Hood louvers... Do they really work? - Page 4 - JeepForum.com
post #46 of 241 Old 07-09-2010, 10:31 AM
Sundowner
There's another thread going right now about a cowl intake using the Windstar airbox...and the topic of heat soak through the intake tubing came up. The consensus - myself aside - was that the air velocity through the intake was too quick to allow any heat soaking. Now, physically, I know this can't work, but I was tired of arguing at that point. No dyno sheet and no fuel usage data = subjective opinion, not fact.
Sundowner is offline
post #47 of 241 Old 07-09-2010, 10:37 AM
J03_TJ
Sorry, just making a funny here. Do you have any facts that proves any other consensus?
I think you probably found the link that we had seen, yep no hard data that I could find either, just impressions.
Doesn't really sound like too many drawbacks except you have a little cooler air coming in and have to remember what type of air filter you have.
J03_TJ is offline
post #48 of 241 Old 07-09-2010, 03:07 PM
Robert J. yates
I have a Scanguage hardwired into my rig and I can monitor IAT temps real time. Wrapping my intake tube took me all of 10 minutes so the weather and temp variables were unchanged when I measured the results.
Robert J. yates is offline
post #49 of 241 Old 07-09-2010, 03:31 PM
TJeeper
TJeeper's Avatar
Originally Posted by stogie25 View Post
That is brilliant. My current "hot air intake system" does not lend itself to that, but it is a really good idea.
I had a similar intake on my TJ. I pulled the filter and put in this one. Also wrapped it thermo tape.
I didn't check my before and after intake temps like Robert did, but it did make a difference on hills at highway speed in the summer.
Patrick
TJeeper is offline
post #50 of 241 Old 07-09-2010, 04:23 PM Thread Starter
TeeJay00
Why would you want to monitor the intake air temp??
TeeJay00 is offline
post #51 of 241 Old 07-09-2010, 05:01 PM
bandit455
That is exactly what it is.
haha, yep, a semi common issue in them xj's, you'll see popped hoods all day long when its 90+
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #52 of 241 Old 07-09-2010, 10:15 PM
Sundowner
That's about the sum of it. And any cooler air is good, in my opinion...I'm just not counting on lots of power from it.
As far as data for proving heat soak is concerned, it's simple conduction and convection. There's no way air of a given temperature can contact/pass over a surface of a differing temperature and not be affected. It's simple energy transfer, and it has to do with one of those pesky laws that make up "science." Now, it might be a very, very slight change in our case of intake tubes, but it does happen. Nitpicking, I know.
I think the cowl intake, along with an insulated intake tube and good louvers would make a very effective way of lowering the temperature in the intake. Of course, the intake itself will get hot, but it will also be radiating that heat back out into air that's much cooler...again, simple conduction and convection.
post #53 of 241 Old 07-09-2010, 10:59 PM
J03_TJ
I agree. Not sure it matters at all though with this 4.0. Too many of them on the road without this mod.
J03_TJ is offline
post #54 of 241 Old 07-10-2010, 05:49 AM Thread Starter
TeeJay00
Yes can we get back to the louvers please? Thank you
Now according to your experience guys. Which of those two types of hood louvers would have the best results in lowering the engine heat temps??
TeeJay00 is offline
post #55 of 241 Old 07-10-2010, 07:45 AM
Sundowner
I'm sorry if that sounded off-track. I was trying to talk about the effectiveness of those exact objects towards a specific goal. I mean, if they don't serve a function, then what's the point? Looks?
Towards answering the above question: the first set. They can be located at the hot spots. The raised hood panel - to my understanding - is not the ideal location.
post #56 of 241 Old 07-10-2010, 07:57 AM
bandit455
i got a buddy that installed the lower one, hyline offroad is semi local to me, and another buddy actually donated an xj to them so they could develop xj louvers and eventually bumpers.
that being said I think either will be just as effective. just a space for the air to escape is really whats necessary so its up to you and your style of how you want to do it.
post #57 of 241 Old 07-10-2010, 07:59 AM
Dryseals
1980 CJ7
I guess my concern is for rain. We get a lot of it here and some times it severe.
My hood paint is faded right were the hot spots are, it needs repainting, may as well add some vents, but I'm worried about the wet stuff.
Dryseals is offline
post #58 of 241 Old 07-10-2010, 09:05 AM Thread Starter
TeeJay00
That is exactly my situation And the water getting to the engine either from rain or from washing the car is a good thing to think about!!!
If I went with the Gen-rights (the 3pcs) the passenger side vent will be right above the fuse box, the battery and the coil packs. Wouldn't this effect any of those? Of course there is a way to avoid this by installing a drain plate underneath the louvers, right?
TeeJay00 is offline
post #59 of 241 Old 07-10-2010, 09:17 AM
bandit455
but those drain plates kind of make the louvers useless...
post #60 of 241 Old 07-10-2010, 09:21 AM Thread Starter
TeeJay00
No they won't... You're not gonna stick them right on the louvers! half an inch between them would do just fine for air to get out as you move.
TeeJay00 is offline
hood , louvers , TJ
hood vents/louvers sgarhaereanh TJ Wrangler Technical Forum 1 04-17-2010 03:04 PM
hood louvers base shakers TJ Wrangler Technical Forum 38 04-15-2010 10:35 AM
Hood Louvers Anyone? DARKBLUETJ TJ Wrangler Technical Forum 9 03-11-2009 06:58 PM
Hood Louvers ThUmPeRcOn TJ Wrangler Technical Forum 30 07-07-2008 10:45 AM
Gen-Right Hood Louvers Linda or Greg TJ Wrangler Technical Forum 6 10-06-2006 07:29 AM
