Hood louvers... Do they really work? - Page 13 - JeepForum.com
post #181 of 241 Old 07-28-2011, 09:44 PM
2005X
couldnt remember if i posted in here or not. total cost for me was somehwere around $15
2005X is offline
post #182 of 241 Old 07-28-2011, 10:11 PM
jeepwrangler97
Originally Posted by RobSheaTJ View Post
So does anyone know where to find a diagram of hot spots on a TJ hood where the temperatures rise the most? I saw one before when looking into hood louvers and cold air intakes but I can't seem to find it again.
Maybe this will help http://www.oman4x4.com/hoodvents.htm
jeepwrangler97 is offline
post #183 of 241 Old 07-29-2011, 10:43 AM
RobSheaTJ
perfect. exactly what i was looking for.
Hopefully this is reliable.
"Wha's a Jeep?" Popeye asks Professor Brainstine.
_/l ,[___],
l--L --OlllllO-
()_)()_)-o-)_)
RobSheaTJ is offline
post #184 of 241 Old 07-29-2011, 11:58 AM Thread Starter
TeeJay00
I don't know how it has been since I installed my GenRights, A year I think! Anyway all I know after I tried them on is that the most obvious thing they do is preserve the hood paint from heat by letting the heat escape from nderneath it.
TeeJay00 is offline
post #185 of 241 Old 07-29-2011, 01:04 PM
99_TJ_Wyoming
Now that I have the 5pc Gen-Right louvres, I have a related question -
I have a 2.5, I have removed the fan from the motor and gone to an electric fan, is there any reason to keep all of the fan shroud thats directing hot air on to the engine and keeping air flow restricted. I know the power steering reservoir has to mount to it, but other than that is there any reason to keep the shroud with an electric fan?
99_TJ_Wyoming is offline
post #186 of 241 Old 07-29-2011, 01:08 PM
biffgnar
biffgnar's Avatar
I was under the impression that electric fans had a shroud incorporated with them.
Romney in 2020!
biffgnar is offline
post #187 of 241 Old 07-29-2011, 01:31 PM
MATT99TJ
When installing fans on different items, I've read in the instructions that removing the fan shroud would "severely diminish directional airflow." I've seen the same thing stated here many times when people talk about installing E fans. It would seem to me that you could cut the shroud back, but I wouldn't know how close you can get to the fan before it would start screwing up the air flow. On the fans here at work that I was talking about the "shroud" only extends a few inches past the fan, but they are much smaller than the fans on our motors.
From what I understand you need the shroud to stop the air from being blown out parallel to the fan blades. When this happens it pulls air from both front and back sides of the fan instead of pulling from the front and blowing out the back.
MATT99TJ is offline
post #188 of 241 Old 07-29-2011, 01:56 PM
99_TJ_Wyoming
I think I will try to find a 4.0 stock shroud, that should allow plenty of directional flow and be about 12" shorter than what I have now, or I may cut mine down to 6-8 inches from the radiator
post #189 of 241 Old 07-29-2011, 04:21 PM
ThUmPeRcOn
I'll play, here's mine "Cyclone hood louver"... http://www.jeepforum.com/forum/f9/cy...nstall-568988/
P.s... Several years later no problem with rust in the engine bay or paint around the louver, everything is the same except for a few additional mods...
The original point and click interface was a Smith & Wesson.
ThUmPeRcOn is offline
post #190 of 241 Old 07-29-2011, 04:27 PM
dwbrown
2014 JK Wrangler
The Gen-Right Louvers I installed seem to help with the underhood temps. they also look cool when you get water in the engine compartment and the steam rises up out of them .
USAF
dwbrown is offline
post #191 of 241 Old 08-10-2011, 05:18 PM
speedbump94
the best reason that i can think of for hood louvers (that hasn't already been posted) is if you were doing a water crossing the air couldn't escape out the bottom of the engine bay how it normally would
/l ,[____],
|-- -L--[]lllllll[]-
()_)-()_)==O=)_)
speedbump94 is offline
post #192 of 241 Old 08-10-2011, 05:59 PM
chmo
mine :
one more effect : the hood does NOT wiggle up and down anymore going fast on the highway
so I assume LOTS of air is vacuumed up THROUGH the hood now ... hot air
btw: passenger side paint (clear coat) was starting to fade already ... so instead of repainting this is a different kind of "touch up"
"The more I know, the more I realize how much I don't know"
chmo is offline
post #193 of 241 Old 08-10-2011, 06:03 PM
dwbrown
2014 JK Wrangler
I was thinking the other day if you could put small fans under the louvers that run for like 5 or so minutes after you shut the engine off to blow more heat out of the engine bay. Not sure what would work though.
USAF
dwbrown is offline
post #194 of 241 Old 08-10-2011, 06:10 PM
chmo
not sure if this is necessary though... chimney effect (hot air is rising up ... pulling more colder air rom underneath the engine) and the louvers are on top of the hood ... I think there is a constant air flow when standing still already.
chmo is offline
post #195 of 241 Old 08-10-2011, 06:46 PM
dwbrown
2014 JK Wrangler
It would be nice for blowing more air out than what would naturally rise out
USAF
dwbrown is offline
hood , louvers , TJ
hood vents/louvers sgarhaereanh TJ Wrangler Technical Forum 1 04-17-2010 03:04 PM
hood louvers base shakers TJ Wrangler Technical Forum 38 04-15-2010 10:35 AM
Hood Louvers Anyone? DARKBLUETJ TJ Wrangler Technical Forum 9 03-11-2009 06:58 PM
Hood Louvers ThUmPeRcOn TJ Wrangler Technical Forum 30 07-07-2008 10:45 AM
Gen-Right Hood Louvers Linda or Greg TJ Wrangler Technical Forum 6 10-06-2006 07:29 AM
