Hood louvers... Do they really work? - Page 7 - JeepForum.com
post #91 of 241 Old 08-29-2010, 11:09 PM
chmo
wrapping the headers like showed above might be worth a thought WHEN they crack and the replacement effort has to be made. (for me at least)
wondering though if wrapping the headers might mess things up?:
if wrapped to tightly for sure the expansion characteristics of the headers change ... more and different cracks?
I have seen somewhere a header heat shield which is more like "socks" or "bags" or so to keep only a loose contact with the headers and still encapsulate them... EXPENSIVE
chmo is offline
post #92 of 241 Old 08-31-2010, 11:54 PM
Night Wolf
Originally Posted by Knuts View Post
It's my Sirius Satelite Radio Antenna. Can't wheel without a good sound track man. I got lucky with my hood. I had a slight run in with a 5 ton truck and a brick wall. The Jeep lost that fight but I got my AEV hood out of the deal. I think all in hood and paint you would be looking at a little under a thousand dollars. I bought it for the apearance and not the heat reduction though. The two bumps on the hood look mean from the side.
You do know the antenna can be mounted on the roll bar, under the zippered cover and will pick up signal just fine with a hard or soft top, right?
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #93 of 241 Old 09-01-2010, 04:50 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
I assume adding vents would help an issue I'm having. When on a long trip on the highway on a hot day, my A/C feels cold but even with the blower turned all the way up it's hardly blowing any air out (like it's on low). I have assumed the engine is running too hot and the computer (?) cuts the A/C for that reason? The A/C later returns to normal.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #94 of 241 Old 09-01-2010, 07:49 AM
base shakers
i used perforated metal from mcmaster. someone in my club coined them "stealth vents"
while they did not make a dramatic difference in engine temp, the underhood temp was reduced. i was melting all sort of stuff underneath and since i put in the hood vents it has been relatively cool in the engine bay.
'05 LJ, ~4" lift, 35X12.5 Toyos, 16" beadlocks, HPD44, HPD60, 4-speed Atlas, 4.6L stroker
base shakers is offline
post #95 of 241 Old 09-01-2010, 09:02 AM
NotURMailman
NotURMailman's Avatar
^^^ details on how you cut the holes. I have thought of doing that, but was afraid I couldn't make the holes that pretty...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #96 of 241 Old 09-01-2010, 10:15 AM
base shakers
i used a step drill to make the corners and then a metal shear for the sides. (use plenty of painters tape to protect the metal) that way it stayed cool and i only had to paint the cut edge. hardest part was measuring 15 times so i didn't screw it up.
post #97 of 241 Old 09-01-2010, 10:17 AM
NotURMailman
Air sheers?
post #98 of 241 Old 09-01-2010, 10:36 AM
base shakers
electric actually. but my guess is either should work fine.
post #99 of 241 Old 09-01-2010, 01:35 PM
CCGRUNT0331
Installing mine today (between 2 and 4am I guess), I am planning on symmetry therefore my rear driver and passenger (Genright 3pc long black) will be moved a little more forward just so the pass louver isnt directly over battery terminals or fuse box. Will post pics during and after
To the guys that wrapped their manifolds and whatnot... I have read that over time moisture (rain,washing) will soak the wraps and it ends up rusting the wrapped piece in 10x the time, have yall checked them lately to confrim or deny?
2000 TJ Sport: SOLD!
2008 JKU Rubicon: aka 'Bruiser'
CCGRUNT0331 is offline
post #100 of 241 Old 09-01-2010, 01:57 PM
Deacon
Shining Adonis
Deacon's Avatar
I'm subscribing because this sounds interesting as all hell
Deacon is offline
post #101 of 241 Old 09-01-2010, 02:53 PM
05TurboS2K
With a deep understanding of this particular topic, YES THEY WORK, assuming they're done correctly.
I have accurate intake temp data logs to prove as well as a dyno-sheet showing a 7-10whp gain.
Also to the guy above who went to mcmaster carr to get that aluminum sheet, I went to the same place when I first vented my own sports car hood. I used a snap-on brand air saw to cut the holes and found a clever way to attach them without using any screws etc. Also I can show you how to build slip on cover that needs no holes to help with muddy days if you wish your engine compartment to stay clean. Rain is no worry, even in Seattle where I lived prior.
-Greg
05TurboS2K is offline
post #102 of 241 Old 09-01-2010, 03:08 PM Thread Starter
TeeJay00
But don't place them too forward though. You don't want water going in the air intake . BTW water will not harm your fuse because they covered up.
If you read the first few posts here you would see pictures showing the hot spots under the hood. You should stick to that when placing those vents.
TeeJay00 is offline
post #103 of 241 Old 09-01-2010, 03:11 PM Thread Starter
TeeJay00
If you want to see the end result of the install, I have posted a link to the install in page 6 post #84
TeeJay00 is offline
post #104 of 241 Old 09-01-2010, 03:14 PM
CCGRUNT0331
ya Im basically following this layout
post #105 of 241 Old 09-01-2010, 03:15 PM Thread Starter
TeeJay00
That's exactly how I did it
TeeJay00 is offline
hood , louvers , TJ
hood vents/louvers sgarhaereanh TJ Wrangler Technical Forum 1 04-17-2010 03:04 PM
hood louvers base shakers TJ Wrangler Technical Forum 38 04-15-2010 10:35 AM
Hood Louvers Anyone? DARKBLUETJ TJ Wrangler Technical Forum 9 03-11-2009 06:58 PM
Hood Louvers ThUmPeRcOn TJ Wrangler Technical Forum 30 07-07-2008 10:45 AM
Gen-Right Hood Louvers Linda or Greg TJ Wrangler Technical Forum 6 10-06-2006 07:29 AM
