Hood louvers... Do they really work? - Page 3 - JeepForum.com
post #31 of 241 Old 07-08-2010, 08:26 PM
Sundowner
It has to do with lowering underhood temperatures, yes...my real interest is in lowering the manifold temperature and keeping less of a load on the cooling system.
Sundowner is offline
post #32 of 241 Old 07-08-2010, 08:28 PM
Apex
Recon death squad
Apex's Avatar
A few weekends ago I wheeled all weekend in the Badlands and I was one of a couple of Jeeps experiencing vapor lock...I had this same issue last year in Uwharrie.
I need to remedy all of this.
Apex is offline
post #33 of 241 Old 07-08-2010, 09:13 PM
Border Dave
Got Sand?
Border Dave's Avatar
Are you sure it's vapor lock? I've read it's extremely rare in fuel injected vehicles.
Border Dave is offline
post #34 of 241 Old 07-08-2010, 09:23 PM
Apex
Recon death squad
Apex's Avatar
Start on the second try, would barely idle, had to kind of smash the gas peddle to blow it out and get it to idle.
All symptoms were amplified by 100 when trying to start it with the ac on.
Apex is offline
post #35 of 241 Old 07-09-2010, 12:16 AM Thread Starter
TeeJay00
What is vapor lock??
TeeJay00 is offline
post #36 of 241 Old 07-09-2010, 12:19 AM
bmxrules39
Originally Posted by stogie25 View Post
I did home made vents. Using my Scangauge II to monitor the intake temperature the vents lowered the temperature approximately 30 degrees. I had my hood off last week while it was getting repainted, and the temperature went down another 30 degrees on average.
How did you attach the screen thats inside the hood?
wHitt
bmxrules39 is offline
post #37 of 241 Old 07-09-2010, 12:19 AM Thread Starter
TeeJay00
Originally Posted by Robert J. yates View Post
... I have my tranny cooler separated out of the radiator...
How did that work out for your tranny? Did you notice a big drop in tranny temp??
TeeJay00 is offline
post #38 of 241 Old 07-09-2010, 05:11 AM
bandit455
there was actually a tsb about it for some of the later xj's, so its possible with the 4.0's. I have heard it has to do with the gas boiling in your fuel rail. A common fix is to acutally header wrap your rail, or to install louvers like these
Eagle scout jeeper #10
The Things We Make, Make Us
bandit455 is offline
post #39 of 241 Old 07-09-2010, 06:47 AM
2005X
i used RTV sealant on mine.
2005X is offline
post #40 of 241 Old 07-09-2010, 06:56 AM
stogie25
stogie25's Avatar
The screen sticks in at the bottom and the back. I used black duct tape for the top and the front.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread
stogie25 is offline
post #41 of 241 Old 07-09-2010, 09:14 AM
Apex
Recon death squad
Apex's Avatar
That is exactly what it is.
Apex is offline
post #42 of 241 Old 07-09-2010, 09:47 AM
Robert J. yates
One quick way to reduce intake and manifold temps is to wrap the intake tube with header wrap or a insulated foil backed product from Thermotec. That right there dropped my intake temps 50*.
As for the person who asked about separating my tranny cooler out from the radiator.... I live in a desert so I am not to worried about cold temp warm up. With dual coolers and 1 of them fan driven.... My trans temps are typically in the 150-165* range with the fan rarely engaged.
Robert J. yates is offline
post #43 of 241 Old 07-09-2010, 10:03 AM
Sundowner
Fifty degrees??? You gotta be kidding me...
post #44 of 241 Old 07-09-2010, 10:04 AM Thread Starter
TeeJay00
I can only dream of getting those figures here I am gonna give it a try in bypassing the radiator though !!
TeeJay00 is offline
post #45 of 241 Old 07-09-2010, 10:08 AM
stogie25
stogie25's Avatar
That is brilliant. My current "hot air intake system" does not lend itself to that, but it is a really good idea.
Jarhead Jeep Club
O|||||||O
My Build Thread
stogie25 is offline
hood , louvers , TJ
hood vents/louvers sgarhaereanh TJ Wrangler Technical Forum 1 04-17-2010 03:04 PM
hood louvers base shakers TJ Wrangler Technical Forum 38 04-15-2010 10:35 AM
Hood Louvers Anyone? DARKBLUETJ TJ Wrangler Technical Forum 9 03-11-2009 06:58 PM
Hood Louvers ThUmPeRcOn TJ Wrangler Technical Forum 30 07-07-2008 10:45 AM
Gen-Right Hood Louvers Linda or Greg TJ Wrangler Technical Forum 6 10-06-2006 07:29 AM
