vs. up.
Maybe they want that rush of belt driven air to wash over the exhaust manifold and exit away from the intake or fuel rail.
I don't know.
I do know if rain or snow creates issues, there's a problem.
post #13 of 113 Old 08-15-2017, 06:30 PM
biffgnar
biffgnar's Avatar
There are things other than the engine under the hood that benefit from staying cooler. Heat rises so addition of vents in the hood let's quite a bit out. Personally I see it as akin to preventative maintenance. And I don't see a downside even if we're wrong and there is no upside.
Mud Machine and Tophog1 like this.
biffgnar is offline
post #14 of 113 Old 08-15-2017, 06:48 PM
TheBoogieman
Made in the USA
TheBoogieman's Avatar
The Mother of Dragon's would like them. Me, not so much.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
TheBoogieman is offline
post #15 of 113 Old 08-15-2017, 07:01 PM
jjvw
jjvw's Avatar
Heat makes plastic brittle and our TJs are getting old. I do feel better believing that my plastic connectors in the engine bay will survive that much longer.
Tophog1 likes this.
2003 Rubicon
jjvw is online now
